Question about GE WBVH6240F Front Load Washer
GE WBVH6240FWW Front Loader Washer is smoking
When put on regular washing it starts to smoke during the spin cycle.
fanny
  • 146 Answers
SOURCE: G.E front load washer Mo# wbvh6240fww
The door interlock may be faulty. Try closing the door firmly or hit the door handle when the door is closed.
Posted on Oct 31, 2007
ngfam1
  • 639 Answers
SOURCE: ge washer # WBVH6240FWW
Appointment department is open 24/7 but i''m not sure if they repair 24/7
Neil
Posted on Aug 25, 2008
MNfisherman
  • 11896 Answers
SOURCE: ge washer won't agitate
If the washer won't agitate at all, but the motor and belts are turning,
then you may have drive coupling or transmission issues. In this case, it
is well worthwhile to have a technician check the machine to verify this.
Sometimes, the base of your agitator can strip out, especially from
overloading. In such a case, the splines are damaged inside the agitator,
and can be seen after the agitator is removed.
If you can hear the motor running, and the water is moving a little bit, but not like normal where the clothes are being worked around you might just have worn out agitator dogs. This is a really easy 15 minute do it yourself fix, and the parts are less than $10 and widely available. Here is a how to article - http://zenfixit.com/repairs/appliance-repair/washing-machine-agitator-clutch-repair/
Posted on Feb 01, 2009
SOURCE: Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Posted on Oct 02, 2009
  • 1267 Answers
SOURCE: GE washer WHDSR209DAWW top loader spins and washes
I would guess that your pump has gone south as the machine needs the full power of the pump to evacuate the water from the tub. It just could be that the pump has gotten stopped up by many strands of lint washed out of the clothes. Most likely your pressure filter that keeps these strands from going into your pump has clogged and no longer lets the water pass. You are going to have to either take the filter apart and clean it or replace it with a new one. Replacing it is probably the cheapest as far as time is concerned. If you turn the machine over on a side, then you can discover the filter is a round plastic container about 6in in dia. and two small hoses connect to it with tensioned ring clips. To take it apart, you have to remove 3 or 4 compression clips around the rim pointed in toward the center. It also could be made of one piece and you really have to replace. Test it to see if you can force water through it.
Posted on Jan 13, 2011
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
I own a GE WCVH6800 J1WW High Efficiency front load clothes washer. Bought it in August 2009- 6 years old. It started to give off white smoke during a spin cycle.
Smoke in spin could be that the basket isrrubbing on the door seal rotate the drum slowly look for a wobble it should be centered if its not check your manual for warranty some cover this repair 100%some parts only. Not worth it if you have to pay whole repair
Nov 02, 2015 | GE Washing Machines
Samsung front loader smokes
Please do not run machine with smoke coming from washer. You could create a fire. Unplug power cord, and call a qualified service person.
May 12, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
GE front load washer model number WBVH6240HWW SERIAL NUMBER RM200099T spins freely by hand but started smoking and belt behind looks fine. What could be the problem. Before the smoke started when spin...
Hmm... Kind of difficult to say for sure. Does your inner spin basket wiggle up and down? If so, you've got a main bearing going. Also, put it in a spin cycle for a minute or so and then try smelling the windings on your main motor. If they smell burnt, you'll need to replace the main motor. Also, one last thought, check to see if your drain pump overheats. I say this because the drain pump is active during the spin cycle and a bad drain pump can sound extremely noisy and start overheating.
I hope this helps. Good luck!
Oct 19, 2014 | Washing Machines
Our GE front loader washing machine starts to smoke when it goes to High Spin.
The transmission may be leaking oil, and then burning when the motor gets too hot during the high speed.
Sep 01, 2011 | Washing Machines
The drum inside my ge wbvh6240fww washer is loose. I can move it around with my hands. During spin cycles it sounds like a tornado, and the room fills with smoke from where the drum rubs. The belt is fine,...
There is one bearing in rear tub/bearing is part of rear tub...To repair that unit you will need a rear tub/inner basket with spindal and possible a front tub if it damaged..If i was you I would price the parts b/c you may not want to repair it as it can be costly .....Good luck
Jan 31, 2011 | GE WBVH6240F Front Load Washer
I am having the same problem.
Did you find a solution.
Our washer is just a little over 2 years old and I am trying to decide if I should just cut my losses and never buy a GE product ever again.
Oct 12, 2010 | GE WBVH6240F Front Load Washer
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
GE WBVH6240F Front Load Washer Logo
66 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
