Question about Krups XP7260 Espresso Machine
Krups - YY1536FD - Nespresso water tank leaks
Water leaks out of bottom of detachable water tank
dahaka
  • 347 Answers
SOURCE: I have a Krups Nespresso
Hello endres,
Here you can find the user manaual.
http://www.krupsusa.com/NR/rdonlyres/780A0DB4-2A87-4308-954A-ED60C3B68B08/19887/867.pdf
Good luck, and remember to rate this solution
Dahaka
Posted on May 27, 2008
SOURCE: Krups type 897, nespresso: Water leaking
I swaped the hose around.
The o-ring at the element end is bigger and can be held in properly by the clip at the pump end. The bracket/clamp at the element end holds in the smaller o-ring sufficiently.
Posted on Oct 14, 2008
  • 3 Answers
SOURCE: krups fmf 5 water leaks from
I took the bottom off mine and found that a hose that connected to to the water level tube had become disconnected.
In order to get the bottom off you need a Torx internal tamperproof pin (6 lobe) screwdriver to get the 5 screws out.
Posted on Jan 06, 2009
  • 17 Answers
SOURCE: I have a Krups XP 7230 Expresso Machine. Water is...
I have a xp7240 which I believe has the same housing as yours. I can remove the bean container by pulling off the grind selector knob and removing the only screw.
Then remove the scute for the cleaning tablets. Then remove the two screws that were covered by the scute. Remove the water tank. Under the tank remove the two screws.
Then the trick where everyone seems to look for: The facade of aluminum can be moved off. Set the machine on the floor and pull hard upwards at the facade. This comes off (pull hard!) and four screw are uncovered. Remove them and pull then back housing of the machine (remove first the containers/drawers). Now the inner parts are freely accessible. Take photos and remove the components from top till bottom to get to the bad parts that need replacement. The valve that leaks is on the bottom of the machine (will cost you a lot of time to get to it. Don't know the replacement price.) Good luck!
Posted on Aug 07, 2010
SOURCE: krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter: http://www.microcenter.com/single_product_results.phtml?product_id=0332974
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
Posted on Feb 02, 2011
Nespresso Essenza 90 leaking at the bottom seam underneath the used capsule holder, HELP
Try gluing the seam with lock tight glue or similar plastic gluing compound. Let it dry overnight and try again.
Oct 16, 2014 | Nespresso Essenza C90 Espresso Machine
How do i clear the air bubble in the nespresso machine?
OK fill the tank and only use water press the small cap botton and after 5 seconds stop the machein and do the same again untill the pump gets the water into the system
Sep 17, 2014 | Krups Nespresso Essenza XN 2009 Espresso...
Krups water leak
It could be the seal where the tank engages. I would remove the bottom and prop it up so I could see underneath it and then engage the tank and see where the water is coming from. Sometimes putting it over a mirror and having a torch on hand can help you see deeper inside while it is leaking.
Jan 13, 2014 | Krups Gusto 880-42 Espresso Machine
Can't remove water tank krups nespresso citiz
Open led and pul tank out if not try doing descale it may have got stuck from solts
Jan 03, 2014 | Nespresso Citiz D110
Krups FNA2 doesn't draw water!
If it sounds like a pumping noise but louder then it may mean that the pump is bone dry and needs to be primed. You need to find an imaginative way to force water into the socket that the tank engages with. A clear hose of the correct size with water already in it and then press the button and blow into the other end of the pipe. Once the valves are immersed in water it should start to function.
Dec 18, 2013 | Krups Coffee Makers & Espresso Machines
Water leakage inside
Use less water....
Apr 29, 2009 | Krups Nespresso 554
Krups nespresso not heating water
That is a faulty thermostat or a defective control board.
Contact Krups and have the machine replaced.
Contact - Krups International
Feb 17, 2009 | Coffee Makers & Espresso Machines
Leaking water, does not close
I had the same problem with the nespresso krups xn20 machine. After calling the Nespresso service desk they substituted free of charge the water tank, which has a little valve with seal at the bottom. It turned out that the problem was not the seal of the water tank, but the seal of the machine (onto which the water tank is installed).
I solved the problem by using Teflon tape (same type as that used to connect for water pipes) on the water tank, applying it at the appendix which goes into the machine.
It's been working ok since then (couple of days). The only problem could be the wearing-off of the tape after some time (you will have to reapply it).
Apr 17, 2008 | Nespresso C100B Essenza Single-Serve...
Krups XP7260 Espresso Machine Logo
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
