Question about Poulan Garden
Change blades on Toro ZX440 Timecutter - Poulan Garden
4 Suggested Answers
  • 246 Answers
SOURCE: bought a 2002 toro timecutter 18-52 zero turn lawn
Hello:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, https://lookup3.toro.com/partdex/default.cfm and Select Start Parts Viewer. Now Enter the Model Numbers () and Click Search. Now Select View Assembly Drawings for your Year Model.
At the Bottom of the Page (#6), Use this Link to Locate your Local Toro Dealer who can Order the Manual for you or you can Contact Toro Using the Options at this Site Addy; http://www.toro.com/contact/Homeowner.html .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
huffman49
  • 235 Answers
SOURCE: replace valve guide seals toro zero turn
i don't think those are replacable i may be wrong but i have never replaced valve guides in a small engine about the only thing that can be done is grounding the valve seats and lap the valves into the new seats..good luck
Posted on Apr 14, 2010
mwoodring1
  • 496 Answers
SOURCE: How to replace the RH
have gotten any help on this yet??
M.Woodring
Posted on Jun 21, 2011
Toro timecutter rough idle, backfires, loses power when blades engaged. Spark plug is gapped correctly, have even changed spark plug with no change.
might check the valves to see if they are set correctly and push rods not bent. turn engine over by hand to be sure valves are opening and closing . or check the flywheel key. if it has sheared it will cause it to back fire as the timing will be off.
Jun 12, 2017 | Toro Garden
Timecutter ss5000 loses power
check for rusted or failing bearings on the cutter shafts
Oct 02, 2016 | Toro TimeCutter SS5000 zero turn mower
I jave a toro timecutter z5035 and it starting making a popping noise when running. When blades are engaged the blades turn slow and the engine idles down and then will pick up running for for 30 sec
clean the spark plug or even change it , when you store it you must run it out of gas which means shut the gas off so the gas does not turn into polish that clogs you carb , needle and seat etc ,
Jan 17, 2015 | Toro Garden
Timecutter z4200
If you were able to jump start mower then the problem lies with the battery connections or battery itself
Jul 11, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro timecutter42 blades squealing and won't turn
just had a guy tuesday bring me a zero turn that did the same thing xcept his fell off his trailer ramp and bent one of the blade spindles so now blade digs into cover , engine off blades spin sort of free?
May 07, 2014 | Toro Zero Turn TimeCutter MX Series MX4260...
you have burned out the reel bearings replace them and, always keep them lubricated
Sharping the blades
should be a bolt or two that holds them on
May 16, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Toro timecutter spits and sputters when blades are engaged
Did you drain the fuel before you put it away? If not then you should drain the fuel and clean the carb. Gas when in lawn mowers and any other small gas engine will turn into a slim in a way and will block the carb. Drain the fuel and clean the carb system will run great when that is done
Feb 19, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
26 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
