Question about GE Washing Machines
Tub is off balance
The tub just wobbles bouncing off the walls in spin mode
The tub is out of balance. When it starts hitting the sides, stop the washer and move your clothes around inside the tub to balance the tub. Now start it to spin again. This should stop the tub from hitting the sides.
Posted on Feb 14, 2012
Sounds like one of the springs going from the tub to the frame could be broke or unhooked. Also, the washer could be out of balance.
Richie_asg1
  • 1036 Answers
SOURCE: tub wobbles terrably in spin mode
This is normally caused by defective dampers. Just like car suspension, these even-out the vibrations of the drum.
When worn, the drum just bounces wildly on it's springs.
The metallic banging should be avoided by foam buffers fitted inside. These frequently fall off unnoticed. They just need gluing back on with impact adhesive.
Here is a typical diagram of a washer - click HERE Move your cursor over the damper on the bottom left of the drum to see it.
Look online at spares centres for your make and model, and look for keywords of - suspension, shocks, shock absorbers or dampers for your parts.
They are fairly easy to fit with the back removed.
Thanks for using Fixya! If this has provided a solution, please rate as such. Thanks.
Posted on Jul 03, 2008
JR JR
  • 116 Answers
SOURCE: empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Posted on Nov 30, 2008
daddy1264
  • 76 Answers
SOURCE: Kenmore Series 80 wobbles when spinning
the basket is attached to a triangular brace that must match up with the frame it sits on.
Posted on Jan 01, 2009
t1m130
  • 86 Answers
SOURCE: The machine does not spin properly. The tub
it sounds like the unit is not sitting on level ground sometimes there are feet that can be adjusted to raise and lower the unit on the front left and right side go to a department store and by a level for a couple of dollars and put it on the top exterior of the unit and check it left to right and front to back
Posted on Mar 14, 2009
  • 464 Answers
SOURCE: tub gets off balanced during the spin cycle and
need to know the make and model to help you. tks.
Posted on Oct 11, 2009
My cabrio will not spin or complete a wash cycle. Acts like iit's unbalanced even when empty. Keep getting an F51 error code
it is most likely a bad center bearing. Was it loud when it sup last? If it was then the bearings are going bad. If not spin the tub by hand and see if its stuck if it is work it back and forth and see if you can break it free. That is still a bad bearing. Also try spinning the basket by hand as fast as you can and see if the bearing sound like they are grinding or smooth. If the bearing seem ok then push down on the tub ring and try to push the tub and basket down it should take quite a bit a pressure to push the tub down is its easy and you can bounce the tub up and down it the washer like a basket ball then you need new support rod they keep the tub stable during spin and when the springs on these go bad they allow the tub to bounce during spin and that causes the unit to go out of balance and stops spinning.
Dec 23, 2016 | Washing Machines
Drum wobbles when empty
can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Apr 02, 2015 | Whirlpool Wfc7500vw Washer
My top loader washer is off balance and makes loud noise when it is spinning even when empty. the tub bounces of the inner wall of washer. It is only a year old.
I had a washer that if it hadent been next to a wall would have been in the other room.It was one of three springs that held the drum stable just under the top.hope this helps
Mar 22, 2015 | Washing Machines
The tub continues to go off balance in spin cycle. Starts out smooth then starts to wobble terribly til the UL shows and shuts down. Support rods are good
There is a little device inside the washer that allows the agitator to spin independent of the drum. If this gets stuck, the washer will try to spin the whole drum instead of just the agitator. This will cause the washer to think the load is too large or out of balance, causing the error code. On some Whirlpools this device is just a washer.
Jan 07, 2015 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
Out of balance condition
check the drain pump in the bottom of the unit and verify its not clogged, verify unit is level, also check the support struts/springs for the tub.
May 26, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Off balance spin cylce
The base of the tub assembly rests on a white plastic ring called a 'snubber'. If any type of lubricant gets in this area, the tub will wobble excessively. The major cause for this issue is a failed transmission where oil has leaked out and into the snubber. The transmission may be warranted for 10 years. Check your owners manual. A good method to check for oil is to tilt the machine back and remove the plastic cover in the center of the pulley, if it contains oil, the transmission is leaking also look at the inside cabinet wall for signs of oil splatter.
If you need further assistance, let me know
Regards,
reg501
Jul 19, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Spin
Does this happen with every load? I've had this happen occasionally but it was caused by one or two heavier when wet pieces of clothing that caused the tub to get off center and it would wobble out of control. By just rearranging the wet clothes to balance the tub it stopped wobbling. But only after making sure that the heaviest objects were on opposite sides if the tub.
Nov 11, 2007 | Washing Machines
Washing Machines Logo
756 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
