Question about Hotpoint Refrigerators
Hotpoint rla34 future fridge compressor is running but not getting cold even when I bybass the thermostat
Yes I have tested the thermostat the contact is closed at room temp. not tried it by putting in the freezer to check if it opens, don't think that is necessary as the fridge compressor is running but it is not cooling.
docjohn174
  • 943 Answers
SOURCE: fridgedaire side by side fan working, compressor hot, refridgerator and freezer not cooling
.thanks for your question i would try a hard, to start re lay on it after its cooled down. it might just do the trick. the appliance doc
Posted on Oct 30, 2008
SOURCE: hotpoint future RFA60 Fidge Freezer
I have lost the instruction booklet for my Fridge Freezer RFA60. How do I defrost the freezer?
Posted on Nov 08, 2008
  • 833 Answers
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Posted on Nov 20, 2008
  • 3 Answers
SOURCE: Fridge dont get cold.
If the compressor is running then it could be one of the following:
The compressor isn't pumping properly. The thermosat has failed. It has lost refrigerant or there is a blockage.
Not alot of help I know but without seeing the fridge it's hard to say.
Posted on Feb 23, 2009
mastatech
  • 478 Answers
SOURCE: Replacing fridge thermostat
Should be prtty easy the wires can go either way, and just follow the bulb to install in same position
Posted on Mar 14, 2009
Hotpoint ice diamond RFA52 P freezer ok fridge not cold enough, this is not a frost free and there are no vents in fridge or feezer?
Good day, please check at the back, at the bottom where the compressor is located for the pencil dryer(as in photo). Get a nice firm grip on it just be careful and feel the temp if it's cold or one side is hot and the other side cold the dryer is block. Otherwise feel the thickest pipe running into the compressor it should be cold if the fridge has been running for a while and the thin copper pipe existing the compressor should be hot. If the thin pipe is freezing up with a thick layer of ice and the dryer as some med-temp then there's a gas leak. If the thin copper pipe is very hot and the dryer has no temp then there's a blockage but if the thin copper pipe feels med-temp and the thick copper pipe more or less the same but a bit cooler the compressor is not pumping also feel if the compressor is running. If dryer as a warmth temp and the thin copper pipe is hot and the thick one very cold(when tipping your finger on your tongue and pressing it against the pipe your finger should stick a bit) if all checks out then it's the thermostat switching the compressor off at the rong temp.
Regards
Jun 09, 2016 | Hotpoint Refrigerators
Why is Hotpoint RLA64T Fridge freezing up after new thermostat fitted?
Make sure that the temp probe from the thermostat is located exactly where the old one was. If it had a plastic sleeve on the old one, the new one will need that sleeve. You shouldn't need to calibrate the control if it is the one specified for this model. If it was a generic replacement then possibly it could need some adjustment.
Aug 02, 2014 | Hotpoint Refrigerators
Hotpoint RLA64T fridge freezing up after new thermostat fitted
WHEN U TALK ABOUT THE THERMOSTAT U MEAN THE COLD CONTROL THERMOSTAT OR DEFROST TIMER THERMOSTAT? WHEN UR PROBLEM SOUNDS MORE LIKE THE DEFROST TERMINATOR OR BAD HEATING ELEMENT, LOCATED ON THE FREEZER EVAPORATOR COILS? IF ITS STAYING ON ALL THE TIME U HAVE A DEFROST ISSUE? OR BAD SEALS ON DOOR AND DIRTY COMPRESSOR
My hotpoint fridge RLA34 isnt keep my food cold
you'll cooling coils may be dirty thermostat may be going bad or it might be just a setting worse case a coolant leak requireing a repairman
Jul 30, 2012 | Hotpoint Refrigerators
Fridge not getting as cold as it should,also i can't hear the motor running. Do you think the thermostat has broken down?
No, if you can hear the compressor at the back running and the fridge isn't getting cold then it most likely means there is a leak in the refrigerant system and the gas has leaked out. This is usually terminal as the likely hood of finding the leak then repairing it and replacing the gas can be quite expensive
Mar 21, 2011 | Hotpoint Refrigerators
Hotpoint RLA30s Freezing!
check the ptc overload relay it could have stuck and is supplying power to the compressor all the time even if the thermostat is off,its on the compressor body where the wires go to the compressor
May 11, 2010 | Hotpoint RLA30 Compact Refrigerator
Refrigerator does not get cold. The freezer works fine, but the fridge only gets slightly cool.
normaly the fridge has its own thermostat to keep the tem right, if this thermostat has stoped working it will do one of two things,,, freez every thing up as it wont turn off the compressor or will just stop working as it wont turn on the compressor,,, try turning up the thermostat first,
Nov 19, 2009 | Hotpoint Refrigerators
Thermostat
HI, your intuitions are correct. this is defiantly a thermostat issue here. replacing this defective thermostat will fix this abnormal issue you are having with your unit.
When a unit of this nature cannot control the Coldness level, it is always due to a defective thermostat.
Jul 08, 2009 | Hotpoint Refrigerators
Feb 22, 2009 | Refrigerators
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
