Question about Miele Coffee System
Miele cva error 81 - Miele Coffee System
3 Suggested Answers
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Posted on Jun 03, 2010
guru_fixya
  • 944 Answers
SOURCE: hello my miele cva 4062
F
ault error 81means-Internal circuit board problem.This error will be cause due to short circuit in the board or the wiring connections internally loose.Use multi-meter to check you are reading volts on the board.If there is no change in the multi-meter then circuit needs service.Check for loose wiring connection
Click here to download the manual.Use this for more help in maintenance.
Note:Usually this problem arises because of Not using the
Switch On/Off button.You would have directly used the main switch with out using the Miele CVA On/Off button.This causes the board to experience sudden increase or decrease in voltage
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 11, 2010
Brew unit stuck
Hi molly girl.
You can try to clean your Brewunit. Most of the times when that message appears, it means the brewunit is dirty
You can have more info in the manual if you dont have it:
http://www.miele.co.uk/Resources/OperatingInstructions/CVA%20620.pdf
Jan 11, 2008 | Miele CVA615 Espresso Machine
Miele cva 5060 when i press on shows 'insert boiling unit.' And stucks there any solutions pls .
any chance you could put up a photo of your brew unit ? something has fallen out of mine and i can't figure out where to put it !
Aug 20, 2015 | Miele Coffee Makers & Espresso Machines
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
Meile cva 4085 not brewing no error
Hi. i need more info. does it turn on, does it heat, make steam, make any noises?
Sep 24, 2011 | Miele Coffee System
Where can I buy a Miele CVA 615 Expresso Watertank?
The only Miele spare parts are direct from Miele or through a Miele service agent. Have a look on the Miele website for your nearest Miele branch or service agent in your country.
I work for Miele and they only sell parts this way. if you call the Miele spare parts number off the website and tell them you have a cva615 they will be able to mail one to you.
Hope this helps.
Mar 23, 2010 | Miele CVA615 Espresso Machine
Parts list and drawing for a miele CVA 620 coffie machine
you would have to contact Miele spare parts for this information it is not readily available on the internet.
Nov 19, 2009 | Miele CVA610
How can I override descaling on a Miele coffee maker?
how can i override descaling on miele coffee machine cva 2660
Oct 30, 2009 | Miele CVA2660 Stainless Steel Coffee Maker
Miele Coffee System Logo
403 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Colin Stickland
Colin Stickland
steve morris
steve morris
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
