Question about Refrigerators
Need a user manual for fridgemaster mtrf242 fridge freezer
4 Suggested Answers
  • 5 Answers
SOURCE: fridgemaster fridge freezer has just stopped
Out of coolant? Got a leak? May just be liquid in the radiator, switch off, turn it all upside down (emptied) for 30 minutes, then right way up, leave for an hour, then plug it in and switch on to see if it has helped to get fluid in the compressor. Cant hurt, sounds pretty bad really, sorry!
Posted on Mar 12, 2010
  • 4793 Answers
SOURCE: Hi I have a fridgemaster mftr280r and it doesnt
whatever,it cant not help,as long as you do a COMPLETE defrost(leave it for at least 24 hours.then dry out thoroughly.clean any drains/vents then restart as new.let it settle for at least 24 hours then check/refill.fridge is +5C...freezer is -18C,optimum temps...
Posted on Nov 01, 2010
  • 3287 Answers
SOURCE: i have a fridgemaster fridge
The first thing to do is to manually defrost the freezer.
If the defroster circuit has failed, the coil in the freezer that is responsible for cooling will be choked with ice. The air that is drawn into through this coil is restricted by the ice - resulting in rising temperatures in the fridge. The freezer will also eventually have a rising temperature (if it hasn't already started).
The next thing to do is decide whether to call a repairman or attempt the job yourself. The faulty component is likely to be one of the following: defrost terminator, defrost timer or the defrost heating element. Accessing these parts will require some simple tools and testing them (once visible) will require a multimeter and taking readings with power both on and off. If you are not comfortable doing this, please call a technician. There is also the hazard of damaging the cooling lines. Skin exposed to refrigerant gasses can result in instant frostbite - and is very dangerous.
You can put this repair work off if you need to - return power to the fridge and it should run fine until the coil becomes choked with frost and ice again. Repeat as often as needed.
This job is not very difficult for trained people to perform and shouldn't be very expensive - of course, "expensive" is a relative term. I hope this helps!
Posted on Dec 07, 2010
Fridgemaster MS91562FF American Fridge Freezer brand new but the fridge is 15C It needs to be lower? How do i do this?
then call that delivery person and demand it back . but there is a dial in the fridge part to adjust the temp just turn it to a higher number for cooler temp
Jan 10, 2016 | Fridgemaster Refrigerators
Hi.My Name is dr.v.rusu and I have got my Fridgemaster MTRF242 silver,Refregerant:R600 a/52 g.The problems is that recently it stopped keep cool in the top compartiment,-but down freezer is in very go
Cold air from the freezer is used to cool the refrigerator section. There is an air passage between the freezer and the refrigerator. That passage is probably blocked by ice.
You will have to remove some covers inside to find and melt the ice.
Aug 27, 2014 | Refrigerators
Hi I have a fridgemaster mftr280r and it doesnt seem that cold in the fridge,the freezer is a bit over-iced and needs a defrost.Will this help the fridge from becoming cold??
Nov 01, 2010 | Refrigerators
Fridge problem
no sufficient gas.
Feb 17, 2010 | Freezers
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
Refrigerators Logo
411 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
