Question about Hitachi 53UDX10B 53" Rear Projection Television
Convergence I have a weird problem on my hands. First I tried magic focus but it would not go past red and displayed a number 4 in the corner. Then I went into manual convergence and I noticed that red and blue would not move. After researching on the internet I found out that the most likely culprit was the convergence ICs. I bought 2 new ICs and installed them and when I turned on the TV the power LED started blinking. I removed the new ICs and replaced it with the old defective ones and the TV turned on with the same convergence problem. All resisters and so on look fine and tested good with a multimeter. Any help is greatly appreciated.
    President:
  • 3,130 Answers
Your going to need to check the schematic and check the b+ going to the IC's as there maybe a bad capacitor. When the new IC's are installed it loads down the set or power supply. Its the bad power supply or the IC's are defective, but im thinking the power supply.
Posted on Aug 13, 2006
My TV is the Hitachi model 51UWX20B and tried using magic focus to line up red color. Picture looks like 3D with red off center. When using magic focus it gets to the red phase and it shows the number 5...
You need to replace the STK ICs which are Convergence ICs STK392-110 use 120s or 150s
also check the small ohm resistors around ICs . They are Big Black ICs and will have part number on them ,should be located on the Right hand side of Chassis .
Mats Eletronics has Parts 1-800-628-1118 Convergence IC Kit.
Jul 04, 2011 | Hitachi 51UWX20B 51" Rear Projection...
My Hitachi 50UX26B/27K red picture tube seems to be out of line with the blue/green tubes. When I press the magic focus it runs a short 30 second cycle then displays the number 3 in the bottom right hand...
Your convergence is fried go to ebay and order this item number 130475189383 copy n paste and put in ebay search.You will also need a delsolering iron, a soldering iron, some kind of skill soldering and patience.
Jan 18, 2011 | Hitachi 50UX26B/27K 50" Rear Projection...
My hitachi keeps showing red and blue bands. when
Replace your convergence ICs they are big black ICs will have part number on them STK392-110s use 150s better ICs Mats has them 1-800-628-1118 also CK Low ohm reisitors 1.5ohms and up 3.9 ohms
May 09, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Goes through magic focus than in the middle stops and displays #5
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 19, 2010 | Hitachi 46F500 46" Rear Projection...
Colors are not aligned Magic focus ?
The magic focus will stop if there is a bad sensor and or a problem in the convergence circuit.
This set uses two STK-392-110 convergence chips--both along with any of the resistors that protect them need to be replaced and the set adjusted--I have repaired hundreds of these sets----
Confirm model number----and if you go into the customer menu and either red or blue will not move in any or some direction--the chips have to be replaced---LET ME KNOW WHAT YOU FIND AND I CAN GIVE YOU FAIRLY DETAILED INSTRUCTIONS ON WHERE TO GET THE PARTS AND WHAT IS INVOLVED IN THIS REPAIR.
I am here to help people--
REGARDS, SD TECH
Oct 02, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Convergence problem, I think
i think you need a tech .because all the users adjustment were tried.
May 28, 2009 | Hitachi 57F500 57" Rear Projection...
PICTURE PROBLEM
Convergence failure - goto www.tvrepairkits.com to get the parts and instructions to fix it yourself.
Oct 18, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Convergence issue Hitachi HDTV Model #53uwx10ba
you have a sensor problem to start magic focus is the last step in this repair done normally after replace converge outputs did you do this? if so a manual alignment is needed then you may write it into memory if you get a solid green screen after just briefly you have done it wright if you get a red screen after wards you need to try again it will stop on red if all is not well
Oct 08, 2008 | Televison & Video
IMAGES ARE OVERLAID AND NOT IN FOCUS
Here is the schematic diagram. Download all the 13 parts and unzip them using winrar.
The parts you need are listed on page # 50 of the schematic diagram.
You will find the ICs HERE.
Make sure you check the fuses and micro/pico fuse nearby the ICs, as well some crystallized solder joints.
Good Luck.
Mar 16, 2008 | Televison & Video
Out of focus
Rach, if it doesn`t move from green to red to blue in Magic Focus then there is a problem with the convergence IC`s and probably one or more support resisters. These components will have to be replaced, questions? ask away, BMW Rider
Dec 14, 2007 | Hitachi 57F500 57" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
115 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
