Question about Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher dishwasher runs but no water enters tub - dishwasher runs all the time and does not turn off
  • 2 more comments
  • etbaer Nov 15, 2008
    Dishwasher makes a noise when turned on. No water enters. Must be manually shut off. Both arms able to swing freely and are not dirtry.
  • kdlav Nov 16, 2008
    Dishwasher will not stop running. If I reset and start over it will run but no water goes in and the cycle will not stop
  • debnlar Nov 26, 2008
    Cycle time will not change, dishwasher runs but no water cycles.
  • Smgood1 Nov 28, 2008
Rotu
  • 175 Answers
SOURCE: Bosch dishwasher SHU9922UC
Sounds like you already know how to fix it. The inlet valve is only held closed by water pressure...if you have low water pressure it could be causing this. Its more likely just a bad fill valve though. The water inlet valve is accessed by removinf the lower kickplate and the sheild behind that. Then all you have to do is remove the water line from the valve, remove the 2 screws holding it and pull it out far enough to disconnect the 2(possibly 3) wires and the fill hose. Make sure to mark where your wires go, if you hook it up wrong it could continue to fill and overflow. Hope this helps!
Posted on Feb 02, 2007
SOURCE: No water in dishwasher
I have a SHU9922UC and the control panel has just died for the third time in 10 months. Its symptom is a dishwasher that runs and runs but never fills. I was told that this is an issue with this model. When they pull the control panel you can see a "burnt" area on the board. at $150 a repair, I'm getting a new dishwasher. It works great until the control panel wigs out.
Posted on Apr 06, 2007
SolutionGuy
  • 331 Answers
SOURCE: bosch dishwasher motor keeps running no water
Hola Lewis!
This is such an easy repair, you'll be shocked and surprised! The reason this is happening is that the computer or timer has detected a "flood" condition and has permanently energized the drain pump to clear the "flood".
What you'll need to fix it...
1.) Shop-Vac (for vacuuming water) with a crevice tool (like one of these)
2.) T20 Torx bit with a driver. Torx sizing here. (You can get a set at Home Depot or Lowes)
All you gotta do now is get down on the floor and remove the kick panel. Then remove the screws holding the water valve and lift it up out of its' plastic holding. Now your shop-vac w/ crevice tool can be used. Stick the crevice tool in there (about 10") and vacuum up all the water that's been trapped in the basin. (you may need a flashlight to see what's going on back in there...) After the water is gone, your DW will work fine.
Here's how it works... About 10" behind the inlet valve is a "float" made of styrofoam. When water gets into the basin, the float rises and eventually trips a "flood condition" switch. This switch shuts the unit down and will only allow the drain pump to operate. So what you want to do is get the water out of the basin.
There may be a reason for the basin flooding, though. Suds (caused by too much (or the wrong) detergent), an actual water leak from the valve, etc... So after you get the water out of there and the unit is working again, you may want to monitor it (like, only run it when someone is home) for a while just to make sure that a real flood does not occur.
Hope this helps.
SG
Posted on Mar 23, 2009
  • 205 Answers
SOURCE: Bosch dishwasher: won't fill with water
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Posted on Jul 21, 2009
Macmarkus
  • 2605 Answers
SOURCE: bosch shu9915uc dishwasher when turned
Welcome to FixYa.
Based on your description "dishwasher when turned on sounds like drain pump is running but water will not enter dishwasher" , it sounds like the emergency overfill switch has been actuated. Here`s what to do and what to look for.
**Turn off the breaker/power at your homes service panel...safety first of course**
Remove the the bottom panel, referred to as a toe panel or kick-plate, essentially the lower service panel shown here...
When you remove the outer toe panel, there will be another small panel which is non finished steel, I find removing that allows much easier access as well.
This panel can be somewhat more difficult as it secures the plastic channeling for the wires but if you observe closely you`ll see it does "snap" out of place...carefully.
Once the panel has been removed check for any obvious signs of water in the base ( the unit has a plastic overfill basin with a float which will actuate an emergency overfill cycle, hence the drain pump runs & runs )
If you don`t see any water in this area, direct your attention to the left in this basin/bottom ( from the front to be sure ) and you should see a device which will resemble a "stir stick" you`d use for coffee etc. it will be a red in color stick.
With the aid of a wooden spoon, long screwdriver, or if you can manage to reach by hand, lift it up and down gently and listen for a "click".
If there is no sign of water and you can here the "click" when lifting up and down the float actuater ( red stick ) then turn the machine back on and give it a try before reassembling the toe panel so you can observe for any possible leaks.
Let me know what you find. This is the most likely cause of the symptom you are describing so we can move forward if this doesn`t resolve the issue.
Thanks for choosing FixYa. Good luck.
Regards,
Macmarkus :)
Posted on Dec 30, 2010
I'm getting an E:15 on my new Bosch dishwasher and nothing works, how do I fix it?
E15 means that water has gotten into the base pan below the dishwasher and it is now in flood mode. You've probably noticed that the drain pump will run all the time now as well. What that means is that water has worked it's way down into the base pan below the dishwasher tub causing the unit to do nothing but drain. This is normally caused by the drain being clogged or too many suds in the tub causing the tub to overflow a bit. Either way, you'll need to uninstall the dishwasher and tip it forward at a 45 degree angle to drain the water out of the base pan. Be sure to put a towel under the dishwasher first so that the water is soaked up in the towel instead of going all over the floor. Once you've drained all the water out of the base pan, reinstall the dishwasher and pour a gallon of water in the dishwasher. If it drains it out right away and doesn't wash or refill, you still have water left in the base pan to try again, otherwise you're good to go.
Now if you don't want to do all this work just to get your dishwasher working again and you have time, let the dishwasher just sit unused for a week and the water in the base pan will evaporate as time goes on and the dishwasher will start working again after a week.
Sep 23, 2017 | Bosch Dishwashers
BOSCH SGS44E12EU/71 DISHWASHER LEAKING WATER INTO TUB
see this causes:
Main tub seal
if your machine is mounted horizontally the pump must be replace.
but if you have vertical machine follow this step:remove the lower rack+spray arms+spray arms support+wash /drain impeller see the diagram, then replace the seal.
Door gasket or seal
replace
Water-inlet valve
water inlet valve, leaking , replace.
Hoses
replace the clamps+hoses.
see the diagrams.
God bless you
Jul 11, 2012 | Dishwashers
Our SHE33M02UC dishwasher won't stop pumping and won't continue to the drying part of the cycle.
Hello Frank,
The reason the pump continues to run and no other function will work is because the flood leak detecter has been tripped and thusly their is water in the base frame and until time their is no more water in the base frame the pump will keep running. The things that could cause water to be in the base are;Oversuddings so suds have entered base a drain problem so to much water was in tub causing some of it to enter from vent into tuba leak in any of the components or hoses in the basea overfill so again water entered the base through the vent
In an case the service panel below the main door panel can be removed and water sopped up with rags/towels/sponges ect and when water is out the dishwasher will operate normally.....if soon it only starts pumping only the reason why water is in the base would need to be determined
Good luck,GENE
Sep 25, 2011 | Bosch Evolution 300 SHE33M02UC Built-in...
No water in the dishwasher Bosch SHX43M02-48. We turned of the water and forgot to turn it back on and ran the dishwasher. Now the it will not let water in?
Hi, By the information you've supplied, I'd guess you burnt out the coil in the water/fill valve by running it without a water supply to the valve. Are there any other unusual symptom's or error codes ? i.e. drain pump running none stop ? Can you put water into the tub manually and run a rinse cycle without issue ? In any event the valve is pretty inexpensive, usually about $30 or so. The part # 425458 works on all bosch, thermador, gaggenau, and siemens dishwasher built since the early to mid 90's up to present day. Hope this was helpful to you. Thanks for visiting "fixya" today. Good luck. macmarkus :)
Mar 05, 2010 | Bosch Dishwashers
I accidently put Jet Dry DISHWASHER CLEANER in my rinse agent dispenser and I need to know how to drain it out..help!
if you leave loading draw or lid open and do a hot wash with no detergent water will enter replacing the detergent you will have to do this several times till wash tub runs with clear water then refill with rinse agent.
Feb 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Water is turned on but will not cycle through washer
check the float inside the tub. make sure that it is all the way down or no water will enter the dishwasher. also when you turn it on do you hear a humming? if yes then it is your inlet valve.
Oct 18, 2009 | Bosch 24 in. SHU68 Built-in Dishwasher
Dishwasher tub slowly fills with water after after completion
the internal parts of the valve are sticking open randomley.the diaphram/piston in the valve most likley have lime deposits on it due to poor water quality.you would need the water valve assembly but before you buy this part i would look where the water line goes into the dishwasher and it will lead you to the valve.remove the valve from the unit and disassemble the valve.clean all the internal parts in the valve and reinstall.75% of the time this works ,if not change the valve.
Jan 24, 2008 | Dishwashers
Bosch 24 in. SHU53 Built-in Dishwasher Logo
21 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
