Question about Samsung ML1915 Laser Printer
Paper jam inside of machine samsung ml-1915 - Samsung ML1915 Laser Printer
SOURCE: Paper jam/lockup
Check to see if the egg-shaped rubber feed roller is cracked. (Pull out the paper tray, it's in the middle at the front on top.) That's what I'm looking for now on the ML-1740. Seems Samsung used cheap rubber for the roller. It should only be a $.50 part if you can find one.
Posted on Jun 28, 2007
  • 186 Answers
SOURCE: Samsung ML 2010
First open all covers and make sure there is not another piece of paper stuck in the machine. Check under the toner cartridge. If you are sure there is no other paper stuck, try unplugging the machine wait about a minute and plug back in.
Posted on Nov 25, 2007
ghassun
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
SOURCE: Paper jam 2 on Samsug ML-3051N
There is a door around the very back of the printer, if your printer is slightly encased in as mine is you can't see it. That is where the Paper jam 2 is
Posted on Jan 05, 2010
uberpuma
  • 83 Answers
SOURCE: my samsung ml-1610 printer always
There are a series of rollers which are made of rubber in the unit. When these rollers become dry or covered with dust (usually from cheap paper) they arent able to pick up paper correctly any longer.
Think of it as though you are trying to turn a page, and you have to lick your finger to do so.
Its the same concept. When your printer grabs the paper, it cannot hold it while it is rolling it through the printer.
There are kits available through your manufacturer or a local print shop which can clean your printer and help to restore it to its working order.
Hope this helps!
Posted on Feb 23, 2011
Samsung lj 1640 not initialise andredled continiously glowing
printer ML- 1915 Paper jam........
sometime 2-3 paper coming ....
Exactly what happens?????????
please Replay ....
Regarding
sureshbabu
Dec 12, 2013 | Samsung ML-1640 Monochrome Laser Printer
Paper jammed inside my printer near bottom
open front cover where toner cart is situated and remove cart.check and see if the jammed paper has fed into the machine and if so pull paper in the direction it is feeding into the machine.
Oct 26, 2012 | Samsung ML-3051N Laser Printer
Paper jam at ML-1915 - SAMSUNG
Dear
Pl. clean with dampen cloth, to the separation pad on the paper tray and the pickup roller bellow the printer base and above the paper tray.
do not forcible rotate the pick up roller.
Thanks.
Jan 18, 2012 | Samsung Office Equipment & Supplies
ML 2010 Laser Printer: I HAVE A SAMSUNG 4200 IT IS SHOWING PAPER JAM, BUT...
you may want to check again on the printer.if it show paper jam.
open up the fron door and bnack door. remove the toner and check if there is any small pices of paper still jam in the printer.
if not try and see if the fuser flag is not sitting properly. you might need to do small adjustment.
May 18, 2010 | Samsung ML 2010 Laser Printer
Do i need to reset CARTRIDGE CHIP OF my SAMSUNG ML-1915 ( MLT-D10
I just refill my toner for ml 1915 can anyone help me how to reset the chip for my ml 1915 because the price of the toner is the same as a new printer, Mr bobby from Indonesia.
Thank's alot.
May 13, 2010 | OKI C3400N Single Pass Color Printer
Page prints, but jams, samsung ml 2510 and toner is smeared over page
Your toner might be faulty, also remove toner and clean place with a cloth. Look to see inside if their are any loose pieces of paper in machine.
Feb 21, 2010 | Samsung ML-2510 Laser Printer
Paper jams in Samsung, ML - 1451N
try to arrange the paper properly..
May 14, 2009 | Samsung ML 1451N Laser Printer
Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Jan 30, 2009 | Samsung ML 2010 Laser Printer
Samsung ML1915 Laser Printer Logo
118 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
