Question about SAMTRON 55V 15" CRT Monitor
SAMSUNG 56V Monitor
Hi all experts, I have the following problem. I have a samsung 56V monitor, when I turn it on with the PC, it does not show anything for about three to five minutes, even the green light doesn't get turned on. After three to five minutes it starts displaying normally. I couldn't understand what is the problem with the monitor and how to overcome. Send me solution as soon as possible. Thanks and regards
My computer monitor is dead after starting onlly green led glows for few seconds after that no rsponce .it happened after tripptng some relay type tripping.
Posted on May 01, 2012
Firstly take the monitor in a backet, and flow a cup or water with surfe.then wash it with pcb. after plug it and enjoy.
Posted on Sep 07, 2007
This is a very common problem on all crts . pls replace the crt base as over a period of time the pins start detoriating resulting in the above mentioned problem also for 56v samsung u could remove the rubber covering provided on the outer side of the c r t neck and the inner side of the crt base . it works
Posted on Aug 16, 2006
  • 105 Answers
If this behavior is relatively consistent, I would suspect the "mains capacitor", an electrolytic cap on the output of the AC bridge. If vibration affects behavior you may have cold solder joint(s) in the SMPS circuit. Knowing what current the monitor is drawing at turn on would be helpful.
Posted on Aug 15, 2006
Samtron 56v pc monitor video background with gray vertical lines
How to Tell If A Computer Monitor Is Going Bad
Computer monitors are designed to work properly for years.
Whether it's from a defective part or power surge, they go bad eventually, and you'll probably know it when it happens.
Look for vertical or horizontal lines across your monitor screen that shouldn't be there.
Time how long it takes for your computer monitor to come out of sleep mode. It shouldn't take more than 5 or 10 seconds for the screen to be fully operational when taken out of sleep mode or turned on after being turned off. If the screen is not operating as quickly as it should, it could be a sign it's getting old.
Read more :
How to Tell If Computer Monitor Is Going Bad eHow
Oct 13, 2015 | Samsung SAMTRON 56E/57E/56V
I have a Problem in vga cable of my Samtron 56V Monitor.. Pls tel me how to replace
connect another cable as follows
1-red
2-green
3-blue
4-gnd
5-gnd
6-red gnd
7-green gnd
8-blue gnd
9-+5v from display card
10-stand by
11-synchronus ground
12-sda
13-hsync
14-vsync
15-scl
the numbers of pin are given
under pin
May 20, 2010 | SAMTRON 55V 15" CRT Monitor
Samsung 56V, difficult to switch on the monitor
check the capacitors inside the monitor, as they may be broken, and they start screen up, just change em and it should kickstart fine
Sep 19, 2009 | SAMTRON 55V 15" CRT Monitor
Samtron 56v monitor control is locked
To unlock your monitor, Press and hold the Menu button for 5 - 10 sec. and the OSD menu should be released.
May 27, 2009 | SAMTRON 55V 15" CRT Monitor
Samsung 56v
Replace 7805 regulator
Jul 16, 2008 | Computers & Internet
Monitor problem
i think the problem is in your monitor and it is not manuall. any part of your monitor might have been damaged ,so get it checked by an hardware expert
Feb 24, 2008 | SAMTRON 55V 15" CRT Monitor
Samtron 56v monitor
HI all,
The problem im facing is, im using a Samsung samtrong 56V monitor, there is horizontal line appearing in the both ends of the monitor screen which gives a mirroring effect. ( for ex: if ya move the cursor on that it will show multiples of cursors displayed in that line only.)
Please suggest me a method to solve this issue. are there any patch avail for this if so please send a link to download.
thanks a lot
Jan 10, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Samtron 56v
change the 5v regulator 7805 which is the supply for microprocesor
Aug 26, 2007 | SAMTRON 55V 15" CRT Monitor
56v-Screen shrinked horizontly
You need to service your monitor. Give it to an authorized service center.
Dec 15, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
558 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
