Question about Roper 24 in. RUD3000 Built-in Dishwasher
Roper RUD4000MQO built in dishwasher - Roper 24 in. RUD3000 Built-in Dishwasher
Roper dish washer not cleaning the dish, it is a rud4000mq Id # fs2941518
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 19, 2011 | Roper 24 in. RUD4000M Built-in Dishwasher
What are the exact cabinet dimensions of a Roper dishwasher, model #RUD3000? Thank you!
The manufacturer specified cabinet dimensions for this model are:
Total width: 23 7/8" / 606mm
Total height: 33 7/8" / 860mm
Total depth (front to back): 24" / 610mm
If you need any further specifications for this model, please reply within this solution.
Regards,
BElectric
Nov 18, 2010 | Roper 24 in. RUD3000 Built-in Dishwasher
Water in back of Roper dishwasher
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 19, 2010 | Roper 24 in. RUD1000DB Built-in Dishwasher
Roper RUD5750DB4 is leaking
Your problem could be the rubber door seal.
Feb 25, 2010 | Roper 24 in. RUD4000M Built-in Dishwasher
Roper dishwasher washes, seems to run normally, but leaves a couple inches of water in the bottom when done
If the drain is stoped this will happen. Is it a new instalation? If into a disposer did you knock out the plug in the disposer. Check the drain line
Oct 17, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Dishwasher on no water
Is the water valve under the sink on? Any kinks in the hose? Check to see if the water valve solenoid coil is open (located under the cabinet front).
Oct 12, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Roper Dishwasher Model RUD3000KQ1 is not washing clean
Ther is a small tab area on left side of screen. Lift here and work way around screen. Right side will unsnap out of drain. Snaps back in when ready.
Nov 28, 2008 | Roper 24 in. RUD1000DB Built-in Dishwasher
Dont know how to start it
Roper is a subsidiary of whirlpool. Call this number and they should be able to help with all operating questions.
1-800-447-6737
Hope this helps,
Kermit
Aug 24, 2008 | Roper 24 in. RUD1000DB Built-in Dishwasher
Just stopped working
Check the following to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jul 02, 2008 | Roper 24 in. RUD3000 Built-in Dishwasher
Roper dishwasher
Here is the link to the user manual if you need it; http://www.roperappliances.com/data/8575997.pdf Page 17 gives all the numbers to call for replacement front panels. here is the link to the installation manual; http://www.roperappliances.com/data/3385181.pdf Page 13 onwards tells you all you need to change the panel. Hope this helps :)
Mar 16, 2007 | Roper 24 in. RUD1000DB Built-in Dishwasher
Roper 24 in. RUD3000 Built-in Dishwasher Logo
88 people viewed this question
Top Roper Dishwashers Experts
Mike
paul
paul
Adzhall
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
