Question about Canon imageRUNNER 400S Copier
Canon IR 400 Copier Web Roller replace - Canon imageRUNNER 400S Copier
3 Suggested Answers
  • 11 Answers
SOURCE: web roller is loose
u remove u r heater unit and remove web rollar unit then remove web guard plate u get two side rollar type web first fix big size web (u look one iron plate. prees down this plate and fix u r web ) then fix another small size rollar. it fix gear side then u see opposite of gear. one screw is there u tight it web cloth is tight then fix u r web unit in heater unit
Posted on Sep 18, 2008
  • 39 Answers
SOURCE: CANON IR 400 WEB ROLLER HOW IT IS FIXING.I WANT VIDEO FILE
That is a little question with a big answer. You first need to buy a web ($10-$30) and then replace the old one with it. This requires tools and if that appeals to you then I'll write the rest of this response, but it's a dirty job. The only tool you really need is a Phillips #2 screw driver. Else if this doesn't appeal to you then call a copier tech to do the job. Good luck either way.
Posted on Dec 17, 2009
Testimonial: "how to fixing the ir 400 web roller "
Powder spray in first copy only
clean gently the charging roller with cloth or better to replace the charging roller
Sep 18, 2012 | Canon imageRUNNER 400S Copier
Problem is canon ir 400 close the front cover?
its because of composit power supply(hvps) replace it...........
Aug 25, 2012 | Canon imageRUNNER 400S Copier
Erreur e 014 pour ir 400
Fixing unit roller is stuck up. Check the cleaning web roller or the lower pressure bearing. You can spray the bearing with penetrating oil to loosen the rotation of the roller.
Jan 25, 2011 | Canon imageRUNNER 400S Copier
Ir 400 ada kode e064
A Error code E064 deals with the transfer roller unit. I would look to see if the roller feel out of place or I would replace the unit.... Good Luck
Sep 19, 2010 | Canon imageRUNNER 400S Copier
Dec 17, 2009 | Canon imageRUNNER 400S Copier
Plz send me (detail) feachar of cannon 6050 & cannon 400s on this address CHECHANI TELECOM & PHOTO COPIERS C-278, R.K.COLONY,NEAR CHOTI PULIYA, BHILWARA,(RAJ)311001 +919829045797 +919413824797
CANON IR 6050 IS AN ANALOG COPIER.
CANON IR 400 IS A DIGITAL COPIER.IR 400 IS SINGLE SCAN & MULTI PRINTS ,STACKLESS DUPLEX & ITS CAN BE USE PRINTER & FAX ALSO.
FOR MORE DETAILS VISIT WWW.CANON.COM
Mar 15, 2009 | Canon imageRUNNER 400S Copier
How do I fix a broken fixing film
You don't have to fix the fusing film on a Canon IR-400, it dose not have one. It has a upper and lower fixing rollers. But it does have a Cleaning Web and it would show on the display that the web needs to be replaced or it codes out with a E005. Afixxing film is on a IR-200 & IR-210 & IR-2200 & NP- 1625 series
Nov 17, 2008 | Canon imageRUNNER 400S Copier
Ir 400 digital photo copier display could not work
replace the touch screen & lcd. if the problem is same after this effect replace the CPU pcb .
Aug 05, 2008 | Canon imageRUNNER 400S Copier
Web roller is loose
you will need to take the fuser out and remove the top part of the fuser where the web is.
there is a gear in there that fails to advance the web, it may need to be replaced
Dec 11, 2007 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
old marine
old marine
