Question about Roper Dryers
When pushing start button, the dryer won't start. It worked great the last load
    Genius:
  • 1,028 Answers
Suspect door switch or thermal fuse located on blower housing behind rear panel on left ..small white object
Posted on Oct 25, 2008
  • 90 Answers
SOURCE: Kenmore dryer won't start
Bad thermal fuse
Posted on Jan 05, 2008
aborcass
  • 2651 Answers
SOURCE: Dryer Won't Start
most common problem with the dryers is blown thermal fuses, something gets too hot and for safety reasons the thermal fuse blows. You can also check your incoming power supply make sure the breakers havent tripped. part num( LA-1053 )about $30 comes with directions to install. its located under main top towards the rear of unit moundted to the side of heater.BE SURE TO TURN OFF ALL POWER BEFORE CHECKING ITS LIVE!!!!!!!!!
Posted on Mar 06, 2008
  • 657 Answers
SOURCE: Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Posted on Mar 13, 2009
SOURCE: Kenmore 600 Series gas dryer
trigger broken dryer will not turn on. I need a replacement. Where can I buy this part.
Posted on Mar 27, 2010
heatman101
  • 43501 Answers
SOURCE: when we push the button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on May 20, 2011
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Another Whirlpool Cabrio Sensing issue
Hi-- none of the solutions I've read here are working. Same problem, dryer not starting, it says "Sensing..." and then "Wet" and does nothing. It worked fine on the last load, except I noticed it read 11 minutes for a very, very long time (I think it got stuck). New load? "Sensing..." etc.
Mar 29, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer won't start all the time. can hand start unit.
hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Feb 17, 2009 | GE DBXR463EBWW Electric Dryer
Nov 02, 2008 | Dryers
Dryers Logo
44 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
