Question about Intel DP35DP Motherboard
Slow bios boot dp35dp
Very slow boot at power on i use a 2modules 2GB memories.
I put a 2gb ddr2-667 memory chip in the single (only) memory slot in my gateway nx100x notebook pc. The pc will not boot up with the 2gb memory card. Is there a compatibility problem or do I have a ba
yes, there may be compatibility problem. your 2GB ram may be dead. try your 2gb ram on other notebooks. if it is working on other notebooks, then your ram is ok. your notebook will support maximum 2GB ddr2 memory per slot. your notebook may not be booting due to unsupported frequency of your ram. maximum supported frequency for your notebook may me 400Mhz, and you are putting a 667MHz ram into it. try to put a 400MHz 2GB ddr2 ram in your notebook.
Apr 10, 2013 | Gateway Computers & Internet
I have a hp pavilion a635w that will not boot up not even to bios
check if the ram if is compatible with the board
check if the battary power the bios
Dec 22, 2009 | HP Pavilion A635W PC Desktop
Ver, very SLOW when booting up! Sometimes the
BIOS System defaults are best used for installing a new operating system or performing diagnostics. Bootchecks and memory checks due to settings on antivirus/antispyware programs are notorious for causing slow boots. In most cases these scans are unnecessary. Saying that, it is also possible you have acquired a trojan. Run a full system scan and if you have a clean machine, disabling the bootchecks and memory checks will speed up your booting. If after doing this your boots are still slow, tweak your BIOS as follows per Intel:
  • Set the hard drive as the first boot device in the boot order in the BIOS setup (Boot > Boot Device Priority menu).
  • Enable Intel® Rapid BIOS boot in the BIOS setup (Boot menu).
  • Disable Hard Disk Pre-Delay in the BIOS Setup (Advanced > Drive Configuration menu).
  • Disable system functions and features if you do not need them. Examples include:
    • Legacy USB - this must be enabled if you use a USB keyboard or USB mouse outside the Windows* environment (Advanced > USB Configuration).
    • Unused I/O ports, such as serial, parallel and IEEE-1394 ports (Advanced > Peripheral Configuration menu).
    • Event logging (Advanced > Event Log Configuration menu).
    I hope you find this solves your problem. All the best! Greg
Nov 10, 2009 | Intel D845GVSR Motherboard
Abit AW8 LGA775 Maximum memory
Hi there
Sounds like the bios will need updating as the board will support 8BG ram.
Put your old memory back in the machine, boot into windows, go to the motherboards manufacturers website and download the latest bios update and install it and reboot.
make sure you read the info on how to install the bios update.
I must also warn you that if you are using a 32bit operating system it will only recognize 2.9BG of memory, there is nothing you can do about this apart from install a 64bit operating system if the board supports 64bit processors.
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Abit AW8-MAX Motherboard
Memory Upgrade and Computer will not boot
You need to do a BIOS Upgrade. First get the name of your BIOS when the computer boots up. Then go to the we site and find your BIOS brand and get a version update or upgrade.
Be VERY careful and follow the directons to the letter.
Let me know if this helps.
Jack
Jun 13, 2008 | E-Machines eMachines Desktop PC
Memory upgrade 512MB > 2GB
Thermal problems becuase of inadequate power . Your power supply to be looked into.
Apr 12, 2008 | Foxconn 760GXK8MC-S Motherboard
Motherboard ASUS P5RD1-VM ram problem
More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
Feb 16, 2008 | ASUS P5RD1-VM Motherboard
3x 1GB DDR400 Problem on booting!
the details for your case can be obtained in this site.....................
http://www.memory4less.com/m4l_results.asp?ref=mem&modelid=800121
read carefully to understand the limitations that arise with your motherboard.
cheers....................
Jan 22, 2008 | ASUS P4S8X Motherboard
Still Doesn't Work
You needed to configure bios (F2) when you first installed the processor,
now the Bios hangs before anything can happen,  You need to remove the Bios Battery (looks like a coin on the mobo) for about 30 secs (with the power disconnected)  then re-insert the battery and power on.
you should get the same power on message as you did the 1st time (maybe with a missings settings error too but this is expected)
Enuro12 is right about legacy USB in that your keyboard should work in BIOS (setup)
Oct 12, 2007 | Intel Motherboard
Intel DP35DP Motherboard Logo
134 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
