Question about Sony Televison & Video
How do i reset lamp timer on a sony kds60a3000
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: sony grand wega master reset
In my openion, Highly Qualified Sony technician will do this job properly because your TV needs modification in C2 Board.
Posted on Jun 20, 2008
How do I fix?
Probably the replacement lamp is not correctly aligned. HOWEVER, if the band is not on the bottom, but is surrounded (above and below) with good picture, the cause is in the RED color circuitry usually the 'convergence' section. This type of failure is often due to a failing electrolytic capacitor. Repair is problematic and may be in the integrated circuitry.
Jul 23, 2014 | Sylvania Osram Replacement Lamp & Housing...
How to reset the lamp timer for Sony Projector vpl-px32
    Instructions
      • 1 Turn on your Sony projector after replacing the lamp.
      • 2 Press the "Menu" button, go to the "Lamp Setting" option and select "Lamp Timer Reset." The projector should display a confirmation window asking, "Has the Projection Lamp Been Replaced?"
    • 3 Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
    Read more : http://www.ehow.com/how_7196165_reset-sony-projector.html
Jul 07, 2014 | Panasonic PT-44LCX65 Television
How can you tell if you have a bad lamp or ballast on the Sony DLP KDS60A3000
Remove and examine lamp to see if shattered--lamp has a 2,000 hour lifespan and may look good--if it fails the lamp light on sets front should light.
A ballast is harder to call--can check the approx 300 volts from the power supply to see if it shows at ballast.
Video instructions for lamp replacement are by model number available on You Tube for most sets.
Apr 03, 2012 | Sony KDS-60A3000 60" HDTV
HOW DO I RESET THE LAMP TIMER ON A SONY KDF55WF655
Procedure for resetting your lamp timer,
Use the Remote Commander to put the set into service mode to display the service menus.
1. TV must be in standby mode (Power off).
2. Press the following buttons on the Remote commander within a second of each other: DISPLAY ==> Channel 5 ==> Volume + ==> POWER. The first service menu (TV) displays.
To reset the Lamp Timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Jun 30, 2011 | Sony Televison & Video
I replaced my sony kds60a3000 lamp 2 1/2 weeks ago. The lamp at that time was blown. I replaced it and the TV worked right after installing it. Now two days ago I try to turn on the TV and its doing the...
If you touched the glass lens part in the front of the lamp will you were installing it, it will burn the lamp and screw up. If you did do this you may need a new lamp. Sorry but thats about all you can do.
Jan 03, 2011 | Sony KDS-60A3000 60" HDTV
I have a sony kds60a3000 projectin tv. when i turn the tv on there is a message that says "your projection lamp is nearing the end of it's life." Should I order a new one now? how long do you think it...
You should order a new one and wait for the other one to **** out first. The automatic message is to make Sony more money.
Shop around on the web for the lamp.
Some places are 2-3X more than others
Oct 04, 2010 | Sony LAMP BLOCK XL2100U Projector Lamp
How to reset lamp counter in Sony-VPL-ES3
To reset lamp timer in Sony VPL-ES3,
Press following keys on the remote control in following order for less than 5 seconds each,
RESET, <<, >>, ENTER
This will reset lamp timer.
Nov 26, 2009 | Sony VPL-ES3 Multimedia Projector
TV(KDS60A3000) not turning on.
sounds like you need a new lamp
Sep 09, 2009 | Sony KDS-60A3000 60" HDTV
Sony projector - replacement lamp counter
  • Set the projector in standby mode.
  • Press the following buttons on remote control in following order for less then five seconds each...
  • RESET,
  • ENTER
Lamp timer is reset now.
This is also mentioned in user manual page 50
Thank you.
Dec 12, 2008 | Sony LMP-H130 Projector Lamp Projector...
Replacing the projection lamp
Try resseting the lamp timer following the info below: Procedure for resetting the KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655 or KDF60XS955 lamp timer:
Dec 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Televison & Video Logo
222 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
