Question about Graco Quattro Tour Travel System
Graco Stroller Buckle
A piece of plastic on our strollers buckle snapped off and now it can't latch. Does anyone know where we can get new straps?
  • 1 more comment
  • jen123smith Oct 24, 2008
    http://www.gracobaby.com/store/order/par...
  • caroosh Mar 12, 2009
    The stroller buckle on my Graco stroller is broken. It will not lock. How can I solve this problem?
  • ShopSmart May 22, 2009
    A piece on my buckle broke too. (The piece that inserts into the buckle part) They told me I have to buy the whole seat assembly...b/c the buckle is not removable. However I just slid this (broken) portion of the buckle off the strap. It's so wasteful to buy the whole seat for one little buckle...not to mention that makes for an expensive buckle!!! I'm still working trying this out with Graco Canada. Hopefully a superviosr gets back to me with a better answer or me.
  • 4 Answers
Try
http://myebestbuy.com/allplasticbuckleslist-1.aspx
heaps of them there
Posted on Aug 06, 2010
  • Jurok Mar 22, 2012
    very helpfull , thanks
How can you change the straps on a bugaboo frog seat frame.. they seem to be stitched on and i cannot see a way to replace them
The straps are built in and Bugaboos solution is buy a new seat. The Bugaboo uses the same plastic buckle components as the Mountain Buggy, Mountain Buggy sell these as separate parts. If you want to unpick the buckle end and sew back new buckles thats the most economical solution. YKK the international Zip maker also have similar buckle systems.
May 12, 2011 | Bugaboo Frog - Black Stroller
I have a Graco twin pram The one chair's buckle is broken. Where can I find a new one? I live in the Western Cape, Malmesbury. Thank You. Janine.
I'm the Bugaboo fix it guy but here goes. I'll assume you had no luck with Graco customer service if not check out a Mountain buggy and see if their harness parts are compatible. If so Mountain Buggy do sell them as spare parts and they fit Bugaboo's so may fit your Graco. If that's a no go try a google for YKK and see if they have a local agent. YKK are the largest manufacturer of zips and plastic buckles.
Feb 08, 2011 | Bugaboo Frog - Black Stroller
I have a bugaboo frog pram and i need a replacement buckle (clip)
YKK the worlds biggest zip maker make the buckles. Google your local YKK agent.
Jul 22, 2010 | Bugaboo Frog - Black Stroller
How do you attach a Graco Car seat to a Baby Trend 1304 tw Snap and Go Double stroller?
Depends on which type of Graco it is, check compatibility. Make sure the babies are facing you, they should SNAP right in just as it says and then buckle them in.
May 10, 2010 | Baby Trend Snap-N-Go LX Double Stroller
I need some buckles for the straps on my phil and teds e3
I need the same buckle and just found the original manufacturer. The company is Prym and the buckle is an "overall buckle". Seems that black and white 35mm and 25mm width buckles are available. Check your local haberdashery for it!
Cheers
Martin
Apr 28, 2010 | Phil & Teds E3 - Charcoal Black Jogger...
Can't unbuckle the buckle
Opening the main buckle should be easy - just press in the waist strap clips as shown in the instructions. Any problems could be referred to your local stockist, or with Bebecar U.K. directly on 01692 408807, service@bebecar.co.uk They can provide instructions by e-mail, and other advice.
Oct 31, 2009 | Bebecar Raider AT Stroller
I took off the cover to wash and now I'm trying to figure out how to get straps put back on
This will help if you lay out the chest pieces and all the pieces you removed on the table first. If it helps, snap them together. Then, lay out the pieces with metal prongs that lock into the buckle that goes between your child's legs.
1st pull through the belt adjusting piece through the bottom cover ****.
2nd pull the square release buckle through the second ****, on top of the piece that tightens and releases. This is the piece that you push with your thumb to release the seatbelt.
3rd pull both side seatbelts through the respective side right and left and make sure they are flat.
4th slide on the two pieces with metal prongs on one left and one right seatbelt. Before you do this, ensure that you have put the correct piece on the correct side and that they will latch properly into the buckle. Snap them into the buckle to ensure you have it right.
5th attach the two respective chest clips on one right and one left seatbelt. Snap them together to ensure you have it right.
6th pull the top shoulder seatbelt straps through one of the top cover slits. If you have a newborn, then it will be the bottom **** at the top. If your child has grown, then it will be the top two slits. Ensure both seatbelts are pulled either through the same **** on either side.
7th after you have pulled the shoulder straps through the top slits on the cover, pull them through the slits in the plastic carseat frame. Pull them through until you see them at the rear.
8th attach on their respective sides the shoulder strap at the back of the plastic carseat. There is a big brass metal piece with "hooks" at the top. The shoulder strap has a seatbelt "loop" on one end that can be hooked on. Do this on each respective side and make sure it is secure.
Oct 26, 2009 | Graco Snugride
I have a stroller just like Evenflo Aura Select Stroller - Somerset that one, and i was wondering how you make it so the baby can lay down...
It should have a strap with a buckle to adjust the seat into position by sliding the buckle up or down. Hope this helps.
Jul 05, 2009 | Evenflo Journey Premier Stroller
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Apr 28, 2009 | Baby Trend Expedition LE Jogger
Broken buckle on Urban mountain stoller
might be here
lots of variants
Mar 02, 2009 | Mountain Buggy Urban Single - Red Stroller
Graco Quattro Tour Travel System Logo
1,406 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dorel UK
Dorel UK
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
