Daewoo washing machine carbon brushes
Have a dwd f1251s washine machine but cannot get carbon brushes anywhere
  • 8 Answers
SOURCE: remove carbon brushes from bosch washing machine
bad news im affraid mackem , depending on what motor your bosch has there is no way to change the carbons without removing the motor .
Posted on Feb 25, 2008
Coldcut
  • 1554 Answers
SOURCE: wff1201 washing machine
You have to take the back off and remove the motor
Posted on Feb 27, 2008
Master_Tech
  • 770 Answers
SOURCE: Daewoo Washing machine Problem
If it is new then it is under warrty plz call the dealer you bought iy from for service
Posted on Aug 02, 2008
barkencoa
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
ginko
  • 19396 Answers
SOURCE: Daewoo Washer Error E8
Hi.
E8 is fault connection from CCU (Control board) to balancing sensor.
When you get E8, this is often because of a faulty control board.
Try first disconnecting power for a couple of minutes, to reset the appliance.
If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Posted on Nov 08, 2009
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
I have a daewoo machine model no dwd f 1031 but in my machine detergent remain in detergent case after a cycle why my machine is not taking detergent from detergent case?
the valve to control the water too the tray or despensor isnt right or jammed check the intel filter too the cold / hot water intakes
they both have a little inline at the valve filter catch
take the two filters out
then reconnect the hozes and run a wash thru
this clears any crap
then refit the small filter cones and carry on with clean valves free from crud...!! a tooth brush is handy here
Mar 05, 2015 | Daewoo Washing Machines
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Daewoo Washing Machine Error Fault Codes
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
My washing machine does not clean clothes properly and washing powder residue is left after wash on clothes I have Daewoo Dwd F1243
start a wash with a load and after he machine fills with water check to see if the drum rotates this is usually the problem if you get powder residue on wash with no drum action the powder does not disperse also check to see if the machine spins if it does check belt tension if not check belt tension and motor brushes
Mar 04, 2014 | Washing Machines
I believe the EO code means the pump is blocked, and you will have to clear the pump for it to work again.
Oct 12, 2013 | Daewoo Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
