Question about Maytag Washing Machines
Maytag top washer model no. SAV4655eww manual
Modal number SAV4655eww
rickzilla
  • 706 Answers
SOURCE: I have a maytag top
based on your description..the motor for the timer sounds like it is bad or one of the wires powering it came free of the motor terminal.. Does the dial spin after you start any wash setting? If not then I'd say your timer needs replacing.. Hope that helps
Posted on Aug 31, 2008
  • 163 Answers
SOURCE: maytag parts/repair manual
try repairclinic.com
Posted on Mar 06, 2009
dmftrucker
  • 1922 Answers
SOURCE: how to replace tub seal on Maytag sav4655eww
you need a 1/4" nut driver and a spanner wrench-start by taking 1/4" screw located toward lower part of agitator,its recessed,take it out,then lift out agitator, then mark where your drum is so you get replaced in that location(counter-weights)then take spanner wrench and loosen nut that holds the wash tub and lift out tub,turn tub over and w/rubber mallet driveout old seal,to aid in new seal install lightly lube with vegetable oil(wessonoil-pam cooking spray) and tap seal into place and re-install in reverse order
Posted on Jul 26, 2009
  • 2180 Answers
SOURCE: REMOVAL OF TOP AGITATOR ON MAYTAG WASHER
i believe all you have to do is put you fingers underneath it grab the sides and pull up,that will remove the whole agitator,if you want to change the dogs,pop off the top fabric softener dispenser and take out the 7/16 bolt and remove middle section,change your parts and put it back the same way you took it apart
Posted on Nov 03, 2009
Testimonial: "Super fast and accurate info. Thanks so very much."
FAV6800AWDIY
  • 526 Answers
SOURCE: maytag washer top load neptune
See this post for troubleshooting the Lr error code. . http://www.fixya.com/support/t2419091-maytag_neptune_top_load_fav6800aww_tub
Lr is locked rotor. My first thought was that this could be a Motor Controller issue. This owner replaced tried that and it did not resolve the issue. He then replaced the main Control Board and that fixed his machine. Without known good parts (Control Board Motor Controller) this might be difficult for a DIY fix.
The Service Manual for reference. Sears Parts Direct for reference.
If you are going to try to DIY the repair I will see if I can help……Rich
Posted on Apr 28, 2010
Bravos X. Where is motor drive?
Manuals and Literature - Maytag
https://www.maytag.com/manuals/
MaytagSearch Manuals & Use and Care Guides. Enter your appliance model number to access your Use and Care Guide and any related appliance literature. Use the ...
Bravos X™ Top Load Washer with PowerWash ... - Maytag
www.maytag.com/-[MVWX600XW]-1101158/MVWX600XW/
MaytagBravos X™ Top Load Washer with PowerWash® Cycle. Ratings ... Instructions for unpacking and installing your appliance, including electrical requirements and .
Oct 08, 2015 | Maytag Washing Machines
Where is the model number on maytag quiet plus ii washer
Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
Jun 13, 2013 | Washing Machines
How to replace tub seal on Maytag sav4655eww
Jul 26, 2009 | Maytag Washing Machines
Maytag SAV4655EWW washer doesn't drain
the filter is blocked or a foreign object in pump impellor
Jul 07, 2008 | Maytag Washing Machines
Washing Machines Logo
73 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
