Question about Leupold RX-II Rangefinder
Long range mode
I cannot turn off the long range mode on my rangefinder. I navigate around the Quick Set Rotary Menu unttil >150yds is blinking, then hit power and >150 yds remains activated and visible. No matter what combination of buttons I push when on the LRM in the menu, I cannot get it to go off and see a yardage number for my bow shooting distance.
To turn off: push the power button twice while 150 is blinking and once to turn it on.
Posted on Oct 30, 2007
What is the difference between Hunting vs Golfing Rangefinders?
If you want to buy a rangefinder then you would have a question at some point. Can you use a rangefinder for both golfing and hunting? Can you save a few bucks buying one rangefinder?
The answer is Yes, you can. You can use a laser rangefinder for both activities if you choose a smart device that has features to serve both golfing and hunting adequately. You just need to know the basic differences between golf and hunting rangefinders and some limitations.
Fast of all you have to know, what is golf rangefinder and hunting rangefinder.
Golf Rangefinder Golf rangefinders seek for the nearest flag stick for the measuring the distance in an open field.
Hunting Rangefinder
The rangefinders always are in "Distant Target Mode" by default to spot wildlife in wooden terrains. This target set automatically ignores close objects that could obstruct your view.
Here I wrote the 3 difference, you should remember that:
1. First Target And Distant Target Modes
Golfers need "First Target Mode" to detect the near objects like flag or pin in an open golf ground. Hunting rangefinders rarely good at detecting close objects. For hunting, "Distant Target Mode" is appropriate to range a target past the wood. Modern rangefinders come with toggling options between both first target and distant target modes, but they are expensive.
2.Quick And Accurate Reading
Golfing rangefinders detect the object quickly, and hunting rangefinders give the accurate reading. It is true that golf rangefinders do not need to be as precise as hunting one. Hunters want to make sure that their prey can be perfectly located.
3. Magnification Strength
You might be aware of the fact that Hunting rangefinders always have more magnification than the Golf Rangefinders. Golfers need the distance of the next hole, which could be maximum 400 yards. For the bow hunters and hunting, 400 yards rangefinders are also appropriate. In case of rifle hunting or long-distance shooting sports, you will be needed maximum 1000 to 1500 yards ranges.
Now you know what the basic differences between the golf and hunting rangefinders are. You can start choosing your suitable one.
Apr 02, 2018 | The Optics
Which is a good rangefinder for rifle hunting?
The attractive vertical design of the Bushnell G-Force DX is a combination of high technology integrated with some features in demand that is noticed on different Bushnell models also having a 6x magnification that can be utilized both for bowhunting and rifle hunting.
Fully Loaded
Display - The Bushnell G-Force DX is featured with VDT (Vivid Display Technology). Its red screen display has incompatible with the black screen display which is targeted for their budget customers. The settings for the intensity of red display is manually adjustable to one out of four preference settings. These brightness settings aid the user to adjust with the reticle and give a visual record or display of the output from the device of their preference under any condition of lighting.
MOA and MIL - The G-Force DX displays the readings about angle indemnified relics in mil or moa and the holdover in an inch or cm when the Rifle mode is turned on. Users can set the relics to measure in an inch, moa or mil when the ranging requires in yards. Again, users can set the program to show holdover data in Moa, MIL or cm.
Angle Compensated Readings - Some of the older versions of Bushnell rangefinders displayed the view distance in line or dots at the time of Bow or Rifle mode. Next, the device displays the shooting angle and extends the number. When in Bow mode, the G-Force DX provides the compensated angle range in yardage. Otherwise, it gives the relics information when in the Rifle mode. But, the newer version of the Bushnell displays the readings of site distance at first, then it displays the shooting angle beneath the screen for not more than one second and a half before disappearing from the screen. Eventually, the device provides an important information about angle compensation.
ESP 2 - The G-Force DX rangefinder is featured with the second generation extreme speed precision processor offers precise distance measuring advantage and boosted with speed. The device can provide up to 1/2-yard accuracy out to 199 yards and 1/10-yard display precision out of 125 yards.
Housing - The Bushnell G-Force DX is coating rubberized for easy grip with a metal housing. The length of the metal housing is 4 inches, thickness 1.3-inch and height 3-inch which is a compact design of the rangefinders. This dimension of the G-Force DX allowing it to give a relatively low weight of 8oz.
Range - The Bushnell G-Force DX is a vertical-style rangefinder used for long range shooting and the maximum range of the rangefinder is 1300 yards on highly reflective objects. An expected reading on trees under good conditions is up to 900 yards where the same on deer is maximum 600 yards. But, the flat style Bushnell 1600 Elite is the right one for the users requiring more ranging power.
Legend Legacy
The new G-Force DX is developed from Bushnell's previous G-Force 1300 hundred design. Although this model is a new design, it had to leave backward many wanted features of the Bushnell Legend 1200 version. The new Bushnell G-Force DX is a featured with a Bow Mode, Rifle Mode, and Regular Mode same as its forerunner. Another feature is the VSI (Variable Sight-in) that adds versatility in shooting with the rangefinders set with integrated ballistics charts. At last, the popular Brush and Bullseye targets priority settings has added a new dimension into the new G-Force DX.
Modes
Rifle Mode - By selecting the Rifle mode, users can pick a ranging sight that they prefer. After that, they had to select from a ballistic chart that closely matches the flight path of their bullets holdover. Then the rifle icon will appear at the left-top of the screen confirming that the device is in rifle mood. After ranging the target, the line of sight yardage will appear on the display. The device will display underneath the shooting angle which will be disappeared within a second and a half, and at last, it will display a holdover measurement in any unit of cm, inches, MIL, or MOA
Regular Mode - In this mode, the user will get a line or dot of distance view in yardage from the target and it will facilitate the users in no other ways. That means, the indemnified angle in yardage, he relics data or the shooting angle - nothing can be calculated or displayed.
Mar 19, 2018 | Optics
Which is the best golf laser range finder?
Bushnell Scout DX Rangefinder is a good one for golf.
It's a fantastic rangefinder.
It offers some amazing feature and specification like...
  • 6x magnification.
  • Range between 5-1000 yards.
  • 3-volt CR2 Battery.
  • Rangefinder Accuracy 5 yards.
The Bushnell Scout DX Rangefinder will help you to pick from 3 different user modes by pressing the Mode button at the left side of the unit. First is the usual mode which can be used for most purposes up to 1000 meters and works well towards the pretty reflective surface.
When turned on, the Scout 1000 Laser Rangefinder liquid crystal display (LCD) will directly display icons like the bow and rifle mode. The bow mode will provide you with true horizontal distances from 5-99yd away, depending on the angle. The rifle mode, however, will permit you to get the angle and drop/holdover of your shot to the target from 100-800yd.
Mar 03, 2018 | The Optics
Alpine cde-9842 clock set
  1. In the Clock priority mode, press and holdTITLE for at least 2 seconds while the time is displayed.The time indication will blink.
  2. Turn the Rotary encoder CDE-9846 only) or press "up" and "down" (CDE-9842 only) to adjust the hours while the time indication is blinking.
  3. When the hour has been adjusted, press the Rotary encoder (CDE-9846 only) or press MODE (CDE-9842 only).
  4. Turn the Rotary encoder (CDE-9846 only) or press "up" and "down" (CDE-9842 only) to adjust the minutes while the time indication is blinking.
  5. The time is automatically set 5 seconds after the minute adjustment.
  6. The time can also be manually set by pressing the Rotary encoder (CDE-9846 only) or press MODE (CDE-9842 only).
Download Alpine CDE 9842 Manual
Feb 05, 2013 | Alpine CDE-9846 CD/MP3 Car Stereo
Replaced Drum Cartridge - Alarm light still on and still says "replace Drum Cartridge. How do I reset?
Try this procedure, it should help fix the problem,
Turn Printer off. While holding down Enter and Menu keys, power the printer on. You should see PCU Diag Mode displayed. Hit Menu key 6 times till Counter Set is displayed. Hit Enter key Dev xxxxx displayed, left 3 numbers are blinking. Hit (down triangle symbol) till numbers are 000. Hit Menu key, right 2 numbers are blinking. Hit (down triangle symbol) till numbers are 00. Hit Menu key. Drm xxxxx displayed, left 3 numbers are blinking Repeat steps 7-10. Dev tm xxxxx displayed. Repeat steps 7-10. Drm xxxxx displayed. Repeat steps 7-10. Life xxx displayed. Life should be set to 005. Hit Menu key. TNL xxx displayed. TNL level should be between 90-110, if you have problems, try changing TNL. Hit Enter key Counter Set is displayed. Hold down Form Feed key and insert blank paper into manual feed slot. You should get a beep confirming reset. Power printer down and back up, you are done.
Oct 06, 2010 | Sharp FO-4400 Fax
How do we set the clock
1 In the Clock priority mode, press and hold the DISP/
TITLE
button for at least 3 seconds while the time is
displayed. The time indication will blink.
2 Turn the Rotary encoder to adjust the hours while the
3 When the hour has been adjusted, press the Rotary
encoder
4 Turn the Rotary encoder to adjust the minutes while
the time indication is blinking. The time is automatically
set 5 seconds after the minute adjustment. The time
encoder
May 16, 2010 | Alpine CDA-9825 CD Player
It sounds like rotary dialing
I have a similar Panasonic phone (KX_TGA101S).  Someone must have inadvertently changed the dial mode on you.  Here is how you change it on mine, which should be similar to yours.  Hit the Menu button.  Scroll down to "Set tel line" and hit the Menu Button (OK). If it isn't displayed, scroll to "Set Dial Mode" and hit the Menu Button. Select Tone instead of Pulse and hit the Menu Button.  That should do it.
Jan 25, 2009 | Panasonic KX-TG1033S Cordless Phone
Can't set the clock
Pasted from the manual:
TITLE/ for at least 2 seconds while the time is
displayed.
2 Turn the Rotary encoder (CDE-9846 only) or
press
up or down arrow (CDE-9842 only) to adjust the
(CDE-9842 only).
4 Turn the Rotary encoder (CDE-9846 only) or
press
adjustment. The time can also be manually set by
Oct 15, 2008 | Alpine CDE-9842 CD Player
Set
Setting Time
TITLE
encoder
encoder
→ Radio frequency → Clock priority → TITLE mode
mode
Playing time
mode → DISC TEXT
→Clock priority→mode
mode
TRACK
TITLE mode ← TEXT mode ←
DISP/TITLE
→ BALANCE → FADER → DEFEAT
SUBWOOFER*← VOLUME ←
Jan 15, 2008 | Alpine CDA-9827 CD Player
Range finder does not register distance 99.9% of the time
I had the same problem, rangefinder would work only sometimes and only at short distances. Called customer support and was ready to send it in. Tech guy told me to turn off "First Target" ( or "last target") and turn on"LOS" (line of sight). Range finder now works perfectly at all distances. Apparently the first target feature doesnt work properly.
Dec 26, 2006 | Leupold RX-II Rangefinder
Leupold RX-II Rangefinder Logo
540 people viewed this question
Top Leupold Optics Experts
Ken Williams
Ken Williams
john h
Are you a Leupold Optic Expert? Answer questions, earn points and help others
