Question about Makita 10" Miter Saw LS1030N
How do you adjust the angle of the miter
I followed the directions on the owners manual and it doesn't want to move. Can you help?
Thanks!!!
  • mags1313 Jan 31, 2009
    how to adjust and fine tune screws.
    Novelist:
  • 99 Answers
It should move if you unscrew the handle at the base of teh table. There is also a lever on most of these saws, under the handle. Unscrew handle, operate lever to release locking pin and move. That's the theory anyway.
Posted on Oct 25, 2008
Bosch Glide Miter Saw get stuck at 45 degree bevel to the left
Adjusting the miter angle involves two cast surfaces sliding against each other. If those surfaces have some irregularities, high spots on the two surfaces will bind against each other. You may have to disassemble the rotating table from the base and do some filing or grinding.
Dec 29, 2013 | Makita Tools 12" Compound Miter Saw -...
HAVE OLD MAKITA 2708 TABLE SAW HOW DO I SQUARE THE BLADE
Hi rjames16,
Are you wanting to square the blade to the rip fence, to the miter fence or does the blade show runout?
To square the rip fence to the blade, lay a combination square or engineer's square along the blade with the short leg against the closest end of the fence and even with the near end of the blade. Slide the square along the blade so that the short leg is even with the far end of the blade. Loosen the lock knob and move the far end of the fence until it touches the leg of the square. Tighten the lock knob. Recheck and adjust the fence until it is perfectly square to the blade.
Adjust the miter fence to the blade in a similar fashion except that the short leg of the square will lay against the miter fence. Adjust until the long leg is aligned with the blade. The instructions for these adjustments are in the owner's manual.
You can download a copy at this website: http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=604
Copy and paste this entire address into your browser and a page will open with 2 Adobe documents. One is for the owner's manual, the other for the parts breakdown.
If you have blade runout, remove it from the saw and lay it flat. Check for warping and if warped, replace it.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 30, 2011 | Saws
My blade is not square to the table i,e if I make a 90deg cut, it is about 1/16 wider at the top of the board than it is at the bottom. I've lost my owners manual and was wowndereing holw I go about...
Set your saw square using a combination square if you have one. Then to to adjust the saw to stay square there should be a gold coloured nut that you can adjust on the right side below the lever you use to unlock the saw when setting what angles you want to cut. Either move it in or out to get the proper setting. Hopefully this answers your question.
Apr 25, 2011 | Makita 10" Dual Bevel Sliding Compound...
Blade does not square up on c10fsh miter saw
To square up a mite saw blade, you need to eeither move the table or adjust it to be square if it is out in the mitre angle, or if it is out in the bevel angle the whole saw head needs to be adjusted, and this is done via the bevel adjustment at the back of the saw. There may be a bevel stop bolt to return the saw back to 90 degrees if moved to a different bevel angle. Usually the blade itself is not adjusted bu either the saw table or the bevel angle of the saw head itself to correct these issues.
Feb 28, 2011 | Hitachi Garden
How do I release the arm of a radial arm saw to cut miters?
Near the blade there should be a clamp that allows the saw head to be tilted to cut an angle miter through the board. The other miter adjustment is a clamp at the top of the post to let the radial arm swing at an angle, this would be used in conjunction with the other adjustment to cut a compound miter. I hope you are not totally confused now.
Jun 09, 2010 | Saws
My saw is really stiff when you try to change the angle .I oiled it but this didn't help. I would like to know how to take it apart but I am un sure how to do it and what is in the boxed off area...
Exploded diagram with parts list for LS1016 10" Dual Slide Compound miter saw is here.
Owner's manual is here. If these aren't quite what you need, you can view other models of Makita miter saws, here.
One thing to bear in mind. There's a miter angle lock and a slide lock on the bottom front of the saw. If you don't have the miter angle lock loose enough, it will be difficult to turn the saw.
If this answer was useful, please vote for it. Thanks!
Apr 14, 2010 | Makita 10" Dual Bevel Sliding Compound...
How do you adjust the saws angle cut? When it is sett at 0 degress it is not making a square cut.
take a framing square sit it on base plate and adjust till its square and level with that angle.works same with table saws also hope that helps ya
Nov 28, 2009 | Hitachi C12LSH 12" Sliding Dual Compound...
Makita chopsaw when cutting angles blade is cutting table
You can adjust the location where the blade drops into the groove in the table. Look on page 24 of this manual and you will see exactly how to adjust the table:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000007351.pdf
Apr 15, 2009 | Makita 10" Miter Saw LS1030N
45 degree cut
Are you having problems with the miter or bevel ? Are you asking how to physically move the saw to that degree angle?
Nov 17, 2008 | Makita 10" Dual Slide Compound Miter Saw...
Makita 10" Miter Saw LS1030N Logo
124 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
