Question about Toshiba Satellite A100-S8111TD Notebook
Flash cards not responding
Most of the times the flash cards are not responding and masking the top of the screen ,its annoying.
  • rubignylouis Oct 24, 2008
    what can I do then to fix up the problem
    I dont much at all about computers.
    There is a narrow window right accross the sreen and it say textually"toshiba flash cards are not responding" and this stay there during the all session.
  • Toshiba Master
  • 13,433 Answers
Can you clarify what do you mean exactly with a flash card? masking the top of the screen? what actually?
Posted on Oct 24, 2008
  • Ekse Oct 24, 2008
    so this is a program that is not working properly? what kind of cards are you using with the computer?
    President:
  • 2,712 Answers
What do you mean by flash cards?
  • Toshiba Master
  • 19,396 Answers
That can be a problem with the flash card reader , probably hardware.
  • Ginko
    Ginko Oct 24, 2008
    Flash cards reader can freeze the computer:
    Because they are faulty, in this case save data, and buy a new card, or format old one.
    Because the card reader had a bad or lose connector, or is faulty. In this case the computer should be taken apart by a technician and fixed.
    Also software and system problems can give troubles when using card readers.
    Give more details on the problem, how does it happen?
  • Ginko
    Ginko Oct 24, 2008
    If you are not using the flash card reader you can tempoorarily disable it.
    Follow these steps:
    • Go into Start -> settings -> Control Panel -> Administrative Tools -> Services
    • Make a right click on "Smart Card" and left-click on "Properties"
    • In the window which pop´s up you have to stop the service and disable it with choosing "Disabled" at the option "Startup Type"
Function key bar appears on desktop screen
Start - All Programs - Toshiba - Utilities - Settings for Flash Cards
then just place a check mark in the box labeled "DisableToshiba
Flashcards"
Jan 06, 2010 | Computers & Internet
I have the nokia 5800 xpressmusic which i have just got. in the top right hand corner there is a envelope flashing, when you click on it its says simcard memory full, i have all ready cleared the numbers...
If you've just put your SIM card in your Nokia 5800, you may have noticed a flashing envelope icon at the top of the screen.
This icon indicates that the SIM card's own text message storage is full. This doesn't actually cause problems on the 5800 because it stores its messages in the phone's own memory, but the envelope can look a bit annoying.
To get rid of the flashing envelope:
1. On the standby screen press the white menu button.
2. Select "Messaging"
3. Select "Options"
4. Select "SIM Messages"
5. Delete some or all of the messages from the SIM messages folder using the Options menu.
This should make the flashing envelope go away. You only have to do this once because when the SIM card is emptied it won't fill any more, as the 5800 does not store messages on SIM cards.
Nov 19, 2009 | Nokia Lands Phones
Hi How do I take the cover off to replace the screen? Toshiba A105 S1712
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The LCD screen mask is secured by five screws. These screws are hidden under the screw seals.
Remove three screw seals from the top and two seals from the bottom of the LCD mask.
Remove LCD mask securing screws.
Start removing the LCD screen mask with your fingers. Place your fingers between the mask and the screen and release plastic latches.
To release plastic latches on the side you can use a guitar pick. Do not use a screwdriver or you can damage the screen.
After all latches are released, you can remove the LCD screen mask.
Nov 03, 2009 | Toshiba Satellite A105 Notebook
Nokia 5310 wont turn on
there is a software problem you need to flash your phone and then install its software...
Dont forget to rate plz
Sep 07, 2009 | Nokia 5310 Cellular Phone
Flashing screen
Bad video driver!
Or screen is going.
As it's under warranty take it back
Aug 09, 2009 | Acer Computers & Internet
Samsung e2510 memory card
sounds like it needs formatting in the phone for it to responde have had that trouble a few times hope this helps
May 02, 2009 | Samsung SGH-E251 Mobile Phone - Black
I purchased a NAVMAN S-150 GPS In-Car Unit last week from ****-smith online shop. I have been testing this device for several days now. Why is it that the various touch screen buttons respond differently...
I have the same problem, the s150 touch screen is pathetic, Got the same story from Strathfield Car Radio..it was normal and had it in for repairs twice when the screen went crazy with vertical lines, same fault both times. I went back to using my s50 and will sell the s150, it is a highly complex, very pretty lemon. They wont refund you or give map upgrades for inconvenience caused by their faulty product. To sum the s150 up. A truly Miserable experience. Rate it out of ten? its a minus.
Graeme
Nov 21, 2008 | GPS
Toshiba flash cards " not Responding"
Dear Sear
First of all i aprechiat your willing to offer me a solution for the problem (flash cards are not responding).My laptop has thise model; Toshiba Satellite A200 - 1 GB - intel(R)Core(TM)2 CPU T5300 @ 1,7 MHz.
I solved the problem just with shuting down the mashin, that's all.
I thank you indeed for you respond and i'm looking forwards.
Best regards
Yours
Aweti.J
Aug 18, 2008 | Toshiba Satellite A205-S4617 Notebook
Xerox XL592DS Flashing Colors, Nothing on Screen
Sorry time for a new monitor you might open it up and look at the capacitors and see if any need to be replaced the bad ones will be domed on top normal is completely flat
Jun 19, 2008 | Xerox XL592DS (Silver) 19 in. Flat Panel...
my Toshiba (Vista home) Laptop flash cards not responding,
May 31, 2008 | Toshiba Margi Compact Flash...
Toshiba Satellite A100-S8111TD Notebook Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
