Question about Onkyo Audio Players & Recorders
Error Code DSP56K4 on Onkyo TXDS939 AVR Receiver: Would like to know reset/reboot option. Along with what this error code means? Thanks, Joe
  • rozneriko Nov 26, 2008
    need to reset a TX Ds 494 onkyo receiver
5 Suggested Answers
  • 3 Answers
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
Posted on Aug 21, 2008
SOURCE: Code for Sony BDP-S300 Blu-ray player on Onkyo remote
Player can be made to work without remote. But it is a pain.
You need to press pause then play in the right combination.and you can get both DVDs and Blu Ray disks to work. I bought a store floor model that did not have a remote. I went through the same problem when I would lose the remote for the HD-DVD player. My four year old daughter knows this trick pause pause play for DVDs and pause play pause play for blu
Posted on Sep 21, 2008
  • 6 Answers
SOURCE: cant find universal remote code for the onkyo tx-sr605
Your onkyo receiver and remote controller only decodes 4 digit codes so what you have to do is to call the manufacturer of the remote controller it self and ask for the hexa decimal codes for their remote. They should provide it to you coz they're the ones responsible on doing that.
Posted on Nov 29, 2008
SOURCE: Xerox Doc12 10-386 error code
10-386 Error
Posted on Dec 01, 2008
SOURCE: Error code sc 552 on Ricoh CL7100
To clear any code on a Ricoh / Savin copier that will no reset by turning the power off / on you need to first enter the service program mode. This is a safety feature installed when repeated resets of some codes could cause damage to the machine or possible fire hazard. Most of the time these codes deal with the fusing unit. The fusing units operate at around 180 degrees celcius. Thats pretty near the point where paper catches fire so you see the need for safety there. Anyway, you can sometimes get a false fuser code if the room is cold in the morning when you first power up the copier and the machine takes longer than normal to reach operating temp. Another reason can be that maybe you didn't push the fuser back in good enough after clearing a jam and the electrical contacts did not make good contact. In these instances you can clear the code and go back to copying. Should the code come back after doing one of these resets then it means there is a bigger problem with your fuser and you need to call for a service visit to have the problem fixed.
Here is the reset for it:
1. Press the Clear Modes (yellow on most machines)
2. Press the numbers 1,0,7
3. Press and hold the Clear / Stop (red on most machines)
after a few seconds on machines with an LCD display screen you should see the screen change to display "SP mode" with a few selections. On older or smaller machines without an LDC display screen you should see a flashing "0" on the panel. This lets the machine know its ok to reset the code. Do not make any selections in this mode. SP mode if for making electrical adjustments to the copier and taking the machine out of spec can cause a lot of problems for you. Once you enter the SP mode you just need to turn the machine off / on. (make sure you do so with the main switch that you have to rock back and forth and not the button that just gets pressed to shut down the machine, the main rocker switch is often located on the front door or on the left side of the machine, sometimes covered by a swinging cover you have to lift first)
If you do not hit the keys in the right order, the machine will not go into SP mode. You can just start over with step one untill you get into SP mode.
After doing this and the code resets but then comes back again or gives you another code, you'll have to place that service call. If not then happy copying to you.
Posted on Jan 14, 2009
Error code when using the built in flash
try to remove first the battery for an hour., to reset all the save setting's.
Let me know here again.,,
micro
Jul 29, 2008 | Sony Alpha DSLR-A100 Digital Camera
What is error code NG:LCRSLSRBLBR"
Hi Rex, if you get this on your display please give us a call so that we can walk you thru this diagnostic, you can reach our Product Support Team at 800-229-1687 as they are here 24/7 ready to assist, Thanks, JT
Nov 17, 2015 | Onkyo TX-SR605 Receiver
CD player displays error code: ER-1
That error code means an unknown error has occurred. Try cleaning the player itself, along with the CD's prior to insertion to see if that helps.
Feb 02, 2014 | Dual XD1228 CD Receiver
No Audio in HDMI THRU Onkyo HT-R380 Receiver
Hello, I am sorry about your issue. I suggest that you contact us at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Mar 03, 2017 | Onkyo HT-S3300 Theater System
Need universal remote code for ATT uverse remote for an avr Onkyo TX-SR875
hi! i do have a couple of codes here for your Onkyo 2006, 2219, 2220, 2318, 2410,5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140 hope this helps! goodluck!
Mar 07, 2010 | Onkyo TX-SR875 Receiver
Error code C-D351 on a Bizhub C250
didn't find this code, so dis you read the code correctly and is the model write. you can try troble reset. turn off printer and then on again, holding utility key down. push trouble reset, and reboot again.
May 05, 2008 | Konica Minolta bizhub C250 All-In-One...
Says protect
Probably some speaker wires got shorted or the output stages freaked out and the cpu went into protect mode. Normally plugging it out of and in to the wall socket should/could reset it.
First check all wiring at the speaker outputs and on the speakers
then if it still wont startup you could try the avr-1500 method with
some trial and error pressing of buttons.
avr-1500 reset method:
Unplug the unit from the wall, hold down both video select and audio select at the same time, plug it back in. Keep holding both buttons for 2 secs, unit will reboot. As you have no audio select button on your avr-1100 you might try pressing video select and another key to see if this will reboot it.
Jan 13, 2008 | Denon AVR-1100 Receiver
76 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Dennis McCollum
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
