Question about Shimano Cycling
How to replace shimano st-4400 shifters
Left shifter has stopped working. have purchased new left and right shifters, but how do i install the new.
  • 18 Answers
SOURCE: Shimano st 7900 shifter,left lever apart and how to reassemble
You can download an exploded diagram of the 7900 series STI shifters here:
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-7900-2874E_v1_m56577569830670749.pdf
You can reassemble them according to this diagram.
Posted on Jul 07, 2009
  • 484 Answers
SOURCE: Shimano Deore LX right hand rear shifter
HERE is Shimano's exploded-view diagram of the shifters, but it really only gives you a ballpark idea of the assembly. You will have to piece the rest together from memory, i suppose. Sorry, i could not find more information for you.
Hope this helps a little,
matt
Posted on Oct 08, 2009
SOURCE: shimano lx m569 shifter assembly diagrams
http://techdocs.shimano.com/techdocs/index.jsp
try here
Posted on Feb 18, 2010
johnegan84
  • 73 Answers
SOURCE: require assembly schematic for shimano dura ace
log onto Shimano.com, it is probably the limit screws (the two screws that limit travel) or you have a faulty ratchet in the lever, try the shimano website anyway they have great tutorial and manual support
Posted on Mar 27, 2010
Coachphil
  • 347 Answers
SOURCE: With Shimano 6603 Group can you use Shimano 5703
The answer is yes and no.
The 5703 shifters will work both derailleurs and match the 6603 group as they are both 10spd.
The Tiagra will not work because it is 9spd, it will functionally shift the derailluer but you will not be able to line up the gearing.
The rear shifter needs to match the number of gears on the back (cassette) in the case of the 6603 group that is 10spd, so you can use any 10spd rear shifter from shimano. The Tiagra is either an 8spd or 9spd depending on the model and will not work with the cassette. You can use a 6603 rear derailleur with a Tiagra group, as long as the shifter and cassette are both the same.
Posted on Dec 14, 2010
Exploded view of shimano gear shifter altus st-ct90
Sorry, Shimano never intended those shifters to be taken apart and serviced, so they didn't release an exploded view. Here's a link to the orginial EV document. http://bernd.sluka.de/Fahrrad/Shimano/TM/ST-CT90_1995.gif
Mar 30, 2017 | Shimano Cycling
Exploded view of parts diagram for shimano tourney st-ef40 shifters for re-assembly?
If you can't find with a search for st-ef40 diagram or on the Shimano site then it does not exist. Although not identical carefully disassembling the other shifter may give you enough insight.
Apr 08, 2015 | Shimano Tourney ST-EF40 3x7 Speed Brake...
Hot to use Shimano Tiagra FD-4400 on a triple front mech?
Can't tell what's wrong without knowing everything you've done. Try just going through the Park Tool procedure from start to finish, skipping no steps. http://www.parktool.com/blog/repair-help/front-derailleur-adjustment Front Derailleur Adjustment
May 13, 2017 | Cycling
Hi! is there any replacement for shimano ST-3300, 8 speed, right hand STI lever?? many thanks
There's a used pair on an eBay auction right now ending 6d 09h (Sep 21, 201101:52:54 PDT) that you might be able to snag for cheaper than a separate right lever. Wait til the last 10 seconds and bid ONCE. Leave time to confrm the bid.
http://www.ebay.com/itm/SHIMANO-SORA-8-SPEED-STI-3300-BRAKE-LEVERS-DUAL-SHIFTERS-8x2-8sp-/200651614761?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item2eb7c4aa29
There are other models, too.
My $.02: I'd take the opportunity to switch to Campi Ergo (also available on eBay). The brake lever is ONLY a brake lever so you don't have to tip toe around it when shifting and ALL CABLES are hidden.
Sep 14, 2011 | Shimano Sora ST-3304
Install Shimano revoshift. bike came with shift cable not attached. how do I attach it? thanks, barry lentz
Front or rear? Is the cable not in the shifter?
If the cable is not in the shifter, there will be a screw in the shifter (made of plastic, usually black) facing outward. You open this and shift the shifter into the highest gear, then slip the cable through and out the side that accepts the cable sleeve. Then you run it through the sleeve and to its appropriate derailleur (left hand=front, right hand=rear).
Sep 12, 2009 | Mountain Shimano Revoshift Bicycle...
May 11, 2009 | Shimano 2008 Dura-Ace BR7800 Rear Road...
8speed lx shifter to xt shifter
It depends.. Shifter cables are standard and the same one would work for both LX and XT shifters. If the old cable is full of grime etc, it is a good idea to run new cables - it will give you a smooth easy shift.
I am sure if you check www.shimano.com you will find the manual for your model of shifter. Replacing cables is pretty easy.
Jan 24, 2009 | Mountain Shimano Deore Bicycle...
Cycling Logo
204 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Eric Hidle
Level 1 Expert
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
