Question about GE Monogram ZISx420DR 42-inch Side by Side Panel Ready Built-In Refrigerator with Dispenser
Too much condensation in back.
Noticed small amount of water on floor--very slow drip underneath. Techs pull fridge out--mold on drywall behind fridge, stains on wood floor below. Tech says, "It feels like there is no insulation in the back of the fridge." Water tube clamp has rusted (allowing tube to leak, too.) and there is lots of rust and mold on back of fridge. See lots of condensation on back of fridge, even above water tube area. Only 6 years old...of course, GE says, "too bad, beyond warranty." Can't we open back and put in insulation? (GE wants to put a "heating pad" on the back of fridge--on top of moldy, wet, rusted back.) HELP!
  • Anonymous Jan 10, 2009
    I am working on it now.  GE sent a repair guy who charged 125,00US and told me that the unit was not worth fixing.  Whatever, I'm going for it and will report my findings.
  • Anonymous Mar 28, 2009
    We are remodeling our kitchen but planned to keep the existing refrigerator.  When it was pulled away from the wall, found extensive mold on drywall and water damaged wood floor.  This refrigerator has been nothing but trouble from day one.  Trouble maintaining temp in both freezer and refrigerator, problematic ice maker, etc.  The GE tech said he would never own this model.
4 Suggested Answers
  • 401 Answers
SOURCE: Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Posted on Jan 05, 2010
DeBruce
  • 145 Answers
SOURCE: How to remove rust looking stains on outer doors
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Posted on Apr 29, 2010
  • 2468 Answers
SOURCE: Water pools on the floor
check the water line back near the rear of the unit,sometime back i had the same issue and the plastic water line that comes off the water dispensing solenoid valve touched the hot compressor body and became brittle from heat and vibration of the compressor,it developed a crack and leaked in the same areas you commented on,so when you press the water dispenser paddle it opens the valve and leaks only then as you stated,i hope this helps you,please rate this if so
Posted on Oct 23, 2010
Runs but no water in pan
Are you referring to the drip pan underneath the fridge? If so the pan will gain a small amount of water when the fridge goes through auto-defrost but that water will evaporate from heat and air movement from condenser coil and fan.
Apr 19, 2016 | Refrigerators
Igloo mini fridges
The question is: Are you seeing water inside the fridge where it shouldn't be? Are there water stains in the try? Some of these have no tube, the water just drips from a small hole above the tray.
Jan 05, 2018 | Igloo FR834A Stainless Steel 3.2 Cu Ft...
GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
Condensation is forming on the glass door and dripping onto floor boards. How do we stop the condensation. It does say to empty drain tray but we cannot find it and instruction manual does not tell you...
The drain tray is under the fridge often times set back a little bit. Remove the kick plate by pulling from one side then the other side, strait forward till it pops off. The kick plate is a plate as close to the floor as you can get on the front side of the fridge going the entire width of the bottom of the fridge. Now get eye level with the underneath of the fridge. Center your view on the underneath of the fridge. The drain tray is right there. Pull it out, carefully as it is probably full of water, and dump the water out of it. Replace the drain tray and then replace the kick plate. Check the drain pan once a week or so and you should have no more water leaking on your floor. Hope this helps.
Mar 22, 2011 | Refrigerators
I purchased a house with a GE Spectra free standing electric range oven and a refrigerator. Where can I get instructions to clean both appliances? Thank you Lynn
Hello- First, instructions are basic. For oven: AVOID the so-called 'self-clean' function. Techs call it 'self-destruct'. Ovens are made to cook food, not bake pottery. Avoid or try to predict boilovers and spills. Use drip pans and foil. Light scrape, light soapy water. Turn on to 450deg  for 30 min. Less time, less energy, less smell, longer lifespan for control circuits.  Next, the fridge: Dust and all forms of fuzzy stuff on the cooling coils underneath and behind the fridge causes most problems. Getting it out involves pulling panel below door and finding a vacuum nozzle that will fit in most of the way to the back. Pulling out is not always easy, but allows for full cleaning access. -Don't scratch floor.- Let me know if this info helps- have more if needed. -Thanks- ED
Mar 06, 2010 | GE Eterna EGR2000EMBB Gas Kitchen Range
Water dripping from underneath
The water is most likely coming from the condensation that's drained out of the refrigerator during the automatic defrost cycle.
Be sure the bottom fan is running and clean out the condensation tray. Warm air pulled across the condenser coils is supposed to evaporate the condensate water. If the fan is not running when the refrigerator cycles on, replace it. This would also result in the refrigerator running excessively without cycling off.
While you're working under the unit, be sure to clean off the coils too.
Good luck. Hope this was helpful.
Nov 20, 2009 | Computers & Internet
The hole at the back of fridge is not letting water go down so i have puddles of water running to front of fridge have tried cleaning out but just the same
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 14, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Kenmore fridge is leaking inside from light switch
The drip pan is underneath on the floor. You don't really need to see it. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Sep 18, 2009 | Refrigerators
Water leak behind/under refrigerator
There can be a few problems causing this. Diagnosis with a good flashlight is the best way, actually see what is wet.
The most likely is a part of the cold side pipework that has a lump of frost on it that has built up and is dripping. I have seen this many times. Switch the fridge off and use a hairdryer to melt the ice. Then dry it off and either wrap it with a small piece of foam pipe wrap and even cut a strip of bubble wrap, wrap it with 3 or 4 layers and secure with tape. This keeps the cold in and stop moisture in the air freezing and building up.
A breakdown in the wall insulation. This causes condensation on the outside of the cabinet anywhere on the appliance. There is no way to fix this.
Or that the metal tray on top of the compressor that evaporates water from the defrost cycles is rusted through or over filling.
Slide a piece of cardboard under the rear of the fridge and bring it forward to the front feet. Remove the cardboard after 24 hours and see where the drip is on the cardboard. This will tell you where under the machine the water is coming from.
Dec 05, 2017 | Maytag MFC2061KES Stainless Steel French...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
