Question about Zenith C27A24T 27" TV
Zenith 27 TV - screen jumps and suddenly turns off.
I have an old zentith TV which was working fine. Suddenly one day, the screen starts jumping and vertically the screen comes down and it got turned off. After that I removed the plugs and connected it after 1 hour. It starts running for some time and the same thing happened once again. Now sometimes it keeps steady and runs with no problem for one hour,then gets turned off. some times it doesnot even run after switching it on. Can anyone please advise?
    President:
  • 3,130 Answers
Sounds like you have a vertical failure, and is causing the power supply to shut down. A repair person can probably repair this main board in this set but it will cost more in time and labor to repair. So the right thing to do is replace the entire module. This Zenith was designed to replace the boards completely to shorten down time as well as labor. The board this set needs is a 9-02107 module, and is avail from http://www.partstore.com for 52.44 + shipping. I dont think you should attemp to do this repair by yourself if you have no electronics training or tv training. This is just so you know what you need and get an idea on what this will cost you to repair. Good Luck
Posted on Aug 13, 2006
SOURCE:
Zenith converter box
Unplug everything from the wall-outlets, and from other devices, and then reconnect all the wires.
Also, try a different TV (some newer computer-screens have "TV-input" and/or "HDMI-input" sockets).
May 20, 2014 | Televison & Video
Color red,green and blue is making a circle on the screen
Hello, please replace the PTC resistor. It is positioned at the primary side of mains converter. Best regards, Arpi
Aug 23, 2007 | Zenith B27A11Z 27" TV
Intermittently dead battery
I had the same problem on my jeep, clean and tighten the battery posts an d terminals. I did the that and it stopped.
May 02, 2012 | Cars & Trucks
Hi, I have a 3yr old lexsor 27" lcd suddenly the
maybe the lcd screen is the defect already, lcd tv often use daily has a shorter life span compare to crt tv's. also there's possibility the inverter power supply of lcd screen has defect, or the connector is loosen
Feb 06, 2011 | Televison & Video
Cursor jumps all over the place! Cursor "arrow" shifts to cursor "four-arrrow" then decides to change zoom level all on its own. Cursor disappears, is nowhere on the screen then...
The Touchpad is the cause. Although some work fine for years others jump the the pointer every time you type (or sneeze). You can turn the touchpad off if you have a mouse for the laptop. Otherwise, you might need to exchange/purchase another model laptop.
Oct 15, 2017 | Toshiba Satellite A355-S6930 16.0-Inch...
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
Zenith tv picture jumps after 20-30 min.
the variations of the supply causes that. a verticle stability be checked, specially semiconductors and capacitor changing valuas
Q= CV
Q=IT
THEREFORE
IT=CV=Q AND frequincy = f=i/t
so if I AND T CHANGES CAUSING MOVEMENT OF PICTURE
SO I is for time and T for tempareture
Mar 28, 2009 | Zenith B25A02Z TV
Zenith B27A11Z remote stop working
remove the batteries from remote ,then put im back and then try again
Jan 01, 2008 | Zenith B27A11Z 27" TV
The picture is jumping, sometimes the tv shows three of the picture.
The solder joints on the vertical output IC have cracked. This is a common problem in those sets and resoldering the pins of the vertical outpit IC will cure the problem.
May 28, 2007 | Zenith C27A25 27" TV
Sanyo Flat Screen (DS27910) "Grey" Screen
dont know for sure but i think that the tube is going bad. Have one in my shop doing almost the same thing.Taped on the tube and it does strange things. My tube tester wont test this kind of tube that is in these sets.Not much help but it is a start.
Sep 17, 2006 | Sanyo DS27910 27" TV
Zenith C27A24T 27" TV Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
