Question about Dualit Espresso 889 Espresso & Coffee Maker
How to descale dualit 889 - Dualit Espresso 889 Espresso & Coffee Maker
2 Suggested Answers
SOURCE: Dualit 889 espresso maker leak
As well as descalling it try renovating the seal, the solution in this link worked for me: <a href="http://drupalen.net/dualit-coffee-machine-leaks-0">http://drupalen.net/dualit-coffee-machine-leaks-0</a>
Posted on Nov 06, 2011
Dualit 889 pump sound normal but no water comes through after lond period without use
For the most part; the pump action is working, however; the water lines (Ports/Tubes) have debris inside and prevent the fluids from flowing. Clean and Purge or Descale as per the manual.
Feb 20, 2014 | Keurig Coffee Makers & Espresso Machines
I have an 889 with the same leak problem. This happened after I descaled it. The water leaks from the small hole on the base at the back of the machine, directly below the reservoir. It must need a new...
Most likely you have developed a leak where the pump joins with the boiler. If you put descale chemicals in the reservoir then they may have been baked into the boiler and the backpressure has either ruptured or unseated the tube that leads into the boiler.
This is not a repair for amateurs.
Graham Leach
Jan 24, 2010 | Dualit Espresso 889 Espresso & Coffee...
Dualit expresso 889 - faulty pump??
Actually solved this myself today. It actually was a buildup of scale as I tried a standard descaling sachet, followed the instructions and once enough scale had come out it burst back into life!!!
If you get 'any' flow at all the pump's fine so it just needs a really good cleanout - even if (like me) you think your local water doesn't tend to scale up your kettle.
Feb 04, 2009 | Dualit Espresso 889 Espresso & Coffee...
my machine did the same.... i just descaled it and gave all the parts a really good clean and it seemes to solve the problem
Dec 30, 2008 | Dualit Espresso 889 Espresso & Coffee...
Brew head gasket
I Rang Dualit direct and they sent out the gasket free of charge
t + 44 (0) 1293 652 500
info@dualit.com
Jun 28, 2008 | Dualit Espresso 889 Espresso & Coffee...
Dualit 889 Spare Parts?
I have the same problem and clean the filter using a small brass bristled brush (I think it is a suede brush).It is the only thing that seems to get in the holes.I can't get it completely clear but it does seem to do the job.I also thought of getting a gas mantle cleaning prong but haven't tried it yet.It seems to be a build up of coffee that causes the problem.Spares seem to be a problem because the machine is obsolete.I'm thinking of buying another machine off e-bay to use as spares.
franklepora@hotmail.com
Jun 22, 2008 | Dualit Espresso 889 Espresso & Coffee...
Dualit espresso machine
lost my instructions for descaling my delonghi espresso machine
May 15, 2008 | Coffee Makers & Espresso Machines
The frothing stick doesn't seem to work
descaling time not with vinegar with descaler vinegar remove calcium in little piece descaler melt it use 1 part descaler 1 part water put in the water container start it up open valve after a few second turn it off leave it for15 minute repeat untill empty after do 2or3 rince descaler is corosif thank you for using fixya pierre
Feb 10, 2008 | Dualit Espresso 889 Espresso & Coffee...
Cleaning and descaling Krups Orchestro 889
take a descaler solution never mind vinegar not strong enought 1part solution 1part water put that in our water container start the machine open valve let it drip for a few second untill you see the solution leave it like that for 10 minute after open the valve and do it again untill emty after you emty the solution clean water container very good fill it with water open the valve rinse very good because that solution is very corosif enjoy cheers
Jan 19, 2008 | Krups Orchestro 889 Espresso Machine
Dualit Espresso 889 Espresso & Coffee Maker Logo
32 people viewed this question
Top Dualit Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Dualit Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
