Question about DISH Network ViP 922
Dish error 04
Cant watch recording...gives error code 04
3 Suggested Answers
  • 374 Answers
SOURCE: How do I correct error code 04 when trying to playback DVR event?
The error code 04 is a two digit error code associated with the opening of dvr files and will more than likely require a technician to come out and troubleshoot the issue. More than likely the end result will be the replacement of the receiver. If they do have to replace the receiver there are some receivers that have a USB port that wil allow an external hardrive to be attached to the receiver. This feature will either give you the ability to have more recording time if the receiver is a DVR or allow you to record directly to the hardrive which will save you the DVR fee every month if the receiver is a non DVR. There is a one time fee of 39.99 to enable the USB port but that cost will be recouped after the first year alone if you get a non DVR unit. I hate to bear bad news but this is as accurate as I can be without being in your living room. I hope you understand. Thanks for using Fix Ya.
Posted on Feb 27, 2009
SOURCE: Dish 625 DVR recorder won't play recorded shows.
Hi I will be more than glad to assist you in this concern. First press the power button on the front panel of the receiver for 10secs. once you press it the receiver will turn off and it should turn on by itself, once it turns on by itself you will see attention 015, press the menu button on the upper left of the remote, once you see the menu button press 6, 1, 1 on the remote and it should show on the screen point dish, select on check switch, once u are on the installation summary screen, select on test and it should do a test of 1 of 3 or it depends on your sat orbital location that u have.. once its done, it will show the installation summary screen and you should see sat input 1 & 2 with port1 up to 2 or 3 depends on your sat orbital location, all the trans on the sat 119, 110 or 129 if you have should be ok and green. once you see that all ok, select done on the screen, and it will be back to point dish, select done again, and then cancel all the way out of the menu, it should show on the screen attention 015, let it finish until it download the programming guide, once its done it should show a tv pic. press the dvr button and access your recorded event, it should play the dvr event. if the problem still exist, unplug the power of the dvr from the power outlet for 1 minunte then plug it back again and it should acquire the sat signal and download the programming guide, once it shows a pic. press again the dvr button and access the recorded event. it should play the recorded event, just incase the problem still exist, check what will be the exact error msg, write it down in a piece of paper and please feel free to get in touch or you can call on 1-800-333-3474..in order to for the dish tech support replace the receiver, this is a dvr lost of function.
Posted on Sep 05, 2009
How do I cancel recordings on dish
turn the recorder off before starting to watch TV
Oct 16, 2017 | Televison & Video
TV switch to live tive when wtaching recorded program
Hi there anil! My name is Kimberly and I form part of the Social Media Department with DISH, It is my pleasure to assist you. When watching an already recorded event and having a timer set up to record it should not interrupt your viewing of that DVR event. When this happened, did you get an error message on the screen? And has this happened again? Please reach me at: kimberly.escobar@dish.com with the details.
Kimberly. Escobar
Social Media Representative
DISH L.L.C
Dec 14, 2013 | DISH Network ViP 922
I have a satalite dish dvr #625 it wont record rewind fast forward or pause. And i cant watch recordings. I have tryed everything and nothing works.please help..
Sounds like a problem with your box. you need to either have dish come replace it or u dont have the right reciever that will allow you to do that. If it is the right reciever and its still not working the dish company should be able to help trouble shoot the problem or send someone out to fix it. sounds to me like a faulty box that needs trashed.
Apr 25, 2012 | Televison & Video
Cant record two programmes at once
Well no matter the DVR, you should be able to record 2 programs at once...but you CANNOT watch a 3rd live while they are recording...also, if your DVR is hooked up to more than one tv and someone is watching something else in the other room, it will not record 2 at once, either. You can watch RECORDED programming while 2 others are recording, but not live tv.
You might want to check how many "inputs" your DVR has...most have 2 which allows the double recording...if you have an older DVR maybe you only can do one at a time. On my DISH box, they call these "TV1" and "TV2".
Hope this helps.
May 14, 2011 | Televison & Video
Error code 04ee on Dish network 722 vip HDD,
Hello this is luke. I do not know of any 04 ee error code on dish network. The closest will be 004. Try to check if it is coming from the receiver or from the tv by unplugging the receiver from wall outlet while tv is on. If the code stays, then it is from the tv, if it goes away with the lights on receiver, it is from the receiver. Let me know.
Jan 23, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Md4 recorder mini disc. will only power up error 04
I have also the same problem with my MD8 recorder, the same error code: ERROR 04... From the yamaha website it says,
Error 04: The magnetic head didn't raise off of the disk.
Apr 09, 2009 | Audio Players & Recorders
Follow this article to fix the issue.100% Guaranteed
http://social.technet.microsoft.com/forums/en-US/itprovistahardware/thread/bd9763de-6141-45ea-990b-70c207fe3fb6
Feb 26, 2009 | DISH Network DVR-625 DTV Receiver /...
Recording
King,
You can try doing a front panel reset and seeing if this resolves the problem but more than likely the receiver needs replacing. Thanks for using Fix Ya.
Feb 12, 2009 | DISH Network DVR-625 DTV Receiver /...
Error code 05
delete all recordings from hard drive unplug the receiver from the wall for 5 minutes and plug it back in, if 311 error message appears call dish network
Jul 27, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network ViP 922 Logo
270 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
