Question about Dryers
KENMORE DRYER PART NO 696891
MY DRYER WILL STILL HEAT UP WHEN I TURN IT ON, BUT IT WILL NOT TURN. DO YOU HAVE ANY IDEA WHAT COULD BE THE PROBLEM? IF SO, IS IT SOMETHING I CAN FIX MYSELF? dryer heats but drum doesn't turn on its own,belt seems to be ok and you can hand turn drum and belt
    Scholar:
  • 147 Answers
Take the bottom of the back panel off and you can see the motor and belt pulley. Start the dryer and you will be able to determine the problem. (belt slipping or motor not turning) Dont get you hands near the motor.
Posted on Oct 25, 2008
  • butch welch Oct 25, 2008
    Dont remove front panel, remove bottom of the rear panel.
    Genius:
  • 1,028 Answers
Are you sure belt not broke remove screws under lint screen and pull top up by releasing clips under edge each corner..is motor running ? also belt may have jumped off idler pulley and motor pulley remove front panel to ck
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Kenmore Dryer
What is the model number of your unit?
Nov 26, 2012 | Kenmore Dryers
Kenmore gas dryer no heat, have cleaned all components with shopvac and rags, still no heat, spins and all seems good, geta little warm once out of every 30 times i turn it on, any idea's?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 03, 2011 | Kenmore 73102 Gas Dryer
I just replaced the motor in my Kenmore Series 90 dryer, When I'm running the dryer with no heat it runs as quite as could be expected for a ten year old dryer, When I run with heat the dryer starts making...
It could be possibly your rear roller bearings expanding with heat causing them to not spin as freely? Im not really too sure but its an idea you dont have many moving parts on the unit. Just your idler pulley, blower wheel, and rollers. Hope this helps.
MJ
Feb 14, 2010 | Kenmore 659 Electric Dryer
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Kenmore Dryer 62802 Doesn't Heat
sounds like the heating element has gone south
if you open up the dryer you can check continuity across the element but make sure power is unplugged
Apr 13, 2009 | Kenmore 62802 Electric Dryer
My dryer will not turn off or heat? ideas
Seems you have 2 problems.
1. Bad thermal fuse located on the heat canister on the top left side.
2. Bad heating element. shorted out.
Remove the back panel to access these parts.
Remeber to unplug the dryer.
Mar 10, 2009 | Kenmore Dryers
My dryer keeps breaking the belts for no reason. I am going to take it outside and beat it with a 10 LB sledge hammer and set it on fire!
Sep 27, 2008 | Kenmore 63942 Dryer
Dryers Logo
138 people viewed this question
Top Dryers Experts
