Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Cant get tractor to crank
430-t not firing
  • John Deere Master
  • 2,239 Answers
Check simple things first, is the battary good, are the conections on the battary tight, is the deck engaged, are you sitting firmly in the seat, have you fully depressed the clutch/brake pedal, the last three items are to make sure the saftey switches are dissabled
Posted on Feb 14, 2012
I have a cub cadet LT1024, with a Kohler 24hp ELS725 motor. When I turn on my ignition key, there is a 2 second delay before the motor begins to crank. What is wrong with my tractor?
Hi Martin,
I would recommend replacing the key switch part number 430-445. This is a common part to have go bad.
You can call a shop like Arcolawn.com and ask for the part 430-445. Tell them Joe M sent you and they can get you the part quickly.
Let me know if I can help further.
Best,
Joe
Sep 27, 2016 | Cub Cadet Garden
Riding mower wont fire, new starter installed
We need more information to help you. Is it that it won't turn over with the starter or that it won't fire to start when the motor is cranking over with the starter ?
Jun 18, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My riding lawn mower turns over but not fast enough to fire cant figure out whats wrong please help
I assume an electric start. Slow cranking could be low battery voltage or capacity. Check battery voltage with a digital volt meter. It should be 12.6 volts. (Unless it is a 6 volt battery which should read 6.3V when charged.) Under 11 volts it is dead.
To check capacity see how much the battery voltage drops while cranking. It shouldn't drop more than a volt.
Nov 11, 2013 | Garden
Enngine does not fire up. no spak at plug
remove the top cover from the engine then the small wire to the coil crank it and check for spark if you have spark with the wire off check your safety switch on the brake/brake pedal it is a dual switch so it can crank and still not fire if there is no spark with the small wire off the coil is bad
Sep 03, 2012 | Poulan Pro 46Inch 22 HP Yard Tractor with...
How do i add hydraulic fluid to a JD 430?
Where can I purchase a John Deere 430 Lawn Tractor Radiator?
Jun 02, 2012 | John Deere Garden
Not firing on ignition appears that mice have
Are the mice in the crank case?Either way that should not bother your fire.Check that the mice have not damaged your plug wire .
Make sure the battery is charged.
Check ignition wires for damage.
GL
May 10, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
75 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
