Question about Microsoft Office Professional 2007 Full Version for PC
2001 winstar keeps codeing 301 302 303 already replaced plugs wires and coil pack
  • 17,970 Answers
Hi John:
P0301 Code - Cylinder #1 Misfire
A P0301 code means that the the car's computer has detected that one of the engine's cylinders is not firing properly. In this case it's cylinder #1.
Symptoms may include:
- the engine may be harder to start
- the engine may stumble / stumble, and/or hesitate, other symptoms may also be present.
A code P0301 may mean that one or more of the following has happened:
- Faulty spark plug or wire
- Faulty coil (pack)
- Faulty oxygen sensor(s)
- Faulty fuel injector
- Burned exhaust valve
- Faulty catalytic converter(s)
- Running out of fuel
- Poor compression
- Defective computer
* This conditions is the same when code is P0302 or P0303.
Possible Solutions:
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day
Posted on Feb 14, 2012
Trouble code p052
You could have got a bad coil pack. Primary and secondary are the coil pack. Possibilities are plug wires and spark plugs also. not likely though.
Jan 31, 2015 | 2001 Ford Mustang
I got a 2001 Oldsmobile aurora that the code reads PO301
well that code means ur have a missfire in cylinder one change the wires for the spark plugs that really the only thing i can think off beacuse you have already done the spark plugs and the oxygen sensors and the coil packs
Feb 26, 2013 | 2001 Oldsmobile Aurora
Check engine light on 2001 Plymouth neon, code says #4 cylinder misfire, already replaced plugs wires and valve cover gasket.
check coil pack for resistance with an ohmmeter. if one pack controls two cylinders, the values should b the same. if not replace coil pack
Sep 24, 2012 | 2001 Plymouth Neon
Hi John:
- Poor compression
Possible Solutions:
Thank you for using FixYa, have a nice day.
Feb 14, 2012 | Cars & Trucks
Ingnition coil b code is on how to change the coil
Do you have coil over each plug or is it a coil pack for all plugs. If each plugs has a coil, they have small screws to remove, pull the plug wire out after this. But if the coil pack, label each plug wire to keep them in order. the pack can be removed easily. It should have 4 screw, once those are out the coil pack will come off. Make sure after replacing it, you use di-electric grease on the bottom of the pack or in the coil over plug method. This keeps run-away spark and can cause mis-fire.
Jan 05, 2010 | 2005 Ford Escape
Code reader showed random misfire on cyl. 1,3 and 5, 2001 XG300
it may well be the coil pack that sits on top of the spark plugs.
Nov 03, 2009 | 2001 Hyundai XG300
Check engine light blinks
Ok, i would ave the ignition coil pack tested for its operational valve asap if possible. this is either an ignition coil pack issue or, a bad ECM. the ECM controls the ignition timing in this vehicle so, the problem will be there if the crank shaft sensor and cam sensors are ok.
I would pull the trouble codes asap as well. this will help diagnosis this issue correctly. this can be done at a local auto zone or a local mechanics shop as well.
Jun 19, 2009 | 2001 Ford Windstar
Misfire code on 2001 2wd jeep cherokee what can we try
I would lean toward a dead coil pack or a dead plug, there is no way to test the coil pack other than removing it and keep the wires plugged in and install spark plugs in the grommet cavities of the coil pack and check for spark across all cylinders( assuming its a 4.0L)
Apr 21, 2009 | 2001 Jeep Cherokee
Microsoft Office Professional 2007 Full Version for PC Logo
363 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
