Question about Craftsman 3/8" Pro Air Ratchet Rapid Reverse 19888
Craftsman air ratchet 875.199430
Works up till the end drive that wont turn at all
2 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: very little power to craftsman 3/8 ratchet. air
add a few drops of marvel mystrey oil to the ail line opening to clean it out and try it again
Posted on Feb 24, 2010
I bought a used ratchet and it won't spin the air blows out the exhaust what can I do to fix it?
on the end where the socket goes there a fap that swings back and forth when you operate it somethimes it will stick to one side you need to peck it on the side and it will free up and run
Sep 28, 2014 | Craftsman 3/8" Pro Air Ratchet Rapid...
The ratchet on craftsman microtork torque wrench 44593 does not work
The ratchet pawls have seized and a ratchet rebuild kit is needed.
Jul 20, 2014 | Craftsman Microtork Torque Wrenches -...
Craftsman 875188020 air leaks out the side only when trigger is pressed.
All air ratchets have an exhaust. Air in must go somewhere and it will go out the exhaust. Some exit beside the air inlet & some have the air exit out the side of the handle. If the air is not coming out of a defined air orifice, then you may have a worn out gasket where the handle meets the head or you may have a cracked handle. The handle unscrews but you must hold the head in a vise while you use a wrench or adjustable wrench to grip the end of the handle to unscrew it for inspecting the internals.
Feb 18, 2012 | Craftsman 3/8" Pro Air Ratchet Rapid...
Which way does a bottom pully bolt turn to loosen it on honda accord 1992
Anti clockwise (Counter clockwise) to loosen, but be warned, it is tight, it is very tight, and will require very heavy duty drives to loosen it. I cannot remember the torque offhand, but suspect it is in the region if 300 ft/lbs.
Apr 06, 2011 | Honda Accord Cars & Trucks
The compressor turned on pumped up and shut off and wont start up
Inccrease the line pressure to 90 PSI, a air ratchet is a very high volume air tool and the compressor may not be able to keep up with it.
Jul 14, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
What sockets fit
Any sockets will fit the ratchet, 3/8 drive, the impact drive is 1/2 drive, and they make hardened sockets for it. And I can't really make out the last tool there in the kit. The impact tool will take normal sockets for reg duty use but not for wheel lugs and such, they will crack, but if you buy Craftsman, they will replace it. I have only cracked one in thirty years. But I also have the hardened set of sockets. Hope this helps.
Jun 25, 2010 | Craftsman Mechanics Air Tool Kit Impact...
The drive just spins, does not have any torque
needs a service at an airtool shop the o-rings get hard and start to break up ,i hope you havent used wd40 or the like ---bad news-- only use automatic transmission fluid or airtool oil, a service is not dear and you wont know yourself
Oct 09, 2009 | Craftsman Air Tools & Compressors
Air impact tool does not engage but will eventually engage after switching directions.
Although I do not have a Craftsman, I have taken severl othe brands apart. They all seem to be much the same. You do not need specialized tool. You just have to be mechanically savey. I think the grease has thickened up too much so taking it apart and cleaning it should do the trick. Start at the working end end and separate the front end. Work on a clean bench where little items (screws, ball bearings etc) won't roll off and get lost. When the two parts are separated, you should see the hammer mechanizm and a lot of grease. remove and clean everything that you can. Re-lube the mechanizm with a light lube grease and re-assemble. Turn the socket drive by hand to make sure everything is free, then apply a liberal application of air tool oil to the air port of the gun and attach an air line and give it a try . Put a load on the socket to check for impact functioning properly. I hope this helps
Jun 02, 2009 | Ingersoll Rand 271 Super Duty 1 Inch...
Craftsman 3/8" Pro Air Ratchet Rapid Reverse 19888 Logo
234 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
