Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Upright freezer door won't stay shut
I moved my freezer with the door wide open to fit it through the door way. Now it won't stay shut. There is no suction. What happened?
  • Anonymous Oct 25, 2008
    my freezer door keeps coming open
    New Friend:
Large drawer wont push in enough so it is not aligned with other drawers therefore the door wont close properly looked there does not seem to be any object in the way
Posted on Nov 22, 2013
  • 903 Answers
The door maybe disaligned. Look at the the door side on to see if it has dropped a little. It may just need adjusting.
Posted on Oct 25, 2008
My freezer door was left open for several days while I was out of town
YES, unplug it and open the doors, let it completely defrost (inside and out) store all your food in coolers or through it out. Then when you plug it in all SHOULD be okay again.
May 13, 2014 | Refrigerators
Bottom freezer door will not stay closed.
Check the hinges and the door seal. If you need parts Sears service center online has a great parts locator for kenmore
Feb 18, 2014 | Hardware & Accessories
Can I lay down an Emerson 4.6 cu ft refrigerator to fit in my car to transport
Even though it's not the preferred method of transport, it's OK to lay a refrig down for moving, even new R134a if you pay close attention to the refrigerant lines.
Determine where the suction line runs up into the freezer. This is the largest tube connected to the compressor, and is usually (though not always) visible running up the back of the cabinet.
As long as the refrig is laid down on whichever side allows this line to stay 'high', there'll be minimal oil migration, and when you arrive at your destination, just stand it upright for an hour or so and it'll be fine. Obviously, the shorter the trip, the better.
If the suction line runs up the door handle side, just duct-tape the doors securely closed before you lay it down to keep them from opening and getting damaged. It helps to lay a block of wood under the top end, just to keep it inclined a bit, too.
I've been moving refrig's for some 32 years now, and while moving them in an upright position IS best, sometimes you just can't. I work out of a van, and have often laid both refrig's and upright freezers down for transport with no ill effects.
May 12, 2011 | Emerson Microwave Ovens
Fridgedaire Upright Freezer Door won't stay shut. Normally when closed, you hear the seal take place, now it pops open
Check the seal in the corners on the side of the door your hinges are on, ya may need to tack it down with crazy glue, but usually it'll curl in the corners preventing door from closing or pop open after you walk away
May 06, 2011 | Kitchen Ranges
Door was not shut tight. A loud buzzing sound recently went off and only stops when we unplug or turn off freezer. :(
loud buzzing I believe is an alarm that is waring you that the freezer is not cold enough. Door problems can be fixed. Test is to stick a dollar bill in the door and shut it. It should be a little hard to pull the bill out. Do this all over the door and find all the bad places. One problem is that the door can become warped by banging it against something or kids hanging on it etc. If you can see the warp you can actually bend the door back into place by holding the bottom of the door and moving the top in the necessary direction. Like jamming your foot against the bottom and pulling on the top or putting a box at the bottom of the door to hold it open and push the top. Next many time the bad fit door is because a hing has moved. All the hinges are adjustable. Usually you loosen the screws and move the door in the appropriate direction and re-tighten the screws. These screws are very tight so you need a big screwdriver and someone big to turn it. Lastly you can purchas a completely new door seal and put it in..
Sep 22, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Our freezer has been running nonstop to refreeze everything and now it is blowing warm air. What do we do? Unplug for a break or just shut the door?
Have u checked the thermostat setting? Set it as u usually do and if indeed the door was left open, then try shutting it down for(unplug) 10-12 Hrs and see if behaves normally after wards(set the thermostat too).
If not then have the thermostat replaced.....sodeep
Jun 02, 2009 | Maytag MZD2766GES Side by Side...
Upright freezer problems
Hi Robert,
Happy to help.
Sounds like it is low on freon
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 24, 2008 | Frigidaire Freezers
Kenmore freezer
Hi Robert,
Happy to help.
You need a new door seal.
But they are not easy to put on properly
Neil
Aug 23, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
386 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
