Manual for samsung ht d455 home cinema system
SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Posted on Nov 26, 2008
SOURCE: dvd multiregion unlock code
Perfectly it work on the SAMSUNG HT X40
Posted on Oct 18, 2008
ginko
  • 19396 Answers
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
rylee_smith
  • 8619 Answers
SOURCE: I need to reset the region code on a samsung home
Hi
Thanks for using FixYa. Please follow this procedure to reset the region code (or to make it region free).
Open tray and remove any disks in tray, then Close the tray. 1. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM) 2. Reconnect to mains 3. Turn on player with remote. 4. Press ENTER on remote. 5. Press 8, 4, 2, 6, 9. Using keys on remote.if your player is already set to region 2 6. Press ENTER on remote. (The tray will open and player will power off and close tray.) 7. Switch on power from remote. 8. Player is now Region Free. Allows both region 1 & 2 DVD's to play.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 15, 2009
  • 5 Answers
SOURCE: when i turn samsung HT-TZ212 home cinema system on
Hi , your amp board need to replace , get one from ebay.
Posted on Apr 04, 2010
Samsung Home cinema HT-TXQ120 system won't read CDs and DVDs.
Hi.
I have had the same problem.
Just unplug the systme and plug it back in.
Jan 03, 2010 | Samsung HTP-1200 System
Samsung hiome cinema protect error message
you need to change 5q tranzistor.if you dont have short circuit on pin 9 to ground on flat who comes from amplifier
Aug 04, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Mar 18, 2009 | Samsung HT-A100T Theater System
Samsung HT-A100 Home Cinema system remote interferes with tv!
Some remotes have facility for changing frequency to avoid conflict. Check yours out for this feature.
Aug 29, 2017 | Samsung HT-A100T Theater System
Feb 02, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
70 people viewed this question
 Grubhead
Grubhead
