Question about RIM BlackBerry Pearl 8100
My blackberry media card
I bought a media card for my blackberry put it in and it say there is no media card present wat am i doing wrong biggeygurl@yahoo.com
  • Anonymous Apr 08, 2009
    media card on my blackberry pearl 8100 says media card isnt present
  • Anonymous Apr 15, 2009
    My Blackberry Pearl won't let me save anything on my media card.. It's as if it's not even in there. Is there a setting I need to do to set-up my media card so my cell knows it's there?
  • 9 Answers
Try opening your options menu and select "media card". Make sure media card support is turned on.
-Neil
Posted on Jul 03, 2009
I had the same problem so I wedged a small piece of paper over the card to ensure the contacts were contacting.  It worked!
Posted on Jul 11, 2009
Can't see files located on the 4gb micro sd hc memory card on my Blackberry 8100 Pearl. Path:Media/Music/Media Card - the folder comes up blank. Any ideas?
your card may not work with the blackberry. try formatting the card via it ebeing in the blackberry, and then put everything back on the card afterwards. it should work. if not again, your card might just not be compatible wit the phone
Feb 17, 2010 | RIM BlackBerry Pearl 8100
My blackberry pearl says: "A media card is not presently inserted in the device
Hello. If you know you have inserted a card but it is not showing up remove the card, wipe it with a tissue and reinsert it more firmly. If you do not have a media card but need one, they are available at any phone store, or staples, or electronics department at walmart. Regards, Joe.
ps - kindly rate my answer as helpful. thank you.
Feb 13, 2010 | RIM BlackBerry Pearl 8100
Bought unlocked blackberry 9530 on ebay I use
You have to contact with your internet service provider.
Feb 10, 2010 | RIM BlackBerry Storm 9530 Smartphone
When i put my media card in my blackberry it says its not there?
back up first all of your files.then format your media card using your Blackberry,not your PC.If it is still same problem after formatting,try to replace another media card and check if other media is working in your phone.lastly,if still not working its already a hardware problem,its a memory card IC,not working anymore,you must replace it.
Jul 22, 2009 | RIM BlackBerry Pearl 8100
SanDisk 2GB memory card
format the mem card through your computer instead maybe, it works best if u have a usb reader that the sd card slot in then jus plug it in. if it dont automatically show up on pc go to 'my computer' in the menu and it should b found there prob as removable drive, once in it right click mouse and should b an option to format sd card, hope this helps.
Apr 10, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry Pearl 8130 has been deleting everything from the call log, SMS, & emails. It started that after I've had it ONLY 2 weeks. After it automatically deletes, anytime I got call missed, or SMS, I...
This issue may be caused by one of the following:
CAUSE1
A large number of applications are installed on blackberry smartphone.To resolve this issue complete the following steps:
  • Make sure that the BlackBerry® Device Software is installed on the computer to display the correct total application space.
  • Determine the application space that is available on the BlackBerry smartphone by completing the following steps:
* Connect the BlackBerry smartphone to the computer. * Open the BlackBerry® Desktop Manager
* Double-click Application Loader
* At the Device Application Selection screen, under the application selection window, note the total application space.
  • Remove applications that are not required. For example, remove additional language packs and themes.
CAUSE2
Media settings may contribute to low memory capacity.
  • On the BlackBerry smartphone, click Media.
  • Select a media application.
  • Display the menu, and click Options.
  • Set the Device Memory Limit to the lowest setting field
  • Display the menu, and click Save.
CAUSE3
A large amount of BlackBerry smartphone user data is present on the BlackBerry smartphone that cannot be removed by the Low Memory Manager.To resolve this issue, complete the following steps:
  1. On the BlackBerry smartphone, click Options > Status
  2. Display the menu, and select Database Sizes.
  3. Reduce the number of items that are increasing the size of the database. For example, if the Address Book database is large, remove out-of-date contacts. If the Content Store database is large, move media files from the BlackBerry smartphone memory to a media card.
Mar 26, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Can't open data stored on media card
Connect the BlackBerry to your computer.
Open My Computer, and open Properties of the drive.
What does it show under File System?
The BlackBerry cannot read NTFS, so make sure that it is not an NTFS file system. if it is, move your files off the card, and format it as FAT, then put the files back on the card after the format.
Otherwise, without the BlackBerry connected to the computer, go to Options (or Setting > Options, depending on your Theme),
Then opem Media Card, or Memory (depending on your Theme and software version).
What does it say about the card? Does it say that it is connected, or that there is no card?
Jan 21, 2009 | RIM BlackBerry Pearl 8100
How to unlock my blackberry curve free!
take out your sim card and or media card and enter the password wrong. It usually has about 10 tries. After the final time, it clears any personal data on the phone for security reasons(thats why you take out your cards) Then when it is done reloading, you can change your password...make it something easy. Then go into your security options and disable the security lock. Then you can put your cards back in. Good luck.
Dec 20, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
HELP
what happens when you try to send one?
Sep 22, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
369 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
