Accidental short/spark - what part did i ruin?
I accidentally connected a hot wire on the thermostat-controlled switch with frame/ground and it caused my to quit. I replaced the $111.00 circuit board and the outdoor unit of the Intertherm T3RA-030K heating/ac system still only clicks and hums quietly after the 5-minute delay. These units don't have a safety fuse or breaker on them? If i replace the switch will it work or could accidental grounding cause a short elsewhere on the unit?
    Novelist:
  • 124 Answers
YOU HAVE TOUCHED A HIGH VOLTAGE WIRE TO GROUND AS I READ YOR STATMENT. THAT WILL CAUSE A HIGH VOLTAGE BREAKER IN YOUR DISCONNECT OR MAIN PANEL TO TRIP. YOU CAN FIND CONTACTOR IN OUTDOOR AC MASH IT IN WITH AN INSULATED SCREWDRIVER AND SEE IF COMPRESSOR COMES ON . IF NOT YOU HAVE NO HIGH VOLTAGE TO UNIT FIND AND RESET BREAKER. or YOU CAN GO TO MAIN PANEL AND ALL DISCONNECTS AND CHECK FOR A TRIPPED BREAKER. REMEMBER MOST BREAKERS TRIP TO HALF POSITION, BUT CUTLER HAMMERS TRIP TO OFF POSITION. THE THERMOMSTAT CONTROLLED SWITCH IS CONTROLLED BY LOW VOLTAGE THAT TELLS IT WHAT TO DO, BUT THE WORKING POWER IS USUALLY HIGH VOLTAGE IF ANYTHING HUMS ETC YOU HAVE LOW CONTROIL VOLTAGE BUT IF CONTROLS CLOSE AND NOTHING HAPPENS YOU HAVE LOST A LEG OF POWER OR BOTH LEGS. LOCATE TEST AND RESET ALL SOURCES OF POWER ( HIGH VOLTAGE)
Posted on Oct 25, 2008
Would not having a proper ground for a 3 prong plug be the cause of short cycling every 2 to 3 minutes, once the desired temperature is reached?
Hi "T"
Highly unlikely.
Depends what you mean by "short cycling"
The Ground pin is purely for SAFETY.
It has almost the same purpose as the neutral wire in an ac circuit.
Both often connect together in your meter box.
First, "Lightning" can jump the gap to take the HV pulse to "Ground"
Also, When wires fall off connectors inside equipment and touch the grounded metal chassis they cause the fuse to blow,
Plastic enclosures don't have a need for the "ground" wire.
Modern AC supplies now use an RCD for added safety.
This senses an minute in-balance between the three wires and electronically switches power off.
(Which may have been caused by your finger between the AC hot phase wire & ground... thereby saving you from a full shock)
The "short cycling" being a shorter time period than set on the timer clock.
This would be either an electronic timer or mechanical timer.
Each would have a different reason for reducing the expected time to do a function.
Disturbances & spikes in the Electronic's Power Supply could change the time value.
Are their any Electrolytic Capacitors on the internal incoming power supply voltages. See Below
Cheers
Hot Neutral and Ground our Funny Looking Household Electrical Socket
Difference between Neutral and Ground wire Explained
Identifying bad capacitors on motherboards and adapter cards
Sep 14, 2016 | DeLonghi Heating & Cooling
Circuit board fuse blows when the compressor tries to start
If its a standard split cooling system you should have a control wire that connects the indoor unit to the outdoor unit. That control wire has 2(or more) small wires and normally red is the hot(24volt) and white is the common. Power from red may be shorting to ground or touching the metal on something. It could be the wire touching another wire causing a short. Or if the outdoor unit has safety switches such as a low or high pressure switch, the wires to them may have rubbed against the copper tubing inside the unit causing a short to ground. It could be the electrical contactor or any circuit circuit board it may connect to. Most the time I find that the control wire (small wire) will be pulled on or chewed at the outdoor unit. Something can pull on it and cause it to ground where it connects to the unit behind the control panel. Be sure to be safe!!! A bit of experience may be needed. A good tech can usually find a short in 10 mins.
Jun 14, 2015 | Koldfront Ultracool 14,000 BTU Portable...
Control transformer keeps shorting out
One or more of the solenoids operated switches is your most probable cause. If you have a clamp on amp meter, measure the amps pulled by each component with a solenoid. The reversing valve solenoid and the main contactor solenoid. Each one of the these components are typically rated at 6watts. If your control voltage is around 25 volts, your amp draw should be about .24 amps max. If your transformer cannot be reset without blowing, install a 3 amp inline fuse so when the overload occurs the only thing that blow is an inexpensive fuse costing about 25 cents instead of a several dollar transformer. If your fuse/transformer immediately blows, try looking for a direct ground in the control wiring. If problems has persisted for a while, you may even have to look into replacing your thermostat wire. The control wire travels over the thermostat wire throught the thermostat and excess amps through the thermostat wire can break down the insulation jacket and short to the common wire causing the control transformer to blow. Another thing to check is the condition of your thermostat wire to check if the insulation is shredding off. Old thermostat wire, especially thermostat wire exposed to sunlight deteriorates quicker. Hope this helps.
Jan 10, 2014 | Rheem 14AJM49A01-RHSLHM4821 4 Ton 14.50...
How to connect to my Air conditioner AZ28E15DABm1 GE a thermostat model TR400 HC-A SECO?
carefully follow the below steps;
Turn off the circuit breaker that controls the air conditioning system. Turn the thermostat to the "On" position to make sure that all power is cut off and the air conditioner cannot accidentally operate.
Remove the cover of the existing thermostat and remove the colored wires from the terminals. Take out any screws that secure the thermostat to the wall, and remove the thermostat.
Mount the new thermostat on the wall. Feed the wires through the unit, with enough slack to allow you to make the new connections.
Connect the red wire to the thermostat terminal labeled "RH," "RC" or "R." The red wire carries the power from the transformer.
Connect the green wire to the thermostat terminal labeled "G." This controls the relay that controls the fan. Attach the yellow wire to the "Y" terminal of the thermostat. This powers the main control. Connect the white wire to the "W" terminal. This is the heating control wire.
Close the thermostat's cover and turn the breakers back on. Turn the new thermostat to the "On" position to test it and that would be all.
I hope the above helps. If it is not helpful, please let me know so that I may direct you further.....
Good luck.
Feb 25, 2011 | GE Zoneline AZ38H12DAD Split System Air...
How do a wire a second emergency shut off switch to my furnace
Try wiring a "Three-Way" switch as follows
Option 1. Fixture Controlled by Two Switches: Power Through a Switch Box
Two three-way switches control one light with the electric power coming through the first switch, flowing to the second switch, and then to the light fixture. The ground wire goes through both switch boxes and the ceiling light box and it is connected at all junctions, except the light, with a pigtail (short piece of wire) and wire connector. The hot wire in the drawing is black and is connected to the COM terminal. The neutral wire is white. Track each with a finger to its conclusion at the light fixture to ensure proper connection.
Nov 16, 2010 | Heating & Cooling
Electrical cord was accidentally pulled out of ac unit.
Green is ground, secure to frame. White goes to compressor, located behind LED/LCD, lower right corner you'll see a number of other colored wires kind of in a circle, each connected to a 'port'. The black goes behind LED/LCD panel also. Top far right, back corner. 2 ports are connected to a black box..a red one and should b your black one.
GOOD LUCK!
Jul 13, 2010 | Kenmore 75085 Air Conditioner
Wiring for Goldstar R5050 window A/C
Yes I accidentally drop my Gold Star Model #R5050 out the window while installing it. I opened it up and the two(2) white wire are off and I don't know were they go. I try to connect the to the empty terminals and I got a spark out of the outlet. Can you please help me....
May 13, 2010 | Goldstar R5050 Air Conditioner
What is a wire lug in my AC unit?
A lug is defined as a screw terminal made to accept one or more wires. Lugs as such are found in Circuit Breaker boxes (and on the circuit breakers themselves) Electrical junction boxes, Contactor relays such as found in Central Air units, those all being fairly large. There are also small lugs as would be associated with small wires such as thermostat wiring. Terminal diagrams for user-made connections are always provided with the unit being connected be it thermostat or HVAC unit. The thermostat comes with written documentation including diagrams, HVAC units typically have a diagram glued to the inside of the access panel.
Electricity can be your friend but can also kill you. Disconnect the power before altering or making any connections. If you don't know what you are doing, don't become a statistic, get help.
Jul 12, 2009 | Heating & Cooling
Will a short/ground in the thermostat wires cause a model(-) HQA to burn up the 24 volt transformer
If the transformer wires are shorted together, this will burn up the transformer. Normally transformers on the LV side (24 volt) are not grounded, but the solenoids that they control could be grounded, and a t-stat wire that is unintentionally grounded could burn up the transformer, but its not likely.
Jul 09, 2009 | Ruud Heating & Cooling
Unit trips circuit breaker when plugged in
On AC current it really makes no difference to the operation of the unit which terminal the wires are connected to as long as the circuit is completed. A reason for the inverted wiring is that there will be a resistance between the hot wire and the control circuit. It makes for a reduced load on the contacts and switches minimizing arching.
Jun 08, 2008 | Maytag Portable Air Conditioner M6P09S2A
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
