Question about LG Washing Machines
Door error appear on my lg wd 1255rd please help anyone ? could not find manual book
catriver
  • 878 Answers
SOURCE: LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Posted on Aug 14, 2006
  • 1294 Answers
SOURCE: door not opening LG front loader washing machine
Try: Program the select knob at 6 o'clock position. Speed at 9 o'clock. Press pre-wash and the power button together for 4 to 5 seconds. Hopefully it will unlock.
Posted on Sep 30, 2007
SOURCE: LG WD-12331. Front load washer and dryer machine
since it is a washer-dryer, the lint trap is in line with the drain. you have to empty the drain basket. there's an access door on the bottom left, first take the little tube out and drain the remaining water, then open the large drain cap to the right and clean out the trap. once you're done put it all back together and it should work. you're supposed to do this every few months. It was too much for me to deal with so i ended up buying a separate dryer and just use the washer .
Posted on Aug 02, 2008
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Aug 16, 2008
abhishek33
  • 1239 Answers
SOURCE: Message error:E5 with Washer LG- WD-10150FB
HI
The dryer timer, located in back of the control panel, controls several things: the drying time of the clothes in the drum, the flow of electricity to the heating element, and the flow of power to the timer motor and the drum motor in the dryer cabinet.
Timers are driven by synchronous motors. Although the contact part of the timer can be cleaned and adjusted on some dryers, this is a job for a professional repair person. Timer motor repairs should also be handled by a professional, but you can replace a faulty timer yourself. Here's how to test and replace a dryer timer:
Step 1: To access the timer, remove the front of the control panel. On some dryers, the timer can be removed without removing the panel. In either case, pull the timer knob off the shaft and slip off the pointer. The pointer is usually keyed to the shaft by two flat surfaces to keep the pointer from slipping when it's turned.
Step 2: Test the timer with a VOM set to the RX1 scale. Turn the timer to the NORMAL DRY setting and disconnect one of the timer power leads. Some timers may have several wires connected to them: The power leads are usually larger than the other wires, and this size difference can be spotted under close examination. Clip one probe of the meter to each timer terminal. If the meter reads zero, the timer is working. If the needle jumps to a high reading, the timer is faulty and should be replaced. Replace the timer with a new one of the same size and type.
Step 3: To replace the timer, have a helper hold the new timer close to the old one, especially if there are several wires to be changed. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram detailing the proper connections. After all the wires are connected, check the connections again for accuracy........PLEASE RATE IT
Posted on Nov 28, 2008
LG Intellowasher WD-8026C having problems with the door latch, I keep getting an error message. Latch appears not to be connecting and locking the door. to start the machine.
The DE error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly
Jan 31, 2015 | LG Washing Machines
Why does my LG washing machine model WD(M) 16115FD show error code dE?
It appears to be a problem with the door? You can go to the following link and try their troubleshooting, hope it helps. http://www.ehow.com/how_7850983_troubleshoot-de-code-lg-washer.html How to Troubleshoot DE Code for an LG Washer eHow
Aug 10, 2014 | LG WD-16115FD Front Load Washer
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
LG WD 80260 NP washing service manual / circuit diagram
tE is heating error. Water not heating, Could be a faulty element, faulty wiring, faulty temperature sensor or faulty control board.
Jul 07, 2012 | LG Washing Machines
I own an LG WF-TS728PC washing machine top loading. Recently i keep having this problen "dE" error and the manual book says its something to do with the door. I've tried shutting the door close...
Hello
The de error is a door switch error or main board error.
Try unplugging the machine for 3 min and see if it will reset.If not you will need to have the machine serviced.
Apr 15, 2011 | Washing Machines
My aged invalid mother has a front loading LG washer dryer combo and has washed the same garment 3 times and after wash cycle or drying cycle can't seem to get the door to open to remove the clothes. What...
Hi I hope you solved this by now but I thought an answer might be useful if anyone else has the same question. I am not an expert just an owner of a LG WD-1412RD. It sounds like your mum is not aware this is just the normal safety cool down period following drying (as the stainless steel interior gets very hot during drying). The Door lock sign (small red light) is on, and the display shows Cd during this time, then it beeps and the door unlocks by itself. If you need to remove your laundry earlier than this, you can press the START/PAUSE button to end the cycle (it still takes a couple of minutes). This is covered on p 21 - 22 of the owners manual. which can be downloaded from the LG site. http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Nov 28, 2010 | LG WD-14124RD Front Load Washer / Dryer
Error code de
DE is a error code for your door switch. The door is not locking properly. You need to get a new door latch mechanism.
Sgt 48
Mar 29, 2007 | LG WD-1280FHD Front Load Washer
Aug 14, 2006 | LG WD-16115FD Front Load Washer
Washing Machines Logo
124 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
