Question about Samsung Office Equipment & Supplies
Cant get wifi connection from cpl320w printer to samsung laptop
On the same network but have new router/modem cannot get laptop and printer to connect wireless
Mix-it-up
  • 832 Answers
SOURCE: Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Posted on Sep 28, 2007
SOURCE: Get no connection useing 6100 modem connected to wireless B router
Hi starman re westell 6100.
Hi i hope you have find solution with your issue ifnot let me walk you through on how to get it up and working.
First , you need to connect your modem directly to your computer. We need to access its Graphic Unit Interface by opening your browser and type onyour address bar its default gateway.
The def. gateway can be 192.168.1.1 or depending what ISP youre connected to . For ATT broadband its 192.168.1.254 / verizon broadband is 192.168.1.1..  { onyour address bar : type in 192.168.1.1 and hit Enter.
to check def gateway : you can go to start > run > cmd then enter > on DOS command type in ipconfig /all  then HIT enter > itl provide you your network list > your default gateway is your westell modem or if your linksys is connected than it should be you linksys.
Itl route you to your westell page. Try to go to  Broadband and choose connection or configure connection.button. Look for configure and by default you will see its in PPPoE> change it to bridged ethernet and save.
By enabling bridge to your modem w/c is westell youl have a chance to configure you linksys to PPPoE.
Connect you westell to your linksys and on your computer try to check your default gateway as seen above. By default linksys can be access by typing in 192.168.2.1 or 192.168.1.1. Itl prompt you for UN and PW: by default your Username is : Blank and Password should be admin. { blank = dont type anything}
On your linksys SETUP page > by default it is set to DHCP or obtain IP address automatically. Pls change it to PPPoE and type in your UN and PW : username@isp { your ISP name}. and hit save settings or save.
Restart your linksys and try to browse to check fore connection.
For all types of modem such as westell : you need to set it to bridge mode first foryou wireless router to work ie linksys. Set linksys to PPPoE .. that should work .
For more detailed steps or questions re: this issue pls dont hestiate contact me. Best wishes.
Pls enable you Wireless Encryption for your home network security.
Ciao .
Prince
Posted on Jun 11, 2008
PABLOCSA
  • 1124 Answers
SOURCE: connecting to printer on wireless network with built in wireless adapter
You have to share the printer to the network
To do that go to Start >> Control Panel >> Printer
Select your printer and right click go to Sharing
Mark "share this printer" an hit ok
A small hand will appears below your icon printer
Now you have the printer available on your network
Posted on Oct 03, 2008
SOURCE: Brother MFC-7840w wireless printer won't connect to network
For me, the quick solution was to use the 'Open System' instead of 'Shared Key', 'WPA/WPA2-PSK' or 'LEAP' authentication options on your printer.
However, after that, I decided to change the security settings on my router a bit. Log into your router, click the 'Home Network' icon at the top, and then check out 'Wireless Settings.'
The 'Wireless Security' section should tell you how your 2Wire is configured (which I eventually changed to WPA2-PSK.)
-DJ
Posted on Nov 15, 2008
  • 47 Answers
SOURCE: Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Posted on Nov 27, 2008
Acer 5100 will not connect to wireless
Things to Check:
1. Please check if the wireless switch on your laptop is ON?
2. Are you able to see your wireless network in the list of connections?
If the answer for both of the above is yes, then Turn OFF & Turn ON the Modem/Router.
Please delete all the connections that are stored on your laptop's wireless settings/Wireless connections and retry connecting to your network.
On your modem/router, please remove any security passwords and make the network accessible by any one any try connecting to the network.If the connection is successful, then reprogram the modem / router with a password.
Another easy fix to find if the fault is actually with your laptop is to go to a free public wireless hotspot and see if your laptop connects to their network.If it dd, its not your Laptop but your wireless modem/router.
Feb 28, 2014 | Acer Aspire 5100 Notebook
Tip
Troubleshooting Laptop WiFi Connectivity Issues
Most laptop manufacturers provide an external switch to switch on/off the WiFi functionality. As a result, the first problem most new laptop owners encounter with trying to connect to a wireless network is that their WiFi has inadvertently been switched off. So, if you have a WiFi connectivity issue, the first thing to make sure of is that your laptop's WiFi external switch is on.
The next most common problem when it comes to WiFi connectivity issues is that the signal strength is too weak to hold a connection. This can be extremely confusing if the network is working fine for a person sitting at the next table. This could be due to several reasons. This person's laptop might have a more sensitive WiFi receiver, be set in just the right location where the signal strength is maximum, or even be accessing a different WiFi network other than the one you are trying to connect to. When you're troubleshooting a wireless connection, make sure to get as close to the router as you can, certainly in the same room if it's in your own home, so you can eliminate signal strength as a possible issue.
In order to prevent every stranger who walks by from accessing any network with WiFi capability, there are a number of security options that can be set on WiFi routers. The most common of these is simply enabling password protection, so that any laptop trying to connect to the network will have to provide a password for the initial connection (after that the operating system remembers the password). In order that you be able to connect to a WiFi network, you will have to set up your laptop's WiFi connection with the correct key. First, try the key printed on the router label, but if a custom password was created when the network was set up, you'll either have to find the piece of paper where it was written or chase the person who set up the network. If the password absolutely can't be recovered, search the Internet for how to reset the router (varies with brand), create a new password and enter it on all the computers that use the connection.
In some cases, it's easy to reset the password or turn the security on and off by connecting directly to the router with an Ethernet cable and typing the fixed IP address for the router into your browser.
Connecting directly by cable to the router is an important troubleshooting step for wireless connectivity even if you don't have a password problem. If you can't connect to the Internet even after plugging directly into the router, neither the wireless adapter in your laptop nor the wireless transceiver in the router are at fault.
If you plug directly into the router via the Ethernet cable and you gain access to the Internet, you can continue troubleshooting wireless issues. Check Device Manager to see if it's complaining about the network hardware. If not, and you still can't gain access at this point, the problem is either with the high speed modem and ISP, or a networking software issue within the operating system.
High speed modems, often called routers if they include a built-in router, are equipped with a series of status LEDs that can be used to diagnose many connectivity problems. Whether you have a cable modem connecting to the cable company, DSL via the phone company or one of the more esoteric high speed modems, they should always include an LED that tells you if the connection between the modem and the Internet has been established. If this link light is out, or has changed colors, say from the familiar green to an ominous red, power down the modem and turn it back on again. This hard reset will usually fix dropped connection problems caused by storms, power surges or signal interruptions, providing the modem hasn't been damaged. A modem/router will also include a status LED to show whether an Ethernet cable connection to your laptop is good, and your laptop will have a little status/activity LED for the network connection as well. While color coding isn't universal, solid green usually indicates a good connection, and blinking green or orange usually indicates activity. Some modems include an LED to tell you if the DSL or cable link to the ISP is good even when the Internet isn't functioning.
Operating system issues affecting connectivity can include firewall (security software) settings that prevent your computer from establishing communications with the Internet Service Provider (ISP), or the failure to install the software that ISP requires. Unfortunately, there are also more complicated problems that will require drawn out conversations with the ISP's technical support department to troubleshoot.
If you're adventurous, or desperate, you'll find all sorts of third party software online that will reset the Windows stack or change registry settings back to defaults, but you're better off trying the tech support route first if a software glitch is at the bottom of your problems.
Please Vote for this Tip if you found it helpful.
M. Omran
on Oct 25, 2010 | Computers & Internet
Tip
Multiple Computers on Same Network, Continual Internet Connection Dropout
After adding that second or third computer to your home network are you constantly fighting over who's using the internet connection? When your high schooler logs into his facebook chat, are you getting dropped off of your internet connection?
Or have you added a wifi router and is your whole network not staying connected like it did before you added your wifi?
These are common issues and we answer these questions often at FixYa.
Here is s a tip that will get you past the internet connection being dropped by someone else on your network attempting to log into the internet or help you get that wifi up and working with out all the cut outs and drop offs.
Follow this simple procedure and you'll be amazed!
1. Turn off everything. Turn off computers, routers, modem, printers... everything that's on your LAN (local area network) or home ethernet.
2. Turn on your wireless router next. With the ethernet cable connected to your wifi router to your modem and let it cycle up to running. If you aren't running wifi, do this with your main router. Make sure your modem and everything else is still off.
3. Turn on your modem (enet cable attached to wifi router or main router) and let the modem cycle up to running.
What you've done is allowed your wifi router to be established as the "MAC" Address for your modem. Modems look for a single MAC address. Once the router has this address, the router will maintain the connection with the modem and the internet, AND will assign MAC addresses to your computers, network printers, network routers etc, while still maintaining your connection to the internet.
4. Turn on all other peripherals, computers and network printers. At this point the order of power up isn't important, because your router will be assigning separate addresses to all the computers, etc on your network.
That's it! The secret's out! Just keep this handy... remember if you have power outage, you'll need to reboot in this order again... Happy Home Networking
on Dec 02, 2009 | Computers & Internet
3G usb modem wont connect to internet through wireless router
Sure you can that. 1. you have new internet connection. need to configure the router according to internet connection type. it could be manually ..
2. set the wireless settings on the router again manually.
then try to connect the router.
If you need my help
the send me some information about the network.
1. when you connect your pc to modem what ip address you get.
2. what ip you get when u connect your pc to router. make hard wired in both condition.
and possible send me your email add.
Dec 23, 2012 | Computers & Internet
Wifi won't connect to network
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Nov 14, 2011 | Computers & Internet
I have zyxel p-600 series router and i managed to connect to internet via cable (wired).then internet works on my ubuntu 10.04 but only when i write sudo dhclient in terminal. then internet works but i...
when going wifi
you have to go to internet connections or options in the control panel and click on the LAN settings button
the wifi modem will have a security code on the back and the wifi connection area code
click on the found area code on the back of the modem then enter the security code
Jun 04, 2017 | Zyxel Prestige 600WH Wireless Router...
Wireless printer compatability
Any printer can essentially be made into a "Networked" printer that function is all a function of software. You can usually, use any WiFi printer, as long as you know it's address, and can connect to it. Install the drivers and connect to the, WiFi, Networked Printer. A WiFi networked printer, is essentially seen as a "PC". It simply has an Address, and you just "Connect to" that address...
Apr 14, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Im trying to connect my ps3 to my wireless router. it has recently stopped working. is there anything i can do?
Sure! Try this:
1 Turn your network off. Modem router, computer, printers etc. turn them off.
2. Leaving the wireless router connected to the modem with an ethernet cable (modem power off) , turn your wifi router on and let it cycle up.
3. After the router is cycled up, turn power on to your modem , leaving the ethernet cable connected to the wifi router's internet port. Let the modem cycle up .
4. After this, turn on all computers, routers and etc... no particular order.
This should allow your modem to find the wifi router and direct it to your computer via wifi or ethernet..
Dec 08, 2009 | Computers & Internet
Lost connectivity to network printer when switched to ATT u-Verse
Is the printer connected via wireless? When I recently connected up a new wireless printer to my UVerse network, the printer manual said that establishing the first connection works better via an Ethernet cable directly to the Uverse router. After the printer is set up once, then I could remove the ethernet cable and connect to the printer via wireless from all my computers.
For all wireless PCs that were previously connected via wireless to dsl, you need to create a new network connection for each one, then enter the key that is listed on the side of your Uverse router when prompted. Sometimes it takes a few minutes to establish the connection.
I am amazed that ATT was so unhelpful on these issues. I was one of their first Uverse customers in Texas, and several times over the last years, techs would visit my house to solve a problem or hook something up, explaining to me as he went. That their helpful attitude is deteriorating is a real shame.
Mar 11, 2009 | Computers & Internet
Laptop
It really depends on what "modem" Orange provided you with and how your personal PC is connected to the modem.
If the "modem" provided by Orange uses WiFi (such as Livebox) networking, then it is a matter of setting up your daighter's laptop to access and use the Livebox WiFi Network. In this case no router is needed since your modem is also a router.
If your PC is connected via Ethernet port to the "modem" and Orange's "modem" is a single Ethernet output port, you would need an AP/Router (Wireless since I am presuming the your daughter's laptop would be accessing the Internet wirelessly) such as the LinkSys WRT54G.
If your PC is connected via USB port to the "modem" and Orange's "modem" has only a USB output port (no Ethernet), you need to make your PC as the default gateway/software router and share your PC's Internet connection. If you are connecting your daughter's laptop using Ethernet cable, then you don't need a WiFi AP/Router but an ordinary hub. If on the other hand the new laptop would connect wirelessly, you would still need something like the WRT54G.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | 2wire (1000-400108-001) Router
22 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
