Question about Dell 2130cn Laser Printer
077-900 code appears saying paper jam but there is no paper jammed in machine anywhere wont reset
2 Suggested Answers
doron_c21
  • 387 Answers
SOURCE: I have a Dell 3010 that has error msg paper jam
you need to check the fuser, sometimes a small piece of papaer or a label stick on he fuser in order to do this you need to open the back and top cover. or take the printer to service
Posted on Aug 21, 2010
Testimonial: "when I finally figured out where the fuser was,there was paper rolled around roller. I carefully unrolled it with its feeder wheel. Its OK now. TU "
My Gestetner- DSm415pf has an error code 121. How do I clear it so I can use the machine?
The only way to reset the jam code is to find the tiny scrap of paper that is still caught in one of the sensors. The 121 jam code is "Exit Sensor Off", essentially it means that the paper did not reach the exit sensor. This would not cause the machine to still think there was a jam, as the paper obviously never made it there.
Check and make sure you have fully closed all the doors, including the front. If that is good, then open and close all the doors one by one. If that doesn't work, then there is a scrap of paper still stuck in the machine somewhere.
If you can't see one anywhere, then it probably is a scrap stuck at the registration sensor, which is just below the registration roller. I've seen this many times, and unless you really get in there and look closely (Flashlight helps), you will never see. It's a major pain to fish it out, so good luck.
Oct 09, 2012 | Gestetner DSm415pf Digital Imaging Sytem
Unable to Clean 5A
The machine does not work due to a paper jam or some sensor problem.
Clear the paper jam, try to clean the sensor on the top of the printhead.
Mar 03, 2012 | Brother MFC495CW
It wont print, says paper jam, yet there is no paper stuck anywhere? any suggestions?
Hi!
Try removing the cartridges and drum and clean the big grey roller as this picks up paper and if not it will show a paper jam without paper being in the machine!
Good Luck!
Jan 17, 2011 | Samsung CLP 300 Laser Printer
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Says there is a paper jam but we looked everywhere and there is no paper stuck anywhere in the machine
soes it say original jam or just paper jam if the jam is in th document feeder part open the top and check the sensors where the paper goes trhough.you may have to take the toner/drum unit out to reset the jam also if there is a door on the back open and close this to reset the sensors. If there was no paper the first time check the paper tray by pulling out and then look inside where the tray sits as the poaper might be stuck there.. also check the tray in that the paper sits tight in the guides and the rollers that feed are not dirty. If turning on and off doesnt get rid of the jam there is something stuck on one of the sensors..Goood Luck A
Aug 11, 2009 | Office Equipment & Supplies
CARTRIDGE JAM - CARRIAGE JAM - PAPER JAM - RESET POWER
change the carrage block will solve this issue.the carrage block cable is damaged
Jun 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper jam msg. in Canon mp530; doesn't appear to b a jam though
look for a paper jam in the front and the back of the printer. open the compartments and take a look. if all is clear unplug the printer and then plug it back in. this will reset it. good luck.
Jan 16, 2009 | Brother MFC-3240C All-In-One InkJet...
HP OJ 6310 All in One Paper Jam
check for a small piece logged inside, remove the toner cart and check that, take paper out and check under that
Jan 10, 2008 | HP Officejet 6310 All-In-One InkJet...
Brother MFC 3240C Paper Jam Error Message
If it is not resetting then either there is still something on a sensor or you did something to a sensor by accident.
here is the manual
http://www.retrevo.com/s/brother+2820+fax++manual
Nov 21, 2007 | Brother IntelliFax-2820 Laser Fax
Dell 2130cn Laser Printer Logo
206 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
