Question about Iomega 1TB Home Media Network Hard Drive (34337BN)
How can I defrag an Iomega Store Center ix2 - Iomega 1TB Home Media Network Hard Drive (34337BN)
Red light blinking
One of the hard drives has failed. Replace it.
Apr 08, 2014 | Iomega Storcenter Ix2-200 2 Tb Network...
Red light is fashing iomega storcenter ix2
I am having the same problem. Once I start the storcenter, blue light start flashing and then in a minute or so it changes to red light. The solutions posted earlier are not clear.
Sep 07, 2012 | Iomega StorCenter Computers & Internet
Iomega storcenter ix2-200 hard reset
Please help with this issue.
I can access the drives but cannot access the system webpage and configuration. I am using the same ip address as above but page is not loading. the iomega storage manager is also not working even after updating to the latest version. Please help.
Jan 19, 2012 | Iomega 2TB StorCenter ix2200 2 x 1TB
I have the Iomega ix2 2T iCloud edition and forgot my admin password. How do I access it? (even if I have to reset everything)
At the back of the drvice there is a little reset swtich, located just above the rear usb port. Take a small object (eg. a paperclip) and press the button for 4 seconds. This should reset the password and disable the security.
Aug 13, 2011 | Iomega StorCenter ix2 1000 GB Network...
I have just bought an Iomega Strocenter iX2 but cannot get it to work. I get two white lights on the front panel to show up permanently and from time to time a blue light. The set up software just says...
The IX2 doesn't have white indicator lights. The IX2-200 does which would mean that the device is healthy and ready for use.
Since you are directly connecting it to your imac via ethernet cable which is the only way to connect to the device as the USB's are hubs.
First make sure you computer is getting an APIPA address 169.254.x.x (x represents randomly generated numbers by the computer), do a factory reset (depressing the reset button on the back for 4-5 seconds) which should restart the device, open a Terminal window (Applications -> Utilities -> Terminal) and type (without the quote marks) findsmb and hit enter. You should see your device populated on that list and you should also see an IP address associated with the device. Open an internet browser window and type the devices IP address into the address bar without the "http://" in front. You should have access to the device now.
At this point you will want to statically (manually) setup an IP for your device with your networks subnet. Once you statically set the IP. Disconnect it from your computer and put it on the network.
Good Luck.
Dec 18, 2010 | Iomega StorCenter ix2 1000 GB Network...
Forgotten admin password
you can reset it from the back there is small whole which reset your storage and it will reset your dmin password
Dec 02, 2010 | Iomega StorCenter ix2 1000 GB Network...
I forgot my admin name and password for my iomega ix2
is there any data loss, if i reset the switch on backside.
Oct 10, 2010 | Iomega StorCenter ix2 1000 GB Network...
I have an iomega ix2 store center and yesterday i lost connection to it. i tried rebooting but after the flashing blue light goes away the red light comes on and i cannot connect.
Kate,
What you must do is that firstly, disconnect the printer from the PC. Then go to Start->Control Panel->Add Remove Programs. Select this printer and uninstall it. Reboot. Insert the driver disk into the drive and install the drivers again. Reboot. Now attach the printer to the PC and allow Windows to detect the printer and load its drivers and give you a message in the right bottom corner of the screen "The new HW is installed and is ready for use". Now it will not give any problems. Also read the following link for complete procedure.
Happy Holidays
Installing Devices on PCs and Laptops
Dec 22, 2009 | Office Equipment & Supplies
Iomega 1TB Home Media Network Hard Drive (34337BN) Logo
181 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
