Question about GE Security Simon 3 Wireless Home Security System
New Home, existing system, no information on what current access code is
My wife and I just bought a home that was foreclosed on. When escro closed we received one key and one garage door opener and nothing else. This was fine and dandy until the alarm system was accidentally activated. The Alarm system is a GE Simon 3 Security system.
Is there any way to do a hard reset on the system so that we can enter a new access code or reset it to a factory default code or something? I'm about ready to take a hammer to the thing just so we can open windows and doors again without fear of setting off our own security system
  • rerescue Nov 08, 2008
    Same issue! Wish someone could answer it.
  • rdailey Nov 30, 2008
    Thanks Jane Deaux. I think I responded to your solution on another post as well. I have managed to figure out how to shut down the system. But I still can't get it to a point where I can enter a new access code. My system's main power does appear to be in some inconspicuous place. At any rate, I removed the main power by detaching the incoming power lines from the main board itself. They were attached using screws, so removing them was not an issue. I also detached the system battery as well. I will leave it detached for a few days to make absolutely sure that I just didn't leave it detached long enough, but leaving it detached from all power for 10 hours didn't seem to do it.
    There are two unused plugs on main board, one is a 4 pin plug and the other is a 5 pin plug. Are either of these used for gaining access to system settings or for resetting the system (ie such as jumpering certain pins?)
    Incidentally, for anyone else who is just trying to get a quick fix to the alarm going off without destroying it, you can unplug the alarm speaker from the main board. This does not disarm the system, but rather, just mutes it for you.
    Problem Solver:
  • 6 Answers
Powering down for several hours should reset the code to 1234.
To power down, find where it plugs into the wall. It'll be a big plug, about the size of your fist ( a three-inch, block style plug), black, white or beige in color, probably a little screw holding it in. It may be directly below the panel or could be in the room on the other side of the wall of the panel. Otherwise, it may be in a garage, basement or attic. It may be in a weird place, like behind a couch in the living room or on the ceiling in the garage. Good luck finding it!
Next, disconnect the back up battery. This can be tricky because it's really easy to break the little tab that holds the compartment shut. With the cover open, look at the top of the panel or the sides/corners. CAREFULLY push the tab, open the cover and disconnect the battery.
Leave it powered down for 24 hours and then plug in the battery first, then plug it into the wall. The code should (hopefully) be 1234 now.
Posted on Nov 20, 2008
MAKING A SAMSUNG HT-F6500W REGION-FREE
1) Switch Player off then On (this is to clean-boot firmware).
2) Wait until main menu appears
3) Open Disc Tray and Close Disc Tray (May not be necessary)
4) As soon as "No Disc" is displayed quickly press REPEAT on
remote quickly use the following code for your current
region:
Region 1: Press - 2,9,3,3,4
Region 2: Press - 5,7,5,3,8
Region 3: Press - 5,6,7,3,2
Region 4: Press - 7,6,8,8,4
Region 5: Press - 5,3,8,1,4
Region 6: Press - 2,4,4,6,2
5) Your current Region will appear in the top-right corner
6) Quickly Press "9" before it disappears (It should replace
the code with a "9" in the corner)
7) Switch Player Off and then On again.
Note that REPEAT is part of the code so one smooth press of
6 keys is required.
There isn`t currently a region hack for Blue-Ray Disks
Dec 27, 2013 | Samsung HT-F6500W/ZA Home Theater System -...
Home and business shutdown
If you have a bootable CD or DVD drive in your computer, download a copy of Hiren's BootCD, or Parted Magic, and boot to that operating system. Then you could copy the files off to another drive such as a flash drive or external hard drive.
May 08, 2017 | Intuit Quicken 2008 Home & Business Full...
Bought a foreclosed home with an ademco 6510pl3 keypad. No manuals left and no code. Is it possible to reset? I don't want to have it monitored, waste of money with all the false alarm fines.
This thing can't be reset,must have the original codes to used the system.Cancel the monitored service,when u all set to move in or sale it.Have to put in a new alarm system.
Jan 14, 2011 | Ademco 1 Ademco 6150 6150pl3 6150pl2...
How do i fix error code 20100
Code 20100 means the Wii is having connection problems with your WiFi. Nintendo says:
Error Code: 20100
  • There could be a temporary issue with the Nintendo Wi-Fi Connection servers. Please wait a few hours and try again.
  • If after waiting a few hours and the problem has not resolved, there could be a problem with your home connection. Try the following:
    1. Ensure your home internet connection is working properly. Use a PC that is attached to your home router and visit a website that you have not been to before, in order to check that the connection is currently working.
    2. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase stability. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
    3. Within the Wii's system settings, erase the current connection file you use to connect your Wii online, and set up a new one. To do this, access the "Internet" option from the Wii settings. For step-by-step instructions, click here.
    If you are still receiving this error code after waiting a few hours and trying the steps above, please call 1-800-255-3700 for assistance.
Dec 01, 2010 | Nintendo Wii Console
How do i change my home page? i want it to gateway
hi
Internet Explorer for Windows
1. Browse normally to the web page you want as your home page.
2. Pull down the "Tools" menu of Internet Explorer.
3. Select "Internet Options."
4. The "General" tab appears.
5. You'll see the "Home page" box at the top.
6. Click the "Use Current" button in that box.
7. Click "OK." \
8. Close and open Internet Explorer. You should see your new home page.
Firefox for any operating system Changing your home page in Firefox is easy. Just follow these steps:
2. Pull down the "Tools" menu of Firefox.
3. Select "Options."
4. Click on the "General" tab, if it is not the first to appear.
5. You'll see the "Home Page" box at the top.
6. Click the "Use Current Page" button in that box.
7. Click "OK."
8. Close and open Firefox. You should see your new home page.
Safari for MacOS X
Changing your home page in Safari isn't tough either:
2. Pull down the "Safari" menu.
3. Select "Preferences."
4. Click on the "General" tab.
5. Note the "Home page:" field and the "Set to Current Page" button beneath it.
6. Click "Set to Current Page."
7. Click the red "close" button in the upper left corner of the preferences dialog.
8. Close and open Safari. You should see your new home page.
Opera
Opera changes the home page in pretty much the same way as the rest:
2. Pull down the "Tools" menu.
3. Select "Preferences..."
4. The "Preferences" dialog box appears. Click on the "General" tab.
5. Note the "Home page" field and the "Use Current" button to the right of it.
6. Click "Use Current."
7. Click "OK."
vote me if you have your solution
Oct 25, 2010 | Computers & Internet
Unable to access my Facebook Home page
I think this is due to cookies. Google Chrome options - 1. Click on "Tools" (Spanner in the right corner under the close page X) 2. Click on "options" (11th option down) 3. Click "under the bonnet" 4. Click "content settings" 5. Keep on the cookies section. Make sure it's on "allow local data......" Click "Exceptions" 6. Type in the facebook ULR 7. Do the same (click exceptions) for all of the others BUT NOT POP UPS!!!
Hope I helped Dr Reed
Mar 22, 2010 | Facebook Social Network
About 80 volts AC is passing to ground and is on
Check the ground wire on the electrical outlet. You can get a simple outlet tester for $10 or so. Here's one at Ace Hardware for $12.
When we bought our current house, the electrician failed to connect the ground wire to two of the outlets in the basement, and the induced current was about 80VAC on the ground.
If this helps, be sure to hit the "Thumbs up" for me!
Jan 24, 2010 | Philips HTS3544/37 Theater System
New house, existing Simon3. How to access to add new sensors
Go to the GE Security website, register and download the installation manual. Heres the link:
https://portal.gesecurity.com/portal/login/login.jsp?TYPE=33554432&REALMOID=06-0008ce40-a18c-1536-85ea-8312f762000e&GUID=&SMAUTHREASON=0&METHOD=GET&SMAGENTNAME=$SM$wqmXYZlDF%2bp9wEfLtfJfgbvvO8xuG0aMyW%2fdUiDGhFTao1t%2b10TkWhV0hWcBh7VC&TARGET=$SM$https%3a%2f%2fportal.gesecurity.com%2fportal%2fmdme%2fDownload.jsp%3fID%3d320%26DID%3d320%26documenttype%3dInstallation$%20Instructions
The master codes are in the manual.
Or google "Simon 3 access code" or "Simon 3 ADT code" or such...
Jun 12, 2009 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
462 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
