Toshiba e-studio 352 error C450 - Office Equipment & Supplies
Bubbabear64
  • 2794 Answers
SOURCE: scan to email
Go into the administration mode. Select network settings. Change your outgoing or SMTP e-mail server to the new source you are using.
Posted on Jun 30, 2008
  • 628 Answers
SOURCE: our Toshiba e-studio 352 is leaving a black line
If u copy through feeder, then probably is the scanning mirror dirty. If u encounter this problem when printing from pc, then probably is process unit or t/s block problem.
Posted on Jun 05, 2010
  • 30 Answers
SOURCE: I got a C440 error code sub code "7" with Toshiba
Hi how are you this is jack ...(jack_pak@hotmail.com)..
Dear follow the procedure
[C440] Fuser abnormality after abnormality judment.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
please vote me.
Thanks
Best Regards,
Posted on Aug 14, 2010
  • 79 Answers
SOURCE: toshiba studio 352 dispose of used toner
The waste toner bottle is located behind the front cover, you should be able to open the cover and remove the clear plastic container. After emptying the container, you need to make sure that the portion of the container that comes in contact with the sensor on the machine side is clear of any toner, as the sensor sends a beam of light through it to determine if the container is full. After doing this, you may need to reset the machine.
-David.
Posted on Oct 30, 2010
djuksoni
  • 103 Answers
SOURCE: Error code c440. call for
Fuser unit error code, need to replace fuser unit
BR
Posted on Feb 12, 2011
My Toshiba e studio 352, when i copyed 200-300 pages then suddenly error occour e 010 then the machine does not copy a single page, cooling/stop machine 10 or 20 minute then i start copying again
sounds like it got a bit hot
tray holds 500 pages doesnt mean it can copy 500 in one session of copying time
Toshiba Studio 352 Copier Studio352
cant see it but
I was looking at the specs to see how many copies per hour it is rated
Jul 03, 2016 | Toshiba Office Equipment & Supplies
Toshiba estudio-352 "can't find HDD data" error
go to toshiba website and look for tech support and email the question to them they should get back to you asap.
Dec 26, 2012 | Toshiba e-STUDIO 352 Black and White...
How to replaced developer in toshiba e studio-352 will i had try with 200 but still machine value is showing error
After replaced the developer material, u need to perform auto toner adjustment 05-200 ( take out the toner )
Dec 03, 2012 | Toshiba e-STUDIO 352 Black and White...
TOSHIBA E-STUDIO 352 ERRO E550
It might be due to sensor faulty. Perform following input test.
Registration sensor 03-[FAX]ON/[2]/[A]
Upper drawer feed sensor 03-[FAX]OFF/[6]/[E]
Exit area Jam access cover Exit sensor 03-[FAX]ON/[2]/[B]
May 22, 2012 | Toshiba e-STUDIO 352 Black and White...
What does error code e010 indicate on the Toshiba e-Studio 352 series black and white copier?
open the side door >> you find any paper?? remove it
else you need to change the jamming sensor
May 09, 2011 | Toshiba e-STUDIO 352 Black and White...
Power Failure in viewer. Paper now jamming also. Toshiba e-studio 352
double press the fc button the machine cannot be switvhed off at the power switch it must be shut down press energy save button and shut down what paper jam error codes does the machine give
Feb 17, 2011 | Toshiba e-STUDIO 352 Black and White...
915 people viewed this question
jasbo
jasbo
