Question about Street Glow Streetglow Streetglow H894 Headlight Replacement Bulbs
Headlight bulb replacement
How do you replace a headlight bulb on an Ifiniti G35
It's easy to change the bulbs. You don't have to remove the bumper.
To start at the left front, jack up the left front of the car, turn the wheel to the right, remove the plastic plugs and two screws holding the plastic fender liner in place (there are two pieces - loosen the front most piece) and pull it down. You will see the back of the headlight housing. Unscrew the caps and install the new bulbs. Reassemble and repeat on the other side.
Posted on Dec 19, 2008
I have a 2008 g35 infiniti and I replaced headlight bulb on passenger side and still not working. Not even the park lights, help me please
Check that the connecters are sitting tight. Wiggle the wires, you may have a brake. Also look at the contacts where the bulb plugs into. If its rusted, scrap it with a screwdriver until you can see the metal contacts. Make sure the car is off. Good luck!
Apr 27, 2017 | Infiniti Cars & Trucks
Looking for the fuse
no fuse they have a circuit beaker instead and relays
Feb 06, 2010 | 2004 Infiniti G35 Sport Coupe
Top headlight bulbs on both sides do not work any solutions
sounds like the bulbs are burnt out, replace the bulbs and if they dont lite then check the fuses, sometimes the fuse blows when bulbs pop.you should be able to acess from under hood, remove cover, unplug headlight connector then remove clip holding light in, then pull light out,watch position of bulb coming out so that new one is installed the same way. hope this helps.
Dec 21, 2009 | 2005 Infiniti G35
Both of my headlights went out and i replaced the bulbs and checked the fuses. they still dont work. what is the problem?
there is a relay in the fuse panel get a test light check the head light fuse if you dont have power to fuse then its the relay
Dec 06, 2009 | 2005 Infiniti G35
Need to remove headlight 2003 infinity g35 sedan
yes ballast is on the bottom of the headlight capsule. remove and note 4 torx heads
Nov 17, 2009 | 2004 Infiniti G35 Sport Coupe
Running lights
check the light bulbs, and fuses. Fuses are usually found in fuse box under dash in driver side.
Feb 26, 2009 | 2004 Infiniti G35 Sport Coupe
How to replace headlights on 2003 Infiniti G35
Bill you have to take off the front bumper and its easy look at the top of bumper their should be retainers and also on the bottom of vehicle and a blot on each side at fender slide forward and then take the light out that youneed bulb replaced then go backward the same way you took it off
Jan 24, 2009 | Infiniti G35 Cars & Trucks
How do you replace (get to them) the headlights on a 2003 G35. Thank you Bill
http://www.g35nyc.com/forums/showthread.php?t=14495
This is the G37 DIY, but it's the same thing as the G35, as I've replaced my bulbs and my hid ballast before. Being that this entry is in January, I'm sure you've figured it out already.
Jan 24, 2009 | 2006 Infiniti G35
Change a headlight bulb
Need to know how to change a headlight replacement bulb on a 2003 G35 Infinity.
Oct 31, 2008 | 2005 Infiniti G35
Street Glow Streetglow Streetglow H894 Headlight Replacement Bulbs Logo
347 people viewed this question
Top Street Glow Car Audio & Video Experts
xxxxxx xxx
Are you a Street Glow Car Audio and Video Expert? Answer questions, earn points and help others
