Question about Brother MFC7360N AllInOne Laser Printer
Replace toner error shows on brother mfc-7360
5 Suggested Answers
  • 3 Answers
SOURCE: New Ink Cartridge
Is the toner cartridge an original Brother or is it remanufactured? The toner cartridge for this model is the TN-350, which has a "flag gear" on the left (gear) side. It is a little plastic piece that sticks out on the new cartridges and, after putting the cartridge in for the first time, it rotates out of the way. This is how the printer knows that the cartridge is new. Some remanufacturers either don't put the flag gear in or they forget to turn it back to the original position when they build the cartridge. So that would be the first thing I would look at.
Posted on Jan 18, 2008
SOURCE: I have MFC-7340 Brother Printer but I have
Open the front cover.
Press the clear/back button.
It'll ask if you want to replace the drum, but ignore that and just press *11 quickly. It should say "Accepted" on the LCD. Close the cover and it should work.
Posted on Apr 06, 2011
Samyfam
  • 379 Answers
SOURCE: Brother MFC-465CN printer. Need a fix for error 46.
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Posted on Jul 12, 2010
SOURCE: Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work. If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear. WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Posted on Sep 08, 2010
How to fix faded copying on brother mfc7360
Gradual fading, going from dark to light or vice versa, is usually caused by unequal toner distribution. Just remove the toner cartridge and shake it by rotating 45 degrees to one side along its axis and then back to zero and then the other direction. It's ok for the cartridge to leak a little amount of toner, so it's recommended to use plastic gloves and do it over an old newspaper to avoid smearing toner all over.
Oct 23, 2016 | Brother Mfc-7360
Error ef brother mfc 7360
Irregular power supply is detected, replace LV PSU or Main PCB assy
Oct 19, 2015 | Brother Office Equipment & Supplies
How to repair head laser brother 7360
you do not repair them-- just replace
you can reset the error code if needed
Feb 16, 2015 | Brother MFC 7360N - Multifunction fax /...
How to reset brother j125 printer's ink absorber full
Go To Below official brother Printer Page For Your problem http://forum.testcopy.net/threads/how-to-reset-toner-cartridge-reset-counter-for-brother-mfc-7360-printer.1915/ Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
May 04, 2014 | Brother DCP-J125 Inkjet Multifunction...
My Brother MFC-7220 shows the error message "Dust
Try cleaning the drum in the toner cartridge with a soft cloth. If this does not work then a replace toner cartridge is the other solution.
Nov 26, 2010 | Brother MFC-7220 All-In-One Laser Printer
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
Open Questions:
See all Brother MFC7360N AllInOne Laser Printer Questions
Brother MFC7360N AllInOne Laser Printer Logo
1,114 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
