Question about Compaq Inkjet IJ650 Printer
Printing PDF files
When I print some PDF files using Adobe Reader 7.0.8, in sone cases some of the text does not print (some does)in a random pattern of text and blank spaces. In other cases strange characters print where regular text should be. In either case the files display fine on the screen
2 Suggested Answers
SOURCE: Adode Acrobat Standard PDF Files won't print on A3000
I've had the same problem when using Acrobat 7.0. I reinstalled version 6.0 and it works fine. You may even want to try a different reader such as Foxit.
Posted on Jan 10, 2008
  • 4 Answers
SOURCE: Web pages print ramdom characters
Try a different version I had it happen to me, so if it did it using 9.0 adobe acrobat reader I would go to 5.0 or 6.0 version instead and then it would solve my problem everytime it's a hassle but don't know any other way around so that's my best advice.
Posted on Dec 24, 2008
0 characters
1 Points
ES9410 - PDF jumbled printing
Assuming you are using MS Windows then install FoxIT pdf reader which allows command line printing on Windows. Go to to get it. Make sure your OKI printer is the default.
Once installed you can print using the command, from my dusty memory -
Reader.exe /p MyFile.pdf
I don't use Windows any longer, now exclusively Linux, so I might be mistaken.
Cheers, Martin
Nov 07, 2013 | OKI Printers & Copiers
How to specify the paper size and page setup
This section describes the procedure for specifying the paper size or page setup when printing from an application, taking Adobe Reader 6.0 as an example.
Note: The screen shots used in this section are from Windows XP Home Edition.
1. Open the PDF file to print with Adobe Reader, and then select [Print Setup] from the [File] menu.
2. Specify the paper size of the document and the printing orientation, then click [OK].
3. Select [Print] from the [File] menu.
4. Select this printer for [Name] or [Printer Name], and then specify the printing preferences.
Note: The printer name displayed in this dialog box can be changed in the [Printers and Faxes] folder (the [Printers] folder for Windows 98/Me/2000).
Jan 27, 2011 | Canon LASER SHOT LBP 3300 Printer
How do I extract the ink cartridge from the Epson NX100. The buttons read On, STOP, Color Photo, B&W Text and Color Text. The cartridge case will not stop in the middle in order to remove a cartridge.
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK=
You will need an adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 17, 2010 | Printers & Copiers
Epson Stylus T10 printer prints out random symbols from PDF file
When you attempt to print, make sure you are using the correct printer. If you had an old printer before, its name will be still in the printers' list.
and unknowingly you may be trying to print with that printer. To check this:
Goto the File Menu -> select Print-> Highlight the printer you are currently using, and then Print.
I am pretty sure this will solveyour problem.
If it does, give a rating to this answer.
Have a good day.
Jan 06, 2010 | Epson Printers & Copiers
Adobe PDF reader tends to print webdings/wingdings in its version 8 incarnation. Download FOXIT reader free from and try to print your document from that instead of Adobe. This nearly always fixes the problem. antosarmy
Nov 25, 2009 | HP DeskJet 5550 InkJet Printer
Problem printing PDFs on an ImageRunner 3570
Hi - I had a similar problem except my Brother printer wouldn't print any PDFs. I had Adobe Reader 11 installed at the time. I uninstalled then reinstalled a previous version - Adobe Reader 9 and that worked a treat!
Mar 05, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Msg 'unable to start print job, is printer available'
A customer called me with the same msg. Let me explain first what the problem was..they had a Graphic PDF that on the HD was 20 MB but when extracted was well over 200 MB..first I had thought the pdf was exeeding the Printers memory but after testing it was not. The customer was printing the document using adobe PRO I had him print the document in reader 8.1 and made sure the print as image under advanced was selected and the document printed..
Aug 09, 2008 | HP PSC 1410v All-in-One Printer
Sharp ar-m276 printing error message
There is a known problem with adobe 7 printing on this model. Unistall the PCL6 driver and re-install it using the PCL5e driver instead. This will fix your problem.
Oct 04, 2007 | Printers & Copiers
Won's print pdf files
Trouble with the HP Laserjet printed output may be solved by using the following settings (or similarly named ones): "Use raster Graphics" (instead of "Use vector graphics"). This may fix the problem of "reversed" text (white on black background) not printing, as well as other problems. "Download TrueType Fonts as bitmap soft fonts" (select "bitmap" instead of "outline" or "graphics"). This may remove the overlapping of text on the printed document. "Graphics dithering" select "coarse" or "fine" (instead of "none"). This selection may improve the quality of images contained in the document. You can find all these settings in your printer properties. Go to File, Print, click Preferences, in Printing Preferences, click one by one all the top options, and change one of the top solutions, one at the time, checking your printing output. Always check if you have the latest version of Adobe Reader Program. If not download the latest version from Adobe, it's free. Is this the first time that you have the problem? or with the same printer (HP 4si), did you were able to print PDF files in the past?
Sep 10, 2007 | HP LaserJet 4si Printer
Compaq Inkjet IJ650 Printer Logo
50 people viewed this question
Top Compaq Printers & Copiers Experts
john archer
Prashant  Sharma
Prashant Sharma
Are you a Compaq Printer and Copier Expert? Answer questions, earn points and help others
