Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Riding mower fails to get gas fast enough to keep it running; floods when off.
That's pretty much it. I cannot fathom how i must have adjusted the richness screw to make it do this... After a few seconds of being off, the 8 horse Briggs & Stratton starts on the first pull. It runs beautifully for a short time--till it uses all the gas that has trickled in from the tank. I left it over night and the whole gas tank had emptied into the chamber--albeit too slowly to have kept it running when I wanted to cut my grass.
  • 48 Answers
Sounds like you better check your oil level to make sure this engine isnt overfull now with fuel - if your tank drained, the needle and seat may be bad or else the brass float is bad - get back to me and well get it running right
Posted on Oct 24, 2008
Hard stating flooding
Search Results
    Rider mower carburetor flooding - help ! - YouTube
    ? 1:30
    https://www.youtube.com/watch?v=ZYqtKvLXYtY
    Sep 29, 2010 - Uploaded by Joyce Boncal
    It won't start. ... Rider mower carburetor flooding - help ! .... ( HOW TO ADJUST VALVES) FIX HARD TO START Lawn Tractorwith OHV Briggs ...
    How to stop a Briggs crankcase from flooding with gas Order ...
    ? 11:34
    https://www.youtube.com/watch?v=VhEiLMtPR5M
    Aug 5, 2013 - Uploaded by doublewide6
    If your tractor keeps leaking gas into the crankcase see how you can fix the problem by ... The hard starting is caused by fuel filling the cylinder.
    Basic Troubleshooting - Lawn & Garden Tractors - Cub Cadet
    cubcadet.custhelp.com/.../basic-troubleshooting---lawn-%26-garden-tract...
    Sep 13, 2002 - Engine fails to start, Engine flooded, Crank engine with throttle in FAST... Engine runs erratic or stalls, Tractor running with CHOKE activated ...
Jan 25, 2016 | Garden
When im riding engine cuts out like im out of gas then dies ,with full tank after a few minutes will restart
Check the fuel filter. If it is mostly clogged, you will get fuel through, but not fast enough to keep going.
If it is pretty old, the fuel lines might be ruined by ethanol in the gas. The inside of the old rubber lines looks like the rubber has melted. New fuel lines are made of material that is resistant to ethanol. Anyway, fuel should flow like water in a pipe. If it is sluggish at all, replace them.
Clean the carburetor. It sounds like the float is not moving right. It runs out of gas and doesn't refill right away. After it sits for a few minutes, it slowly refills, then you can go again for a short time. This is a shot in the dark for this problem, but I have solved 90% of running problems by just doing a quick carburetor cleaning.
Apr 02, 2015 | Garden
John deer flooding out went engaging deck
If this is an older mower that has carburetor adjustments , turn the large needle valve counter clockwise 1/8 of a turn., and see if the mower runs with the deck engaged. If there are no adjustments on the carb. It may need need cleaning, and the gas filter may need to be changed. You can place 1/3 -1/2 can of carb & fuel system cleaner in the gas tank and run the mower. If this does not help, please forward info on the mower - Model #, serial #, and Model/ serial # of engine, which is usually on the ehgine shroud.
Apr 19, 2014 | Garden
Mower cranks with throttle in choke. after cranked and throttle moved to fast or any other position. The mower dies as if someone turns it off??
Ok I assume what you are trying to say is that once it starts with the choke on and you turn the choke off it dies.
This behavior usually means that the engine is leaning out. This means that it is not getting enough gas. Often if you put it back to choke fast enough it will keep running though very roughly.
The problem is the main metering jets are plugged or there is some kind of obstruction in the carburetor. This is assuming of course that the tank is full of gas and the fuel filter is clean.
Aug 17, 2013 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a troy built riding mower it starts up fine , runs 10 or 15 minutes, then it starts spuppering and dies. then it acts like its flooded when you try tostart it again. then the other day while tr
is it starving for gas the gas cap vent could be plugged keeping the fuel from flowing leave the cap loose and run it/are you loosing spark when this happens like the coil is going bad?
May 08, 2012 | Garden
1993 john deere 445 surging and popping down on power won't spin mower deck fast enough to cut grass. seems to be running rich.
sounds like the flote is stuck down in the carb thats causing it to flood up strip card and give it a goofd clean out
its that or the mower deck is sezed up or the blades are rounded off and your stalling the engine trying to turn it and cut grass,, have a look at them as well,,,
Nov 17, 2009 | Garden
Have fuel to carb but engine wont keep running? help
Time to clean out the carburetor. It sounds like the needle valve is not opening, the jet is clogged, or the float is miss adjusted. May have a clogged fuel filter, allowing enough gas to start but not enough flow to keep it going.
Good Day.
Oct 07, 2009 | Garden
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
110 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
