Question about EdgeStar Portable Air Conditioner Heater
Edgestar AP550Z - Noisy, Not Compressor, Flywheel?
My Edgestar AP550Z has been working fine up until last night. It still heats, but when the blower starts and the flywheel begins to turn (not sure of terminology, but it's the black rotating cylindar that can be seen through the vent next to the motor housing at the bottom back of the unit) it becomes extremely noisy.
Looking at the 'flywheel' while operating it appears to be wobbling as it turns, causing it to hit against the side housing of the unit. I can't figure out how to access it to stabilize it again, nor do I know what I would use to stabilize it. I assume there may have been a spacer of some kind on the side of the wheel that may have broken, although I haven't found anything outside the unit that looks like it came from there.
Suggestions on what I can do or what I can use to keep it from wobbling and shut it up? (Last night it would eventually quit banging after a few moments, I assume from finding equilibrium in its spin. Today, no luck on that.)
Please read the problem carefully and address the problem. These reponses fail to do that! The problem is in the balancing of the circulating exhaust fan which is like a hamster wheel lying on its side. Once this begins to make noise, it is due to breakdown completely. This is a problem that should not happen and is built in obsolescence. It needs to be maunufactured stronger.
Posted on Aug 16, 2012
blueextc3221
  • 15935 Answers
SOURCE: THERE'S NOT A PROBLEM I NEED YOUR OPINION
This EdgeStar 10,000 BTU portable air conditioner heats and cools for year round comfort and is recommended for room sizes up to 350 square feet. This slim and light superstar uses the latest technology to squeeze the most powerful cooling from the smallest possible package this 10,000 BTU portable air conditioner has a footprint of just over a square foot and is under 28andquot high! This portable air conditioner is the most powerful portable air conditioner in its class and size range and can bring down mid size rooms faster than competitor's models.
Posted on Dec 27, 2008
SOURCE: edgestar AP550Z won't heat, goes into some sort of alert mode
http://edgestar.com/ownersmanuals/AP550Z_wire-fix.pdf
This could apply to at least one of your units. Apparently these models have had some trouble with the compressor capacitor wires coming loose. If they're barely touching they could cause the compressor to run intermittently and possibly overheat. The compressor runs in heating and cooling mode.
Posted on Dec 12, 2007
SOURCE: edgestar 12,000 portale air conditioner and heater
There are 3 possibilities beginning with the most likely problem
1) If your heater heats up for a few minutes and then quits, chances are there is a blockage in the air flow, check for dust and grime blocking the air intake coarse filter , airgun blow to clear accumulated dust and otherwise clean the coarse filter .
2) If the heater fan blows but there is no warm air, the heating element needs renewal ( this happens very rarely)
3)If the fan stalls and the heater heats up and the thermostat kicks in, then this will be not be a DIY job. This is least likely as you said the air cooler works.
Posted on May 06, 2008
  • 51 Answers
SOURCE: Hello.. I am looking for the bottom squirrel Cage
If you take off the back filter panel, you can look down into the innerds of the unit and you will see the squirrel cage.
Posted on Jul 10, 2010
hvac1960
  • 2133 Answers
SOURCE: when in heat mode unit
Check thermostat setting and also heating sensor.
Posted on Dec 07, 2010
Car stalls when ac or defrost on
Sounds like the compressor is dragging the engine down. The compressor runs in ac and defrost mode. You might try unplugging the compressor to verify.
Jul 21, 2013 | Ford Cars & Trucks
2003 ford taurus heater fan worked fine last night but won't come on at all today.
I do not understand why people will continue to operate a vehicle when they know there is an obvious problem. They ignore check engine lights until the engine stops running altogether and then are "surprised" when they get stranded in the middle of the expressway in rush hour traffic. Then they blame it on the car!!!
In your case, you have ignored the warning signs of your blower motor failing ("making noise for a couple months"?) and now you are dumfounded as to why your blower motor now does not work at all.....I don't get it....!???
REPLACE YOUR BLOWER MOTOR!
Dec 26, 2011 | 2003 Ford Taurus
My ac unit is in the attic is this normal
Do yu mean the compressor unit is in the atticor the indoor blower unit. If its the indoor blower unit thats fine though kinda hard to work on but it keeps the noise down. If its the compressor unit.. Hm mmm Not the best place for it . hard to work on and noisy I'll bet
Aug 09, 2011 | Carrier 38CKC024 Air Conditioner
My A/C was serviced last week and it was fine until last night when the cooling is not enough again
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 15, 2011 | LG Heating & Cooling
My 1995 Sierra blower quit.
probably the blower motor.
Jul 18, 2010 | 1995 GMC Sierra C1500
Wine Cooler not Cooling
I think the compressor of the cooling refrigerator is not working. Otherwise the refrigerant gas has escaped from any leakage. Please check two above mentioned things. Gautam Kr. mandal, Durgapur
Jan 19, 2010 | Kitchen Appliances - Others
No heat or air are blowing from the front , back is fine
it sounds like your fan motor may be stuck or has gone out
Feb 04, 2009 | 1999 Ford Expedition
Edgestar AP550Z won't heat, goes into some sort of alert mode
Dec 04, 2007 | EdgeStar Portable Air Conditioner Heater
EdgeStar Portable Air Conditioner Heater Logo
143 people viewed this question
Top EdgeStar Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
James Coghill
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
