It is stock in drying setting with inverted faucet like that is continuously blinking and 2 short beeps every time i made a menu selection...can i reset this because it doesn't work anymore.
SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
SOURCE: not sure whats wrong with my washing machine!
My washer humes like it wants to start but doesn't and i have to constantly push it in an pull it out while its humming, after abot 15 to 20 times of doing this it will eventually start. Help!!!!!!!!!!!!!
SOURCE: LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
SOURCE: how on earth do u find auto dry?
I don't know if this helps, but the washing machines I have used will only go straight from wash to dry if the wash is set to 'half load'.
SOURCE: I don't know how to
Hi Thanks for using FixYa. As you don't have the model
no# then to deactivate the child lock,
set program to Easy-Care and hold option down arrow for 5 seconds.
If still it does not get unlocked then Try pressing
"dry" & "spin" together for 10 seconds or until the CL
disappears. Also try pressing "end of cycle" for over 5
seconds. If this doesn't work then try pressing "options &
select" till the light goes off. Also try and press ECO and rapid buttons
together for more than 10 seconds. Please accept the solution if the issue is resolved or post
a comment for further assistance. Thanks Rylee
