Question about Magic Chef Dryers
My cye3004ayw was taking 2times to dry then it blew cold air so i cleaned the back of dryer worked cold air 1time hot now it dont start at all no light makes noise when timer is on also i noticed when no clothes was in it i would be wet moist when not in use
    Sergeant:
    Champion:
  • 245 Answers
Well.. you probably smoked a high limit that controls your heating element.. which controls the whole machine. This part isn't very expensive, but it is a task to get to. You're hearing your timer because it's designed like a kitchen timer (no power). If you're uncomfortable doing this yourself (don't play with 220 if you're inexperienced).
Posted on Feb 15, 2012
docjohn174
  • 943 Answers
SOURCE: Kenmore Dryer Gas 110.73942101
Hi. thanks for the question. The problem you have is with a motor. it gets hot, and cuts off. pull dryer away from wall. clean venting. remove back panel, clean all dust. that will solve your problem thanks the appliance doc
Posted on Oct 03, 2008
  • 192 Answers
SOURCE: dryer doesnt dry clothes
I suspect you have a blocked air vent. A blocked vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Posted on Jun 06, 2009
Controlfrk
  • 304 Answers
SOURCE: drying not drying, clothes moist after hours
This is likely the result of an air flow problem if you are sure the heater is working. Ensure you are not running the dryer in a closed room which would starve the dryer of air dramatically reducing the air over the clothes even if the full length of your vent is brand new. Next, remove the vent hose from the rear of the dryer and check for strong air flow at the outlet. If it seems strong enough then run a vent through a window or out into another room and do one load in this fashion. If this resolves your problem the blockage exists in the vent line outside your dryer and disassembling dryer becomes unnecessary.
If not, ensure you have seen and touched every inch of interior dryer piping and hold the lint filter up to the light to be sure you can see through it. Disassemble and clean ANY section of piping you can't get your hand into. The area below the lint filter tends to catch a lot of lint and can only be accessed by removing the housing at the rear on the left side as you face the rear. Ensure the blower wheel turns when the motor turns. (Newer models may have the filter housing at the front)
Having performed all these actions will likely resolve the problem.
Posted on Sep 19, 2009
  • 185 Answers
SOURCE: Dryer turns on and rotates. However, does not dry
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Posted on Mar 21, 2010
Testimonial: "Thank you. I will check this"
  • 171 Answers
SOURCE: my dryer does not dry clothes
i would start by checking the thermal fuse and then the heating element itself.
Posted on Jul 29, 2010
Ge front load dryer
Your issue probably causes by vent duck was blocked either at the rear or from inside the duck. Take off the vent where it hooks up to the rear of the dryer. Turn on the dryer, if it works with hot air again then you have to clean your vent duct. Else, you need a service man to find down what is wrong with the thermostat, burner, etc...
Oct 15, 2013 | Washing Machines
The dryer is not fully drying clothes
Here are a few basic trouble shooting things to try to get you started. Is this a gas or electric dryer? I will assume electric. Check to make sure the heating element is heating up. You can do this by taking off the vent hose on back, putting the dryer on a hot dry cycle and feel the air coming out. You should have a very strong flow and after just a few minutes you should have hot air. If the air flow is weak, you need to clean the vent and lint tray with a flexible brush to clear any lint and debris from the air path. If the dryer is not blowing hot air it could be a thermostat, the heating element itself or even a bad circut breaker only allowing half of the 220 volt electric to work.
If you have a strong air flow, and hot air the next step is to hook the dryer up to the vent again, go outside and find where the dryer vent exits the home. At the vent exit if you have flaps covering the exit they should blow out fully when the dryer is running, and if there is no vent cover the air flow should be just as strang as it was at the back of the unit. If it is a weak flow you will need to clean or replace the vent from the dryer to outside the home. The most common cause of slow dry or incomplete drying is restricted air flow or the heater not working. Please let me know if any of this helped or fixed the problem. If not we can look into more possible solutions.
Mar 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
We have not used our Daiken wall mounted inverters since the cold days of winter, and now the remote control will turn on the lights, but nothing else goes on and no cool or warm air will come out. The...
Normally, there will be error code whenever the problem arises. But if you couldn't see the error code, depends on counting number of flash, we can diagonize. Any how, with your limited statement, I hereby try to solve your problem.
Indoor Room thermistor error 1time Flashing
Indoor in-piping sensor error 2times flashing
Communication error between in and out 5times Flashing
Indoor Out-Piping sensor error 6times Flashing.
Hope, this helps you.Thanks.
Dec 25, 2010 | Fujitsu Heating & Cooling
No heat just warm air
I think you are on top of your problem,,you dont need any one elses advice.
Complete rebuild of the cooling and heating system,, simple.
Jan 19, 2009 | 2001 Oldsmobile Alero
Dryer is hot but not drying throughly
Hi klsuch.
When a dryer starts taking too long to dry usually there can only be one problem.
A lack of air flow.
To solve this make sure you lint screan is clean everytime you use the dryer and then check the vent in the back of the dryer. Take the vent looses from the dryer and start the dryer and feel the amount of air exiting the machine. If you do not have good air movement then you may have a blockage in the dryer or even a bad blower wheel. If the air pressure is good you may have a blockage somewhere between the dryer vent and the exhaust outside. Once you get all the lint and any little critters that may have built nests in your vent cleared out your problem should be gone. If you find that the blower wheel may be bad let me know and I can help you with the replacement. I hope this will FixYa. Please dont forget to rate me.
Mike
Mike Anderson
Oct 28, 2008 | Frigidaire GLGT1142CS Top Load Stacked...
I have a whirlpool dryer that heats until I walk away and when I come back it is blowing cold air and my clothes are cold and damp. I blew out the dryer itself , dislodging much lint, removed the back and...
It sounds like you have a clog in your vent line somewhere between the point where it exits the dryer to where it exits the house. You may still need to remove the entire line and clean it thoroughly.
Here's an easy idea you can try to determine: Remove the vent hose from the back of the dryer and try running a load with the hose removed. The air leaving the dryer should be hot (about 140 degrees F) and forceful. If it's not, you have a clog INSIDE the dryer somewhere. If the air flow is normal, allow the dryer to run to see if your drying results are better. If so, you have venting problems EXTERIOR to the dryer. Either your vent line is clogged, is kinked somewhere, or too long. Remember: The SHORTER and STRAIGHTER a vent line, the better. If your drying results are about the same, then you probably have an operating thermostat that failing. Here's a helpful link you can try to assist you in troubleshooting:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Let me know if your need further assistance. I hope this helps you.
Jun 15, 2008 | Whirlpool Dryers
Hotpoint washer dryer leaking water whilst drying
driers work by running cold water down the back plate of the machine so the hot damp air condence's on to it. It works on the same principle as your bathroom mirror, because its colder than the air around it the moistier in the air condence's on to it. Most machines use a seperate inlet valve from the cold water to do this, they are proned to rub against the back of the drum.Take the top cover off the machine and check the hose's from the cold inlet onto the back of the machine you'll probably find a hole worn in it.
Oct 21, 2007 | Hotpoint Ultima WD72 Front Load...
Dryers Logo
128 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Roderick Scott
Roderick Scott
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
