Question about Canon EOS-5D Digital Camera
Oil spots on sensor 5d
Have these orbs showing up after using eclipse2 solution... inclined to think that it must be some of that factory lubricant i read about... am new to cleaning the sensor...was thinking of trying Smear Away solution...images appear as under exposed areas in shadows and darker areas in sky shot at f22...suicide is only slightly considered at this time...go ahead and push me over the edge...
    Master:
  • Canon Master
  • 442 Answers
Are you sure what's on the sensor isn't dust and not oil? Cleaning a sensor is a delicate operation though I've done it in the field where I had no options to save a shoot. If there is actual debris on the sensor and it cannot be CAREFULLY removed with a LIGHT, INDIRECT burst of air or a very clean, fine lens brush then I'd send it in to have it professionally clean. Canon has a fast turnaround time and pretty reasonable.
Posted on Nov 30, 2014
5 Suggested Answers
arnomonfort
  • 115 Answers
SOURCE: spots on images
spot is dust on the sensor. unfortunately, you will have to clean your sensor by yourself (it cost 30$ in a shop) There a fonction in the menu that up the mirror so you can access the sensor. very carefull. the pixel are so small that you can not see the dust but they are there!. caution, you need to put your body on a pod, have a good light to see what you make and some adapted items to clean the sensor. If not neede, avoid liquids. good luck and don't panic.
Posted on Feb 05, 2009
thomtime
  • 38 Answers
SOURCE: Under exposed pictures when using studio lighting with 5D
A black shadow at the bottom of the image is usually the result of using a shutter speed that is beyond the max flash sync speed of your camera. The max sync speed of the 5D and 20D is 1/200th. In a studio setting with wireless triggers there can be additional latency. Try using a shutter speed of 1/125th and see if that clears it up. You may be able to push it a little higher as pocket wizards are very good wireless triggers but don't use a shutter speed above 1/200th.
Posted on Feb 09, 2009
  • 4 Answers
SOURCE: Camera display shows two black spots but doesn't appear in photos
Try cleaning the sensor
Posted on Sep 08, 2009
  • 122 Answers
SOURCE: It appears I have some
Bring the camera in for a cleaning If you have never done this yourself then dont try it you will ruin the chip
thanks
rene
Posted on May 28, 2011
Spots on the display screen
Still not clear, what you mean. But take care wham cleaning a lens. Never use a fluid like alcohol. Use a special lens pen or the soft brush on the other side of a lens pen, when you think the lens is dirty. Spots, or disk, also can appear when light is entering the lens from an angle. Even the expensive Fuji X10, had orbs or disks on the pictures in certain situations. Like dark with one or a few sharp lights close bye. Try the camera in different situations, to make sure the phenomena is in the camera or just a strange rare occasion.
When it is caused by a defect in the camera, it should show on every picture.
Dec 26, 2013 | Vtech Kidizoom Digital Camera
How to take apart a signer 7430 model
You can remove screws bottom plate, however, unless you are mechanically inclined, I would take in for service. Lay machine back on soft cloth or old towel. Don't lose screws! Oil moving parts one drop good quality sewing machine only and use Singrr lubricant on gears. If you don't have oil or lubricant, you can blow hair dryer 1-2 minutes and put plate back on. Never oil or lubricate plastic parts! One drop oil on shuttle hook, Run scrap to distrubute oil before sewing on project fabric ! Jimmy
Apr 03, 2012 | Singer Sewing Machines
Our Canon IR2200 model is making squeaky highpitched noices when it copies. We're thinking it needs some lubrication, any suggestions? PS. If oil is needed, where do we apply the oil and what type of...
Regular oil applications is a necessity in order to combat the squeaks of a copier, as for where to oil and what type of oil to use; I suggest going to radio shack (or similar) and picking up a pen-type lubricator, as it makes it much easier to reach tight spots and it is also rated for electronic use. Do not use WD40 or any other petroleum based oil, as this will cause vital components to breakdown and literally melt away. As for where to apply it, you may apply several drops to any gear, motor, clutch, roller; really there is no restriction, just anywhere that may have friction points. With this type of lubricator, you do not have to worry about destroying circuit boards, as only a small amount comes out and it is rather viscous so it will not drip.
Hope this helps,
David R.
Dec 01, 2010 | Office Equipment & Supplies
We have a front loading dryer that is noisy and vibrates a bit when the drum turns during use. Everything else works fine. Thank you for this service!
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Sep 18, 2010 | LG SteamDryer 7.3 Cu. Ft. Extra-Large...
GLER341AS1 Frigidaire electric dryer, was grinding, now not work.
Sounds like you have two problems with your dryer, both are fairly easy fixes if you are mechanically inclined and cheaper than buying a new dryer.
1...Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley. 2..Sounds like the front seal between the drum and the door needs to be replaced
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt and front seal. You can now replace or reposition the drum seal if it has moved from its normal position. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Jan 11, 2010 | Frigidaire GLER341A Electric Dryer
My dryer makes an annoying squeaking noise while operating. What do you think it is?
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Jan 02, 2010 | Frigidaire Electric Dryer
Intermittent rumbling when the dryer is in operation. I think it might be a bearing. The product is a Maytag Gas Dryer #LDG9304AAE Serial # A1515769KK.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Good Luck,
I hope this helps
Please rate me,
Thank You
Dec 04, 2009 | Dryers
Spots on images
Jul 02, 2008 | Canon EOS-5D 12.8 Megapixel SLR Digital...
Dust Orbs
The bright, round spots appear to be flare caused by internal reflections of the lights in the lens. Dust on the sensor blocks light, and hence appears dark.
Sep 13, 2005 | Kodak EasyShare DX7440 Digital Camera
Canon EOS-5D Digital Camera Logo
63 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
